Snow chains vs cables TRD PRO
Discussion in 'Wheels & Tires' started by SugarRush, Nov 10, 2020.
  1. Nov 10, 2020 at 10:12 AM
    SugarRush
    SugarRush [OP] New Member
    D
    2020 White TRD Pro
    Retrax POWERTRAXPRO XR
    Looking for snow chain or cable suggestions on brands & placement and experience to be in compliance and prepared if necessary ... mine’s a 2020 TRD PRO and this is my First Toyota 4x4
    I’m in OR longer than I expected & I’m sure to meet up with some inclement weather on my drive across through ND to NY & eventually down South maybe.
  2. Nov 10, 2020 at 10:16 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I have Laclede cam lock chains. I also carry some of the rubber snubbers for additional tightening. I don't think they'll fit on the front tires, I need to install them and take a look. Pretty sure there isn't enough clearance from the UCA on the stock TRD rims. A different offset may allow enough clearance.
    If you really want to get in deep, the V-bar type chains really offer some bite. FWIW, I typically don't use chains on the way in unless I have someone else with me. I use them to get out after I get stuck in 4WD. I don't have a winch though.
    SugarRush[OP] likes this.
  3. Nov 10, 2020 at 11:35 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Are you coming back to Or? If so buy at Les Schwab. If you don’t use them you can take them back for a full refund in the spring.
    As for type I don’t know which to recommend or why. My last Tundra had 35’s and I only had 1 choice chains.
