So, how hard is it to remove inner and outer tie rods?
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Jan 3, 2024.
  1. Jan 3, 2024 at 6:10 PM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Last weekend I replaced the driver side lower ball joints, and if all goes well, this weekend I'll replace the passenger side.
    Next up after that, I'm such a masochist, are the inner and outer tie rods.
    How hard is this?
    One of the threads in this forum recommends a Lisle 54500 Inner tie rod tool, 42 mm. Is this a good idea?
    Also, I was planning on replacing my 13 year old OEM tie rods with Import Direct tie rods from O'Reilly's.
    Several times a year I take my truck on rough four wheel drive required dirt roads when I go camping and fishing. I'm definitely not a four wheel enthusiast, but I definitely use and need four wheel drive several times a year.
    Should I consider something more heavy duty.
    Thanks so much.
  2. Jan 20, 2024 at 10:10 AM
    myt1
    Richard
    Scottsdale, AZ
    To make a long story short, I was able to remove the inner tie rod with an 18" pipe wrench. I worked great.
    I tried a couple of other ways first, but they did not work. I couldn't rent an inner tie rod tool that would fit, and I couldn't get the wide opening, narrow jaw crescent wrenches I bought to work either.
    With the pipe wrench it was a piece of cake.
    SF1973, Krewcial and NewImprovedRon like this.
