So I got a 4.6 2014, I wanna LS swap or Cummins swap, can I?
Discussion in 'New Member Introductions' started by oakTri1, Oct 13, 2023.
  1. Oct 13, 2023 at 11:49 AM
    oakTri1
    oakTri1 [OP] New Member
    Got the 4.6 with 2wd, I wanna turn it into something fun, what’s some options you guys would offer and is it possible?
  2. Oct 13, 2023 at 12:02 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome to the site . Anything is possible with enough time and money .
    ZappBrannigan and snivilous like this.
  3. Oct 13, 2023 at 12:44 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I don't know exactly how much a Cummins weighs, but I don't think I would trust a half ton frame under it. Guys who take their Tundras off the beaten path a lot are already having custom shock tower braces built, and that's with the stock 5.7L.
    An LS swap would probably be easier, but you're still looking at a lot of custom work.
    It's probably easier and more cost effective to sell the truck and buy what you want. If it were me, I'd get a 4wd 5.7L truck and just supercharge it.
  4. Oct 13, 2023 at 12:46 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If you don’t already have a good idea of what is possible, chances are you don’t have what it takes to make any of it happen. Unless you’re paying someone who does know to do it for you.
  5. Oct 13, 2023 at 12:58 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    I would say sell it, and buy with 5.7. Because unless you can do the job yourself it will be VERY expensive
  6. Oct 13, 2023 at 1:01 PM
    ~1050 lbs for a 6BT. That includes turbo.
  7. Oct 13, 2023 at 1:03 PM
    I would sell and purchase a 5.7L.
    If this is just something you want to do, LS3 crate motor would be the easiest route.
    ZappBrannigan and AZBoatHauler like this.
  8. Oct 13, 2023 at 1:23 PM
    Welcome from NY.
    :spending:
  9. Oct 13, 2023 at 2:00 PM
    SD Surfer
    Bruce
    So Cal
    You can do anything you want if you throw enough money at it.
    ZappBrannigan likes this.
  10. Oct 13, 2023 at 2:57 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    You can do a 4 cylinder Cummins diesel swap. Time, money, and resources, you can swap almost anything into your truck.
    ZappBrannigan and Mr Badwrench like this.
  11. Oct 14, 2023 at 7:45 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  12. Oct 14, 2023 at 7:46 AM
    This 1000%
  13. Oct 14, 2023 at 7:49 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I'd find a V10 out of an old Viper, add twin turbos, and go shred some tires. If you have a CM, maybe see if you could make a mid-engine mount work.
    Disclaimer: I might watch too much "Roadkill" and other similar shows. :laugh:
    Lovetrucks likes this.
  14. Oct 14, 2023 at 9:20 AM
    Mr Badwrench
    Mr Badwrench New Member
    If you swap and old 12 valve Cummins (or a 24), you won't have to worry about a computer. Not knowing anything else, because I don't, that might be the easier way.
  15. Oct 14, 2023 at 12:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  16. Oct 14, 2023 at 1:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Can you? I have no idea. If the question was actually supposed to be “May I?” then I hereby grant you my permission.
    Post a build thread if you giterdun!
  17. Oct 14, 2023 at 1:21 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    If it's a 2007-2021, wouldn't a 5.7 swap be the easiest path?
  18. Oct 14, 2023 at 1:41 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
  19. Oct 14, 2023 at 3:34 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    KNABORES likes this.
  20. Oct 14, 2023 at 4:15 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    If you go 12 valve, make sure to leave enough room for a radiator, intercooler, transmission cooler, a/c condenser, cooling fan, and fan clutch.
  21. Oct 14, 2023 at 4:27 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    people are dropping those r2.8’s into 80 series pretty frequently now. That rig isn’t too much lighter than a tundra and the r2.8 is pretty much the same weight as a 5.7. I think it’d be underpowered but all the YouTubers are saying those rigs are a blast to drive. But then again, how many YouTubers actually say anything negative on their channel. All about the hype
    Terndrerrr[QUOTED] likes this.
