Softer-riding front struts that keep stock ride height?
Discussion in 'Suspension' started by Reckoner, Mar 3, 2022.
  1. Mar 3, 2022 at 3:52 PM
    Reckoner
    Reckoner [OP] New Member
    2014 Tundra SR5
    Hey all, I'm new here. Long time lurker, first-time poster.
    Anyway, I am looking for a softer on-road ride--less crash-through on pitted bumpy roads, railroad tracks, etc. Important note: I like the stock ride height and the factory rake--I don't want to lift or level the truck. I have replaced my rear shocks with Fox 2.0s, and I think it helped a lot back there. Now I'm turning my attention to the front.
    Considering the Bilstein 6112 and Fox 2.0 strut assemblies. Trouble is, I'm reading that the Bilsteins will raise the front end about 0.75 inches.
    QUESTION: Does anyone know if the Fox 2.0s at their lowest setting will keep the stock ride height?
    Are there other options I should consider?
  2. Mar 3, 2022 at 4:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Eibach can be set for 0 lift and they are quality shocks. Do you have the stock black hitachi ones now?
  3. Mar 3, 2022 at 4:35 PM
    Reckoner
    2014 Tundra SR5
    Yes, just the stock black ones. I actually bought a set of the yellow/blue TRD off-road shocks (Bilstein 4600) on my local classifieds, but learned after buying them that they’re probably even worse than the black ones I have.
  4. Mar 3, 2022 at 4:47 PM
    HOKIES
    HOKIES New Member
    Western Virginia
    2021 B Red Crew Max
    Consider 17 inch wheels with larger sidewall tires?
    2mchfun likes this.
  5. Mar 3, 2022 at 5:29 PM
    Reckoner
    2014 Tundra SR5
    I had 20s and switched to 18s. I have the TRD off road wheels with Goodyear Wranglers. Stock size. 275/65/r18.
    I don’t have interest in switching to 17s.
    HOKIES likes this.
  6. Mar 3, 2022 at 5:33 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Falcon is what you seek.
    Bilstein 6112s and Fox 2.0s will not soften your ride at all. They will be much more firm.
    1lowlife likes this.
  7. Mar 3, 2022 at 5:37 PM
    Reckoner
    2014 Tundra SR5
    Not sure what Falcon is. Is that a brand of strut?
    What’s your experience with these struts? The other forums I’ve read extensively suggest both the Fox 2.0 and Bilstein 6112 will substantially improve ride quality.
  8. Mar 3, 2022 at 5:45 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Falken is a tire brand. Your stock struts are good enough for what you look for. Ride comfort is determined by rear suspension as your empty bed even the softer stock suspension to make your truck bouncy.
    I installed Road masters active suspension on the back with rest being stock to avoid squatting pulling trailer but RAS helps to eliminate the bounce considerably too. Much better smoother ride and it barely lifts the back up. You can adjust the RAS to the low setting and you barely get a 1/2'" lift. Your smoother ride in back will result in smoother ride overall. That's my experience. Billstein 6112's will stiffen your ride and from what you say its the opposite of what you want.
  9. Mar 3, 2022 at 6:06 PM
    Black
    Yes Falcon is a brand and they blow both the 6112s and the Fox 2.0s and 2.5s out of the water. I have had them all and my Tundra rides on Falcons now. They are far superior to Bilstein and Fox offerings.
    Not only in ride comfort but pure build quality.
    https://www.falconshocks.com/2007-toyota-tundra
    https://youtu.be/AtCqYjx2JxM
    You are some what correct. Falken is a tire brand but we are talking Falcon which is Teraflex’s shock brand.
    Ride comfort comes from much more than just your rear suspension.
    I have had the mentioned Bilsteins and Foxes they are not really that good in the comfort realm.
    I now have Falcons with Coachbuilder +1 shackles and the truck rides like an absolute dream both on and off-road.
    The only way it would ride better is spending thousands more on fully dampening adjustable setups.
    HulkSmurf14 and AggiePhil like this.
  10. Mar 3, 2022 at 6:15 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    I really enjoy the Eibachs. Like was already stated they can be set at stock ride height. I’m set at 1.9 with a ranch hand bumper on the front and it rides great. Very comfy on/off-road.
    Reckoner[OP] likes this.
  11. Mar 3, 2022 at 6:17 PM
    Mobeyk
    Mobeyk New Member
    I just got a set of Eibach Pro Truck Sport shocks in after reading recommendations on here. You confirm what I am going for. Can't wait to get them on.
  12. Mar 3, 2022 at 6:20 PM
    Reckoner
    2014 Tundra SR5
    @Black Interesting. Do you know if the falcons can truly be adjusted to stick ride height? The Bilsteins say 0” is the lowest option, but the people I have spoken to said even the 0” still raises the front of the truck 0.75”.
    HulkSmurf14 likes this.
  13. Mar 3, 2022 at 6:22 PM
    Black
    Yes. There is a setting for stock height.
    The reason the Bilstein can raise the height slightly even though it is the stock setting because the 6112s utilize a new spring.
    Their point of measure comes from a setup with their old spring that was likely a bit worn so it is not the truest measurement comparison.
    A brand new truck to Bilsteins at the stock setting likely would see very little difference.
  14. Mar 3, 2022 at 6:24 PM
    Black
    Did you get the 2.0s??? They are truly a bargain and give a fairly good ride.
    We put a set of the 2.0s on my buddy’s Tacoma and I was super impressed with their ride quality and performance for the price.
    Though I really feel these Tundras would do better with a 2.5 option and would love to see Eibach make a larger shock body for these trucks.
  15. Mar 3, 2022 at 6:37 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Do you have a rear sway bar? I feel that helped improve the ride.
  16. Mar 3, 2022 at 6:41 PM
    Mobeyk
    Mobeyk New Member
    No. I talked to Eibach with my specs and what I use it for and they said I can keep my oem front springs and replace the front and rear with the pro truck sport as the RAS already improved ride in the back and I have the option of raising the front a bit and have a bit better struts at the front.
  17. Mar 3, 2022 at 6:48 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    I'd go with Falcons on the stock height setting. They are way better than anything close to their price point.
  18. Mar 3, 2022 at 7:38 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have 6112s set at +1.9. I have no problem with the ride but I have always owned trucks so maybe just use to the way a truck rides. I had a Tacoma Baja before the Tundra and it had 6112s from the factory. I was definitely a little rougher riding then the Tundra. I have to bite my tongue when I see posts about how a truck rides.
    mattyd170 and MaxPower like this.
  19. Mar 4, 2022 at 4:19 AM
    Black
    Not sure I understand your post. I have driven trucks all my life as well and realize that a truck is not going to ride like my Granny’s Cadillac. I am also well aware that one can make a truck ride far better than they do from the factory all while gaining far better off-road performance as well.
    So I am not sure what you are getting at or why one needs to bite their tongue when folks are asking questions about something that is certainly achievable.
    There is no doubt it is a truck and not sure anyone is trying to change the fact that it is a truck.
    But my Tundra with this Falcon setup rides smoother than a few of my sports cars I have had over the years.
  20. Mar 4, 2022 at 5:15 AM
    1794TX
    Steven
    N.TX
    '20 1794
    +1 on the Falcons.
    HulkSmurf14 and Reckoner[OP] like this.
  21. Mar 4, 2022 at 8:01 AM
    Reckoner
    2014 Tundra SR5
    Thanks @Black . You've done your homework! You've given me some good leads.
    @Stumpjumper I understand that trucks ride stiff. I also know that within the Tundra realm, there are some that ride better than others--for example, the TRD Pro comes from the factory with a much more comfortable setup.
    I use my truck for towing and outdoor adventures, but I also daily it. I'm willing to invest a little in my comfort.
  22. Mar 4, 2022 at 8:19 AM
    Black
    And failed the quiz twice while I was at it. Since I had Bilsteins and Fox before getting the Falcons.
    But also the Falcons weren’t available when I first started shopping.
    The Bilstein and Fox are good product. The ones you have listed just do not provide a comfortable ride which is what you are trying to obtain.
    Also being that you tow the adjustable rear Falcon shocks for towing are nice.
    I don’t tow a lot but every spring I haul loads of compost and manure and the switch makes a very noticeable difference.
    I presume for towing it would do the same.
    Reckoner[QUOTED][OP] likes this.
  23. Mar 4, 2022 at 8:21 AM
    Reckoner
    2014 Tundra SR5
    @Dawoofles did the rear sway bar stiffen the rear end, or make it more compliant? I've heard it helps with axle hop.
  24. Mar 6, 2022 at 7:30 AM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Do the Falcons have longer shafts than the stock shocks? Wondering if you gain any travel with them.
  25. Apr 10, 2022 at 1:17 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    You will never, ever notice a .75" difference in height, even with a tape measure and on level ground.
  26. Apr 16, 2023 at 10:49 AM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Yes you sure will notice it. Put Eibach Pro Truck Coilovers (adjustable) on my stock height 2018 DC SR5 and with them all the way down it was 1” higher.
  27. Apr 16, 2023 at 2:30 PM
    mattyd170
    Albuquerque, NM
    Okay, if you say so.
  28. Apr 17, 2023 at 3:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
