Solar panel added to the truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by cquilichini, Feb 3, 2020.
  1. Feb 3, 2020 at 6:33 AM
    cquilichini
    cquilichini [OP] New Member
    Hey Guys I just wanted to share an Idea that came to me after reading a post where a fellow Tundra owner added a permanently installed solar panel to a Tundra he uses for camping and as his daily driver to power his 12v fridge.
    So I don't really camp but the idea of having a permanently installed solar panel sounded like a great idea to keep my Dometic PLB40 LiFePo Battery charged all the time which powers my Dometic CFX50 12v Fridge.
    So i Measured the bed of the truck and the size of a 100 watt solar panel and with those measurements in mind, I had a stainless steel fab shop custom made this base for the panel and I think it turned out pretty cool.
  2. Feb 3, 2020 at 6:37 AM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    I dig it. How much did the Fab cost? I have a love hate relationship with solar panels. I'd love one on the truck for camping buuuuuut the only places I camp happen to be fairly heavily wooded which would turn my solar panel into a shiney paper weight.
    kevine0001 likes this.
  3. Feb 3, 2020 at 6:41 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Specs on the panel?
    What other hardware necessary?
    Been thinking something similar (don't want to drill holes in my roof for a rack). But that placement would have me worried as I offroad and my beds always a flexin.
    Sunnier likes this.
  4. Feb 3, 2020 at 6:48 AM
    cquilichini
    the fab shop invoiced me close to $300.
    Rica25 and Jpneely[QUOTED] like this.
  5. Feb 3, 2020 at 6:49 AM
    cquilichini
    The panel is a Renogy 100 watt mono (compact design). Sourced from Amazon. also needed the solar panel surface mount brackets (aluminum).
  6. Feb 3, 2020 at 7:00 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Never mind
    I need to read
  7. Feb 3, 2020 at 7:47 AM
    2chains
    2chains New Member
    Southern Ablerta
    Thanks for posting. I've been researching Solar chargers for maintaining my 12v battery as I leave it parked 10/12 days in our colder temps. Also I was thinking that it might be a good way to power parking mode of dash cam?
  8. Feb 3, 2020 at 7:49 AM
    cquilichini
    Do you want to maintain the truck 12v battery or a secondary 12v battery on your truck?
  9. Feb 3, 2020 at 7:53 AM
    timsp8
    NY
    That’s pretty neat. Do you need a charge controller for that battery or does it have solar plugs built in?
  10. Feb 3, 2020 at 7:56 AM
    2chains
    2chains New Member
    Southern Ablerta
    I like your idea.
    Looking to maintain the truck's 12v battery. Tons more solar options now than a few years ago.
    Want something portable to leave on the dash.
  11. Feb 3, 2020 at 7:56 AM
    cquilichini
    The solar panel plugs directly to the battery through Anderson connectors.
  12. Feb 3, 2020 at 7:59 AM
    timsp8
    NY
    I have the genesis dual battery kit and have been thinking about adding a solar panel to keep the secondary battery charged. All my extra stuff is hooked up to the secondary one. I have roof racks already too so I was going to put it on top. I’m worried something will fall on it and break it, but I guess nothing has fallen on the truck so far except hail.
    2chains likes this.
  13. Feb 3, 2020 at 8:09 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nice!
    cquilichini[OP] likes this.
  14. Feb 3, 2020 at 10:48 AM
    Breathing Borla
    Northern Illinois
    with how much the bed flexes, I would wonder how that I going to hold up over time mounted like that
  15. Feb 4, 2020 at 12:23 PM
    Dometic
    Dometic New Member Vendor
    This is a really cool (and nicely done) set up!
    DOMETIC
    mobile living made easy
    shop.dometic.com
    Use promo code Tundras20 for $25 off your order of $75+
  16. Feb 5, 2020 at 6:37 AM
    cquilichini
  17. Feb 5, 2020 at 6:39 AM
    cquilichini
    The stainless steel base for the solar panel is not completely rigid and it flexes so it will move with the truck.
  18. Feb 5, 2020 at 7:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  19. Feb 5, 2020 at 8:03 AM
    oogabooga289
    oogabooga289 New Member
    Is that a double cab without a rear sliding window?
  20. Feb 5, 2020 at 8:17 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    Plenty of folks mounting them to Roofs of RV's for years - plenty of miles - plenty of flex and some even on off road rigs / campers...they last fairly well, it is the "flexible" ones that tend to crap out after a few years - usually from heat developing under them.
    this looks like a decent install...
  21. Feb 5, 2020 at 8:31 AM
    P-Factor
    P-Factor New Member
    You will need to add a charger/controller otherwise the voltage will be to high and destroy your battery. This panel will generate up to 22.5 volts.
    The following picture (specification) is directly off one of my 100 watt Renogy panels.
    Also, please be advised that different batteries require different charging requirement i.e. Gell Cell, Lead Acid, ADM etc. and most charger/controllers can be set for specific battery types.
    Sas and 14burrito like this.
  22. Feb 5, 2020 at 8:35 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I assuming the OP got the kit from Renogy which includes the necessary controller and wiring.
  23. Feb 5, 2020 at 8:40 AM
    P-Factor
    P-Factor New Member
    I have been using Renogy products for several years and they do have a bundle package with controller, they are a good company with quality products.
    Highly unlikely he has a controller otherwise he would have said from your question.
  24. Feb 5, 2020 at 9:10 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Uhhh...yeah. what's up with that?
  25. Feb 5, 2020 at 9:20 AM
    ToyotaTundraMike
    2015 Tundra
    Do any of the double cabs even have a power window anymore? I thought that was only on crew max now....my 06 DC had one but my 15 doesn’t.
  26. Feb 5, 2020 at 10:14 AM
    cquilichini
    yes.
  27. Feb 5, 2020 at 10:19 AM
    cquilichini
    The Dometic PLB40 LiFePo Battery has it's own PWM integrated charge controller, so yes you can connect the solar panel directly to it. It will self regulate and adjust the charge rate on its own.
  28. Feb 5, 2020 at 10:40 AM
    P-Factor
    P-Factor New Member
    Thanks for this clarification. Sounded as though some were inquiring about maintaining their truck battery with the solar panel alone...
  29. Feb 5, 2020 at 11:19 AM
    oogabooga289
    Double cabs never had a power window as far as I know. I think it had to do something with the lack of room. I just realized OP is from Puerto Rico. I wonder if Toyota made a fixed-rear-window version?
