Solved: Climate control knob lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by rubberchicken48, Sep 9, 2021.
  1. Sep 9, 2021 at 2:53 PM
    rubberchicken48
    rubberchicken48 [OP] New Member
    2016 Toyota Tundra SR5, Black
    Pioneer HU and storage under the back seats
    Hey all. I can't seem to find much on this question. But do the Climate control knobs or the climate control panel light up at all? Its really dark in that area at night and seeing the knobs is sometimes impossible.
    If no lights, does anyone know of a mod or upgrade?
  2. Sep 9, 2021 at 3:44 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Mine light up but it's the basic analog three-knob-job. Just the 4WD knob is dark and hard to find sometimes.
    Does turning the odometer/tripmeter knob have any effect
  3. Sep 9, 2021 at 5:38 PM
    rubberchicken48
    The three gray knobs that control ac/heat, fan speed and airflow? Yeah, mine don't light up. I tried twisting the odometer rod like you said but it didn't make a difference. Wonder if I have a fuse out...?
  4. Sep 9, 2021 at 5:42 PM
    I have dual climate controls in my 14 Limited. Definitely a step above the climate controls that my 07 SR5 had. Especially at night.
  5. Sep 10, 2021 at 7:18 AM
    rubberchicken48
    Anyone know which fuse controls these lights? I checked #24 for the instrument panel lights but it was fine.
  6. Sep 10, 2021 at 10:08 AM
    rubberchicken48
    Can someone post a pic of these dials illuminated at night? Here's a pic of mine.
    As you can see, the three gray dials are not lit up.
  7. Sep 10, 2021 at 10:31 AM
    Backlight behind the knob and very small amount of light in the knob position indicator.
    NewImprovedRon and THinTX like this.
  8. Sep 10, 2021 at 10:33 AM
    rubberchicken48
    Many thanks!!!
  9. Sep 11, 2021 at 8:25 AM
    rubberchicken48
    I replaced fuse 24 under the steering wheel dash. Still not lighting up. Anyone know if another fuse can affect this? I don't want to have to pull and check them all but I guess I can.
  10. Sep 11, 2021 at 8:34 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Doubtful there is a dedicated fuse just for AC panel illumination. Does all other illumination on the dash panel (lighting switches, TBC, Traction switch, Radio buttons, etc.) seem to be working well?
    NewImprovedRon likes this.
  11. Sep 11, 2021 at 9:35 AM
    rubberchicken48
    Yes, all of the other lights work fine. That makes me think its a bad wiring connection behind the panel. Looks like I'll have to pull it to see what's going on. Thanks for the reply!
  12. Sep 16, 2021 at 10:02 AM
    rubberchicken48
    UPDATE: I was able to solve this problem. Fuse 24 under the dash kept blowing. The problem was with the aftermarket HU I installed. The wire cap on the yellow/black striped wire had come off and apparently was touching the metal frame, grounding it out and causing a short. I re-applied the cap and used electrical take to hold it in place. Then replaced fuse 24 and the climate control lights work now!
