[SOLVED] How to change boot screen on Kenwood DMX1057XR and DMX1037S 10.1" floating screen
Discussion in 'Audio & Video' started by someguyinhtx, Jan 8, 2022.
  1. Jan 8, 2022 at 1:54 PM
    someguyinhtx
    someguyinhtx [OP] 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    Has anyone figured out how to change the boot screen on the Kenwood 10.1" floating screens?
    Tried some youtube tricks on smaller units and they won't do it.
  2. Jan 8, 2022 at 2:03 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  3. Jan 9, 2022 at 11:10 AM
    someguyinhtx
    6" Pro comp lift
    Solved!
    Thanks.
  4. Jan 9, 2022 at 12:08 PM
    someguyinhtx
    6" Pro comp lift
    It’s working:
    619Tundra and 1lowlife like this.
  5. Jan 9, 2022 at 5:48 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Care to share what you did exactly?
    1lowlife likes this.
  6. Jan 9, 2022 at 5:57 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    I am sure he did what's in this post below because its exactly what I did to make it work.
  7. Jan 9, 2022 at 6:18 PM
    someguyinhtx
    6" Pro comp lift
    Pretty similar. I chased down a kenwood tech - there are some changes. File size is 1280x720.
    also - the tapping sequence is
    2 top left
    2 bottom left - but ABOVE the 9 key
    Then repeat with 1 tap each.
    1lowlife and BrandonL812 like this.
  8. Nov 19, 2022 at 4:24 PM
    2014Sequoia
    2014Sequoia New Member
    Other than the 1280x720 was anything different? I have the exact same radio and wondering if the text file needs to be different?
  9. Nov 19, 2022 at 4:38 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I believe I used 9999 as the model number.
  10. Nov 19, 2022 at 4:42 PM
    2014Sequoia
  11. Nov 19, 2022 at 4:43 PM
    2014Sequoia
    Thanks! I will try that!
  12. Nov 19, 2022 at 5:51 PM
    someguyinhtx
    6" Pro comp lift
    Keep me posted - i still have a facebook dm thread with the Kenwood lead that I can resurrect to ask.
  13. Nov 20, 2022 at 9:46 AM
    2014Sequoia
    It worked perfectly; all I did was use a 1280x720 and changed version to 9999
    Thank you for your help!
    619Tundra and omgboost like this.
  14. Oct 13, 2024 at 3:47 PM
    darthkevyn
    darthkevyn New Member
    Kevin
    I know this is a super dead thread but I just installed this HU did everything like in the videos changed the image to 1280x720 changed the version to 9999 and when I go to the customize screen it is just red and never takes. Any suggestions?
    619Tundra likes this.
  15. Oct 15, 2024 at 3:17 PM
    SD Surfer
    Bruce
    So Cal
    Are you guys talking about the boot up screen that just stays on for a few moments? (I think mine says Excelon)
    Or the wallpaper screen background? (Like the wallpaper of my truck/trailer)
  16. Oct 16, 2024 at 4:31 AM
    darthkevyn
    Kevin
    The actual boot up screen that says excelon. But I did figure it out. I had the text command wrong.
  17. Nov 2, 2024 at 9:18 AM
    JonnyB13
    JonnyB13 New Member
    Jonathan
    2012 Toyota Sepquoia
    Miles....
    So trying this in my sequoia. Can not get the tap sequence to work, anyone do this in the last few months?
  18. Nov 2, 2024 at 10:26 AM
    JonnyB13
    JonnyB13 New Member
    Jonathan
    Miles....
    What was the text command you changed, I’m still just getting the red screen
    darthkevyn likes this.
  19. Nov 2, 2024 at 3:50 PM
    darthkevyn
    Kevin
    So, from the video above there is a lot of downloadable files, just download the text command from there. Then add your picture. That's what I did and it worked perfectly
    JonnyB13[QUOTED] likes this.
  20. Feb 7, 2025 at 1:38 PM
    Elvio b
    Elvio b New Member
    2018 tundra platinum
    I tried the sequence and when I get in the customized tabs some are grayed out
