[Solved] HVAC tick
Discussion in '1st Gen Tundras (2000-2006)' started by Zach_795, Jul 16, 2024.
  1. Jul 16, 2024 at 2:07 PM
    Zach_795
    Zach_795 [OP] Master Apprentice
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k
    Whenever I have the fan set to “HI” there is a constant ticking noise coming from under/behind the glove box. If you switch the fan to any other setting it’s silent. Doesn't matter if the A/C is on or not. I haven’t stuck my head under there and looked at it yet; but is there a common part that goes bad or a specific thing(s) I should check?
  2. Jul 16, 2024 at 2:30 PM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    Pull fan, check for debris.
  3. Jul 16, 2024 at 2:33 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    This is the one thing that kind of sucks about or trucks not having cabin air filters. After you pull the fan (1 harness and 3 10mm screws) might as well clean all of the inside as far in as you can reach just for good measure.
    Zach_795[OP] and FrenchToasty like this.
  4. Jul 16, 2024 at 2:49 PM
    I mean, I'd go so far as to drop the blower motor and carefully pull the blow motor resistor, and flush out everything.
    @Zach_795, @GXPaycheck is probably right. It could be a number of things causing the issue because it's literally a wide-open hole above the blower, straight into the cowl. We have no cabin filter (unless you have a Sequoia, then maybe?). Chances are if you park under a pine tree, there's a pine needle or two stuck in there, slapping into the fan blade at every rotation. The fan could be on its spindle off-center. Bearing could be worn out. There could also be debris farther up the line from the fan, at the evap coil, and it's slapping against the evap coil.
    Best 1st step is to pull the fan like @The Black Mamba said, but while you're in there, be aware you can (and should probably) attack this cleanout from multiple angles if you really want to deep clean. Specifically, the red box here is your blower motor resistor - remove it carefully, two bolts holding it in. You can see the evaporator coil back in there, which is where your AC system pushes coolant through inside the ducts so you get cold air when AC is on. Then the blower motor in blue under the glove box. PHM posted a great set of pics showing his cleanout, but I can't seem to find them. I posted this, which shows what happens if you're not carefully about removing the resistor, and also shows the debris I had in mine (also pine needles) and how to refresh your HVAC system: https://www.tundras.com/posts/3126837/
    DarkMint, Zach_795[OP] and bmf4069 like this.
  5. Jul 16, 2024 at 4:53 PM
    luxury4play
    luxury4play New Member
    Pull the fan and check for trash. It may be the motors brushes causing the notice also
    Zach_795[OP] likes this.
  6. Jul 18, 2024 at 1:55 PM
    Zach_795
    Just got finished taking the fan out. There was a pretty stout helicopter type leaf stuck in the blades. Pulled that out then blew all the dust off the fan with a compressor. Then I took a wet rag and wiped down everything up in the vent hole as far as I could reach. Good as new. :thumbsup:
  7. Jul 18, 2024 at 3:54 PM
    teereqs
    teereqs New Member
    Love an easy fix!
  8. Jul 18, 2024 at 5:32 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I have had this issue fo the last two years. I just turn up the radio. :lalala:
  9. Jul 18, 2024 at 5:57 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    BINGO ^^^. I like to suggest Led Zeppelin's: How The West Was Won live album.
  10. Jul 19, 2024 at 7:53 AM
    Zach_795
    Zeppelin 2 or physical graffiti never misses
    Jack McCarthy likes this.
