[Solved] Popping or sucking sound after spark plug and coil change
Discussion in '1st Gen Tundras (2000-2006)' started by 2000TundraKid, Mar 20, 2024.
  1. Mar 20, 2024 at 3:05 PM
    2000TundraKid
    2000TundraKid [OP] New Member
    2000 AC SR5 4.7 V8 2WD
    Grill Guard and 16" 398 Vision Manx Competition
    Hello again, I replaced all my coil packs and spark plugs today and the process went well for the most part. I went through one coil and plug at a time and after installing made sure everything was tight and secure, I bought TRQ brand coil packs ( and spark plugs from 1a auto. Bought my struts alternator and couple other things from there and they seemed like a pretty good website to get my parts. My coils I can't tell if they were too bad but I wanted to get them all new since it's been a bit since I last changed them. (I have a bad habit of not keeping track when I replace stuff) and for my spark plugs they all seemed pretty dark. Long story short after changing everything I started it up and it turned over pretty nicely and seemed to idle fine, I let it warm up and then took it around the block. But once I got back and got out I noticed this subtle popping sound which started to get a bit louder. It's only coming from the driver side for the most I can tell and I haven't gotten any check engine light yet. I noticed the plugs should be gapped to 0.33 after looking around and used a tool where I can measure the gap and set it. The ones I replaced were well over 0.45. I didn't unplug the battery since online a majority said you don't need to but I only saw one say you have to because you're dealing with high voltage, also I don't remember doing it in the past. Just need some help dialing what I may have screwed up? Thanks
    Sound in Question: https://www.youtube.com/shorts/UswLEPVgPms
    Coil pack 1 of 2
    Coil pack 2 of 2
    Spark plugs
  2. Mar 20, 2024 at 4:41 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sounds exactly like a vacuum line disconnected. Look it over again.
    2000TundraKid[OP] likes this.
  3. Mar 20, 2024 at 5:01 PM
    Your EVAP line to the charcoal canister (black box next to brake MC) is disco'd.
  4. Mar 20, 2024 at 5:05 PM
  5. Mar 20, 2024 at 5:14 PM
    2000TundraKid
    Oh damn I moved all those lines and crap to the side as well, this thing here? 20240320_171402.jpg
  6. Mar 20, 2024 at 5:16 PM
    2000TundraKid
    Thanks you guys, is it just a simple plug back in?
    Jack McCarthy likes this.
  7. Mar 20, 2024 at 5:18 PM
    Jack McCarthy
    Bill
    North of Boston
    Unless it goes on loosely because it’s too stretched out, but yes. If loose, you may want to secure it better or buy replacement hose.
  8. Mar 20, 2024 at 5:20 PM
    2000TundraKid
    I've got some zip ties if that's better than nothing lol it did easily just slide on
    FishNinja likes this.
  9. Mar 20, 2024 at 5:22 PM
    Jack McCarthy
    Bill
    North of Boston
    You may want to look into replacing the hoses at some point. If it slid off by itself, it’ll do it again.
  10. Mar 20, 2024 at 5:54 PM
    2000TundraKid
    yeah ill definitely look into it. all my hoses have seen better days but gonna add it to my list of stuff to replace. *cough* carrier bearing *cough cough* lower.. ball joints :goingcrazy:
    BroHon and Jack McCarthy[QUOTED] like this.
  11. Mar 20, 2024 at 6:16 PM
    Chances are the carrier isn't bad. But that's just my humble opinion. If rubber isn't torn, look at the U-joints before the carrier.
  12. Mar 21, 2024 at 7:34 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    zipties4lyfe
  13. Mar 22, 2024 at 4:14 PM
    2000TundraKid
    I would say its far from torn lol
  14. Mar 22, 2024 at 4:59 PM
    Oh yeah, that there's seen more action than a $2 hooker.
  15. Mar 22, 2024 at 6:20 PM
    2000TundraKid
    About that, I took it into midas a couple months back and they noted it during an inspection and a guy who owned an older tacoma said their tranny went out because of the carrier bearing being blown how true is that, I've heard it can cause the driveshaft to seize but destroying the transmission
  16. Mar 22, 2024 at 6:23 PM
    Transmissions are one of those things I just provide a lot of quality insight on. I'm not sure I buy into a carrier killing a tranny, but I also can't help but think it depends a lot on the transmission. I can't imagine, say, a carrier bearing killing an old 4spd Muncie, for example. But I could see it killing a shitty Nissan CVT transmission. Then again, a fart bubble would probably kill a Nissan CVT, when you consider a couple dozen K miles of normal operation will kill it.
  17. Mar 22, 2024 at 6:38 PM
    2000TundraKid
    Noted, my transmissions been pretty solid with it so far but not gonna leave it unattended. Got a couple recordings of it while im driving and it does move forward, backward slightly and bounce around quite a bit, two hands I can push the driveline up about an inch and I get a clunk sometimes when going into reverse but no shifting problems out of the tranny which is a relief. Pretty tough truck
  18. Mar 22, 2024 at 6:48 PM
    2000TundraKid
  19. Mar 22, 2024 at 6:58 PM
    I have about 1/4"-3/8" of play in mine in both directions and it's in pretty mint condition. Some play is normal.
    But with how torn up the rubbers are on that joker, you should replace it. Go with a Dana/Spicer replacement only. Be sure to clock your driveshaft correctly, mark before removal.
