Sound deadening my 18' Tundra Crewmax Cab EVERYWHERE. need to do
Discussion in 'Audio & Video' started by OhEmmBee, Oct 12, 2020.
  1. Oct 12, 2020 at 8:16 AM
    OhEmmBee
    OhEmmBee [OP] Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    I'm sound deadening the floor and the head liner soon and hoping maybe anyone here can pitch any advices on how to do it. I did my door panels and need to do the rest. Any advice or tricks to get the headliner and floor liner is greatly appreciated!
  2. Oct 13, 2020 at 3:00 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I sound deadened the floor in my 2018 CM. Doing the ceiling seemed to invasive to me at the time and I knew it really wouldn't help much with the audio sound much, so declined to do it. Regarding the floor, however, remove all seats, remove center console, remove carpet, remove rear foam blocks, in that order. No tricks that I know of. Just removing shit, laying deadener down, and rolling it out. To be perfectly honest, doing the entire floor is a bit overkill for audio. Most important are all 4 doors, rear wall and floor area behind rear seat (in case you are installing a sub box). I can understand doing the roof IF, you are trying to help insulate against heat, but do not think sound deadener is a good insulator for that purpose.
    OhEmmBee[OP] likes this.
  3. Oct 13, 2020 at 3:15 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    OhEmmBee[OP] and rockmup like this.
  4. Oct 13, 2020 at 12:33 PM
    OhEmmBee
    OhEmmBee [OP] Rick
    Richard
    Denver
    Just lined part of the floor from the back moving to the front. Doing the front and and firewall next and hoping for the best. Is it just heat that it insulates or also the cold?
  5. Oct 13, 2020 at 1:48 PM
    preacher35
    Well, I live in Texas. So cold is never really an issue. Regardless, I do not think sound deadened is a good insulator for heat and/or cold. But, if that is what you are looking for, there are other alternatives as I have seen it discussed here on tundras.com.
  6. Oct 13, 2020 at 2:31 PM
    Tundyfundy
    Bay Area, CA
    Correct, if you look at the post I linked above you’ll see an additional product that is a heat/cold barrier. I love it and it also helps deaden additional sound.
  7. Oct 13, 2020 at 5:45 PM
    OhEmmBee
    OhEmmBee [OP] Rick
    Richard
    Denver
    Great! Two in one is little better. I was hoping to do something like that and maybe insulate the doors as well while I’m at it. Anything worth sound deadening on the outside?
  8. Oct 13, 2020 at 5:49 PM
    Tundyfundy
    Bay Area, CA
    Eh not really IMO. I love the sound of my engine and exhaust but I believe you can deaden the hood underneath the firewall mat with most products if wanted.
    OhEmmBee[QUOTED][OP] likes this.
  9. Oct 13, 2020 at 5:54 PM
    OhEmmBee
    OhEmmBee [OP] Rick
    Richard
    Denver
    I can still hear most of my engine and the road. I like to hear my engine and exhaust when I got my windows rolled down but when the windows are up it’s really for my tunes. Other than that, I’ll take that into consideration once I change my exhaust later down the road. I hear some people recommended doing the wheel well but don’t know how reliable the adhesive will still if I ad it on there.
  10. Oct 13, 2020 at 6:04 PM
    Tundyfundy
    Bay Area, CA
    The product I used had a specification and said where you could use it. It said indoor use and under hood. I’m sure you could verify when the time comes!
  11. Oct 27, 2020 at 9:45 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    For sound deadening I rap the area with my knuckle. If it has a hollow reverb type of sound I apply it. Usually large flat areas could use a strip or 2 to stiffen it up Places where there are bends in the sheetmetal are usually ok; sometimes not though.
    Tundyfundy likes this.
