SPACER LIFT TO COILOVERS?
Discussion in 'Suspension' started by nappyboy94, Aug 10, 2020.
  1. Aug 10, 2020 at 7:49 AM
    nappyboy94
    nappyboy94 [OP] New Member
    Tanner
    2010 Toyota Tundra
    Has anyone gone from a 7" PRO COMP (or any brand really) spacer lift to a coil over lift? I'm wanting to trade out my spacer lift and get a decent set of Coil overs, but i'm unsure the route to take. Do I need to match the coil over size to my 7" lift I have? I can only find 3-6 inch coils and if I do something smaller will everything I have like my steering knuckles and be compatible? My front strut continues to cut a key hole style slit into my 7" spacer in the front on the driver side, ive replaced 3 times so I want to just do it the right way. Any advice would be highly appreciated thanks in advance!
  2. Aug 10, 2020 at 7:52 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    What 7” do you have? The manufacturer probably has a coilover upgrade option
  3. Aug 10, 2020 at 7:52 AM
    nappyboy94
    Tanner
    2010 Toyota Tundra
    PRO COMP, probably should have specified sorry guys haha
  4. Aug 10, 2020 at 7:59 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Most company’s make a coilover to your spec. Call for example king,fox,icon as they can custom build one just for your specs. Sometimes they already have the measurements and other times they will ask you to give them the measurements
  5. Aug 10, 2020 at 8:02 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Pro Comp offers a 6" coilover. Then you make up the difference with some Coachbuilder shims.
  6. Aug 10, 2020 at 8:02 AM
    nappyboy94
    Tanner
    2010 Toyota Tundra
    I'm sure a custom build might be a little more coin, or maybe not? Just was looking for a reasonably priced option since I don't do to much do a whole lot of gnarly things in my truck haha but every time the strut rod cuts the spacer it throws my alignment out and my tires wear that much faster and those buggers are expensive ;( but ya I guess I could go the custom route
  7. Aug 10, 2020 at 9:28 AM
    ninjajay
    Spoolston, TX
    Or as mentioned above check with Pro Comp, they will probably be your best bet cost wise. I suspect you’re already well aware of the cost of cheaping out by now.
  8. Aug 10, 2020 at 9:31 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    You would be surprised. They aren’t much more then a regular pre made coilover
