Spanner Wrench or NO
Discussion in 'Suspension' started by bamelanc, Aug 28, 2021.
  1. Aug 28, 2021 at 6:10 PM
    bamelanc
    bamelanc [OP] New Member
    Orange, Texas
    2018 Magnetic Grey Platinum 4x4
    Addictive Desert Designs Stealth Fighter bumper w/ 40" Baja Designs Onyx6 arced dual control combo light bar and Smittybuilt X20 Comp 10k winch. Baja Designs S8 10" amber fog lights. sPod Control for lighting and compressor. ICON Stage 3 Suspension with tubular UCA set at 3". ICON Alloys Six Speed 17" machined/satin black wrapped in 285/75/17 Nitto Ridge Grapplers. TRD Performance Intake. TRD Cat Back Exhaust. LED Kit inside and out. ARB onboard compressor. Amp Research Power Step w/LED kit. Retrax XR Pro bedcover. Armadillo Bed Liner. Tint - 35/5/5 ceramic. Center Console Safe. Weather tech mats.
    Can you make adjustments to the coil adjuster nut on coilovers without a spanner wrench? Is there a tool that will substitute for one?
    Thanks
  2. Aug 28, 2021 at 7:48 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    A punch works best, a screw driver works too but since the head is rounded off you can more penetration with a flattened end :D I've used a spanner like once to adjust shocks, 9/10 times you can't fit it without totally removing the shock from the vehicle. Closest sized punch (or cut the tip off a screw driver), maybe cut down to fit in there easier, is your best bet.
    And maybe you know this already, but if you're adjusting while on the truck, jack it up so no weight is on the shock, and spray the threads and collars with lube so they/the spring can rotate easier. A hammer hitting the side of the punch can go a long ways too.
