Spare Tire Hoist/Carrier Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by SOB, Nov 20, 2020.
  1. Nov 20, 2020 at 5:51 AM
    SOB
    SOB [OP] Big Member
    Ohio
    2013 Red Crew Max Platinum
    I recently had a flat tire and couldn’t get the spare tire lowered. The underside of my truck is pretty rusty thanks to living it’s entire life in Canada and Ohio. I needed a new set of tires anyways so I had it towed and replaced all the tread. However it would be good to be able to use the spare. Tire shop said they couldn’t get the hoist busted loose either. I’m guessing I need to cut the chain to drop the spare then replace the mechanism. Has anyone done this and have any guidance or advice?
    Thanks!
  2. Nov 20, 2020 at 5:55 AM
    timsp8
    NY
    Did you or the tire shop try to spray it all down with some pb blaster or anything? I’d say that’s worth a shot before trying to replace the whole thing and shouldn’t cost much or take a lot of time.
    If not, look through an online parts catalog for it and see if it looks replaceable. I’ve never seen or heard of it being done, but I’m sure it is.
  3. Nov 20, 2020 at 5:57 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You should be able to hit a used part supplier or pick-and-pull yard for something like that and likely a lot cheaper than buying a new one. Anything 2007 or newer will have the same hoist setup.
  4. Nov 20, 2020 at 10:33 AM
    SOB
    SOB [OP] Big Member
    Ohio
    The tire shop supposedly did hit it with penetrating fluid. I haven’t looked at it myself yet but when I replaced the rear shocks I had to cut the nuts out because everything is super corroded. Blaster and my little propane torch have come up short on a few occasions w this truck.
    A new OEM part is about $100 so it won’t break the bank. I’ve read threads in a 4RUN forum where folks replaced theirs. I’m sure it’s doable and probably just a few bolts. Once you cut the chain to get the tire out. Maybe I’ll take pics and do a little write up if/when I replace mine.
    Oh, and the parts diagram on Cool Springs Toyota website just shows it sitting off to the side and not connected to anything. Not much help...
  5. Dec 3, 2020 at 9:39 AM
    SOB
    SOB [OP] Big Member
    Ohio
    Here’s a few pics of the carrier. I don’t think PB is gonna help :(
    B73AD8E3-65B4-441D-8993-5F958B7542AD.jpg 02ED39BE-E799-4E2C-A398-8136177226EF.jpg 600ABF7B-9EE4-4252-9617-A32846BAB6FB.jpg
  6. Nov 2, 2021 at 6:45 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Ever replace yours? I’m running into the same issue.
  7. Nov 2, 2021 at 10:07 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    my 07 is a Steel cable , kept wondering why people were calling them chains..
    it shouldn't be to hard to replace if I recall correctly it was held on by a few bolts to the brace assembly when I removed my dry rotted spare.
    -but definitely hit it in both the chain hole and tool insert with some lube for a couple days then try tighting then untighting (raising / lowering it) and see if it breaks free.-
    just looked closer at pictures definitely crusty. Would recommend the enclosed steel cable one for the replacement.
    can use marine grease on the cable or use a good lube of some sort an service it periodically, it will keep rust free.
    pictures grabbed from ebay
  8. Nov 3, 2021 at 3:52 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Don’t those bolts go through or under the bed so you don’t have access to them? Maybe they can be reused but the state of rust might not allow it.
  9. Nov 3, 2021 at 11:14 AM
    NueveTundra
    Planet Earth
    they bolt to the x brace thats part of/ mounted to the chassis should be a couple inches between the top of the brace and bottom of the bed.
    Medic343 likes this.
  10. Nov 3, 2021 at 11:18 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I've replaced the spare tire hoist and it wasn't bad at all. 4, 10mm bolts hold it in place on a brace that's bolted to the bottom side of the bed. The spacing is a little tight but it can be done. Took me probably 30 minutes total and like you said just under $100 for the OEM replacement.
  11. Nov 3, 2021 at 11:35 AM
    DavidinMA
    DavidinMA New Member
    2007 Tundra Limited
    I ordered a new one yesterday for my 07, that has a cable. I also ordered the frame cross member, which is badly rotten. The frame rails looks okay, oddly enough.
  12. Nov 30, 2021 at 2:32 PM
    cptjnz
    cptjnz New Member
    Hey all...brand new to forum and am having issue finding part number for replacement spare tire hoist for my 2008 Crewmax. I too have the one with the braided cable...not the chain. Mine actually looks exactly like the hoist in post #7 by Nueve. Any guidance would be greatly appreciated!
  13. Nov 30, 2021 at 2:46 PM
    NueveTundra
    Planet Earth
    it's one of these parts numbers both have the same diagram of chain but neither say what's different, google search of the numbers show the cable style, but at the same time haven't verified witch is witch. the 2000-2006 Tundra comes up close with cable diagram on 519000C060 part number. hope this helps some or gets you in the right direction. I know there's a guy here whos a master at finding parts but I can't remember his name at the moment. @cptjnz
  14. Nov 30, 2021 at 2:57 PM
    NueveTundra
    Planet Earth
    okay I dug some more and got it is the 5190009000 part number for cable style for the 2nd gen Tundra's
  15. Dec 7, 2021 at 4:37 PM
    SAM999990
    SAM999990 New Member
    Sam
    2014 tundra crewmax
    I'm in same situation. Spare tire winch seized up due to rust. People having trouble removing spare tire. Here is my solution until winch knocked free with PB blaster or replaced. Let some air or as much air out of spare tire as you can to create a little wiggle room between tire and frame above. Hopefully tire valve is facing down. Use a crow bar to knock bracket holding tire up loose from tire wheel and tire will drop down to ground. This will give you much better access to spare tire carrier winch to try and free winch or replace entire assembly.
    Hope this helps.
