spare tire hoist relocated
Discussion in 'General Tundra Discussion' started by Rica25, Sep 17, 2019.
  1. Sep 17, 2019 at 8:26 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    has anyone relocated the hoist or moved over the hoist to have more clearance for the spare tire to not have rubbing issues with the shackles?
  2. Sep 17, 2019 at 8:30 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Still having issues ? :notsure:
  3. Sep 17, 2019 at 8:33 PM
    Rica25
    Ricardo
    Tulare
    yes i ended up removing the tire for now i would rather relocated if it is simple instead of loosing bed space
  4. Sep 17, 2019 at 10:30 PM
    TheBeast The Beach
    best bet is to use slimmer shackles (TC, MCM,..) if you wanna keep full size under the bed imo.
  5. Sep 18, 2019 at 3:52 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    How big of a tire can we put in as spare?
    Rica25[OP] likes this.
  6. Sep 18, 2019 at 5:11 AM
    coTony
    Tony
    Montrose, CO
    The upgraded shackles are bought and installed for a purpose. Replacing them for a spare tire is not an option in my opinion. Try something to push the tire away from the rear bumper similar to the stock "metal tire guide" that had to be removed for the 35".
    I need to do this myself still. I have my hand in a cast, arthritis ate cartilage between a joint caused from an old injury. Once I am back in the ring for the fight I will be looking at this
    texasrho83 and Rica25[OP] like this.
  7. Sep 18, 2019 at 5:27 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    If you remove the spare tire guide tabs you can fit a 35 in there. It's tight, but it'll fit.
  8. Sep 18, 2019 at 5:29 AM
    coTony
    Tony
    Montrose, CO
    Exactly what we are discussing. When you remove the tire guide and have shackles like Coachbuilder shackles and you put a true 35" tire under the tire will rub the shackles
  9. Sep 18, 2019 at 5:57 AM
    Rica25
    Ricardo
    Tulare
    Yes that's the shackles that I have so now it runs so I'm going to try and relocate the hoist about and inch over to the passenger side but I wanted to see if anyone had done it and if it was simple
  10. Sep 18, 2019 at 6:02 AM
    Rubberdown
    Uh huh. Isn’t there a wee hole you have to put that long bar through to crank it down? IF you can move the hoist, your going to have to deal with all of that too. I’d imagine it’s easier to buy thinner steel shackles and be done with it. No need for billet aluminum unless it makes you feel better.
    What about taking a piece of steel in place to keep your tire from sliding over?
    NewImprovedRon and Rica25[OP] like this.
  11. Sep 18, 2019 at 6:04 AM
    Rica25
    Ricardo
    Tulare
    Moving it to passenger side only ......not moving it up towards the engine bay so that should not be a problem
  12. Sep 18, 2019 at 6:05 AM
    Rica25
    Ricardo
    Tulare
    Only need about about half inch to 1 inch max to the passenger side
  13. Sep 18, 2019 at 6:06 AM
    15whtrd
    15whtrd Mr. Blonde
    Weren’t you working on something to see if you could just keep it pushed forward?
    Rica25[QUOTED][OP] likes this.
  14. Sep 18, 2019 at 6:08 AM
    Rica25
    Ricardo
    Tulare
    Did not work it is to big of a rubber piece and to hard to make the whole to mount to the frame behind license plate
    15whtrd[QUOTED] likes this.
  15. Sep 18, 2019 at 6:13 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I have a full-sized 35" spare using my old Fuel Assault rims. And even if I cut the tabs off, I can't get the tire in the spare holder area because the rims are such that the device that takes it up to the space won't get level or stable enough to stay, so it's in the bed of the truck...
  16. Sep 18, 2019 at 6:46 AM
    Sas
    OKC, OK
    Maybe take a look at MCM Fab's shackles? Those are the ones I'm using.
    TheBeast and Rica25[OP] like this.
  17. Sep 18, 2019 at 6:58 AM
    Rica25
    Ricardo
    Tulare
    It should not be that big of a difference the hole underneath tailgate has wiggle room
  18. Sep 18, 2019 at 6:59 AM
    Rica25
    Ricardo
    Tulare
    Not going to spend more money on shackels it's cheaper to relocate hoist or buy straps to mount tire on bed
  19. Sep 18, 2019 at 7:03 AM
    coTony
    Tony
    Montrose, CO
    I did not see any place on their site that sells only the shackles. I am not a fan of buying these expensive upgrades only to sell them to someone at a discounted price so I can buy yet another upgrade. In any event I did not see where to buy
  20. Sep 18, 2019 at 10:45 AM
    TheBeast The Beach
    you can fit a 35" there with slim shackles like the MCM. The CB while great are way overbuilt.
    myself I have a 295/70/18 there with guides removed and MCM chackles. I still have some space left and could go up to 35"
  21. Sep 18, 2019 at 10:47 AM
    TheBeast The Beach
    and post exhaust chop. shows the clearance.
    Sas, Rica25[OP] and Pinay like this.
  22. Sep 18, 2019 at 10:49 AM
    TheBeast The Beach
    tire in the bed defeats the purpose of a truck unless it is a race dedicated truck.
    AggiePhil, Rica25[OP] and Pinay like this.
  23. Sep 18, 2019 at 10:50 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I can't get my spare balanced on enough to get in the holding area...
  24. Oct 18, 2023 at 8:36 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    This is confirmed by me today. 100% will touch without any way to make it not. Unless you are able to re-locate the tire mount its not happening.
