Spare tire size.
Discussion in 'Wheels & Tires' started by Gordo79, Jul 19, 2021.
  1. Jul 19, 2021 at 9:07 AM
    Gordo79
    Gordo79 [OP] New Member
    2019 Tundra 5.7.
    I recently went from a P275/55R20 stock wheel and tire to a P275/60R20 Cooper Discoverer AT3 4S. Is there any reason to replace the spare with a P275/60R20 ? I’ve heard there’s no need to change spare size since one would be used only to get to a tire shop. On the other hand I’ve read that it could possible damage the differential. Folks run donuts on cars ? Seems about the same to me. Any input would be appreciated. Thanks
  2. Jul 19, 2021 at 9:19 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    You went from 632 revolutions per mile to 612 revolutions per mile. Just use the spare on the front without FWD engaged if you have it.
    snivilous and Gordo79[OP] like this.
  3. Jul 24, 2021 at 7:03 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Can we fit a R20 series tire in the same spot on the truck?
  4. Jul 24, 2021 at 8:54 PM
    Lutefisky
    Lutefisky 2021 TRD Sport Crewmax 4x4
    This is what I've been thinking about too. My next mod will be different rims and tires (than stock) and wondering if I can put a larger tire on the spare rim under the bed. Would like to have something the same size as the other tires to prevent any damage.
    IsaiahCanada likes this.
  5. Jul 25, 2021 at 5:02 AM
    biebs96
    PA
    yes you can. I have a 285/75 (35") on my stock steel spare wheel, and it tucks up under the bed nicely.
    Lutefisky[QUOTED] likes this.
  6. Jul 25, 2021 at 8:37 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I have a spare 295/70 R18 on the spare metal rim. The diameter is a little over 34”. I had to modify the mount for the two retaining brackets to make it fit properly. Some remove completely and some bend these brackets, but I cut out the inner most rivets and added 1/2 spacers with new bolts to tilt them back enough for the tire to fit.
  7. Jul 25, 2021 at 11:47 AM
    Lutefisky
    Thanks for the replies! This really helps....now to decide if I want to stay with 20's or go to 18's....
  8. Jul 25, 2021 at 11:56 AM
    biebs96
    PA
    you could always find the comparable size in an 18 for the spare, if you go with 20 for the truck.
  9. Jul 25, 2021 at 11:58 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It'll be fine, your differential is meant to make up the size difference and worst case run it on the front. I wouldn't think twice about swapping my stock spare onto the rear and I have 35s.
