Spark plug deposits
Discussion in '2nd Gen Tundras (2007-2013)' started by Rodion, Nov 15, 2020.
  1. Nov 15, 2020 at 8:08 PM
    Rodion
    Rodion [OP] New Member
    Rodion
    2010 Tundra 4.6L V8 4x4
    Greetings!
    Hey, does anyone have an idea what can cause such deposits (see the pic). I have the similar situation with spark plugs of #1,3,& 5th cylinders (I sometimes have a misfire at the cold start on those, P0301,3,5).
    All the spark plugs are a half-year-old (4,000 miles used)
    Denso (3421) SK20HR11 Iridium as per spec.
    Also, FYI, yesterday, I did a compression test, and all the cylinders showed from 165 to 177 PSI which is totally good per spec.
    Thanks
  2. Nov 15, 2020 at 8:16 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Spark plug part number?
  3. Nov 15, 2020 at 8:22 PM
    Rodion
    Rodion
    Denso (3421) SK20HR11 Iridium (per spec)
    Newly installed 6 months ago or 4,000 miles ago.
  4. Nov 15, 2020 at 8:22 PM
    ZPMAN
    Minnesota
    Do you have a specific place you fuel at all the time?
  5. Nov 15, 2020 at 8:25 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Where do you live?
  6. Nov 15, 2020 at 8:26 PM
    Rodion
    Rodion
    SF Bay Area, CA
  7. Nov 15, 2020 at 8:27 PM
    Rodion
    Rodion
    Mostly at Costco. Interesting why it impacts only 3 cylinders.
  8. Nov 15, 2020 at 8:27 PM
    ZPMAN
    Minnesota
    Maybe a little salt deposits?
  9. Nov 15, 2020 at 8:30 PM
    Rodion
    Rodion
    I replaced those spark plugs, so I'll try to scrab the stuff and see if it will dissolve in the water?! Or will go down...
  10. Nov 15, 2020 at 8:31 PM
    Rodion
    Rodion
    Which place are you comfortable to fuel up with?
  11. Nov 15, 2020 at 8:32 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    The pics look like ash to me. Do you have any oil consumption issues?
  12. Nov 15, 2020 at 8:34 PM
    ZPMAN
    Minnesota
    BP 93 octane non ox if possible otherwise 91 non ox.
  13. Nov 15, 2020 at 8:34 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I think costco is rated top tier, just curious whose additive packets they use.
    FundraTRD likes this.
  14. Nov 15, 2020 at 8:36 PM
    Rodion
    Rodion
    It does not really look like ash to me from a closer look, plus I'm not sure I have an oil consumption issue... The level is good, I don't have a blue-ish smoke from the exhaust... Although, I started to notice a gasoline smell from the oil fill cap.
  15. Nov 15, 2020 at 8:36 PM
    Rodion
    Rodion
    Copy
  16. Nov 15, 2020 at 8:41 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I'd send a oil sample to Blackstone for a quick check-up.
    Compression done on cold or hot engine?
    Lot of short trips?
    Engine reach OP temp regularly?
    Black Wolf likes this.
  17. Nov 15, 2020 at 8:43 PM
    ZPMAN
    Minnesota
  18. Nov 15, 2020 at 8:46 PM
    Rodion
    Rodion
    On hot engine!
  19. Nov 15, 2020 at 8:47 PM
    Rodion
    Rodion
    The majority of trips are long-distance (~200 miles one way).
  20. Nov 15, 2020 at 8:47 PM
    Rodion
    Rodion
    Yes!
  21. Nov 15, 2020 at 8:48 PM
    Rodion
    Rodion
  22. Nov 15, 2020 at 8:49 PM
    Rodion
    Rodion
    Will try to do it!
  23. Nov 15, 2020 at 8:49 PM
    ZPMAN
    Minnesota
    Were the plugs tight when they came out?
  24. Nov 15, 2020 at 8:51 PM
    Rodion
    Rodion
    Hard to say... Could they loosen up? I mean, I did tighten them myself to 15 ft-lbs 6 month ago.
    I don't believe they were loose yesterday when I removed.
  25. Nov 15, 2020 at 11:15 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Are those internet plugs from a reliable source? There have been a lot of issues from internet sales of plugs being fake plugs, look a likes made from inferior material and causing missing problems. Did you change them for time/wear or did you have the missing issue before you changed them? Toyotas are very fussy about plugs. I don't know if you know this or not but worth mentioning anyway. Go strictly by the number in your owners manual. Do not use a cross reference plug. If the store does not have either the right Denso, or the right NGK number go to another store and get the exact plug number or you will more than likely have miss fire issues. You may be savoy about Toyota and Sparkplugs but just throwing this out there for anyone else trying to get a good deal on the internet and end up getting a inferior plug. They look good on the outside, and they even come in stock manufacture boxes. So don't get fooled by price.
    TheBeast likes this.
  26. Nov 16, 2020 at 4:11 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Plug looks like some images I've seen for lean AFR conditions. And it's happening to multiple cylinders on one side of your engine... possibly a fuel pressure issue.
    14burrito likes this.
  27. Nov 16, 2020 at 5:21 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    This will solve the problem and a host of others too. It is far more cost effective than any other fuel treatment out there, meant for boats but I use it on all my engines. It decarbonizes, stops the breakdown of methanol and allows the engine to burn fuel hotter to get rid of those deposits. Luck.
    https://www.amazon.com/Star-Tron-En...id=1605532716&sprefix=startron,aps,240&sr=8-6
  28. Nov 16, 2020 at 5:28 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I concur. :thumbsup:
    The misfire codes are due to another cause. There's not enough deposits on that plug to keep it from firing. Sparkplugs typically will get some deposits, we just don't take them out every 5K miles to see them.
    Filthyphil and hagrid[QUOTED] like this.
  29. Nov 16, 2020 at 6:58 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Very possibly especially since its bank specific. Good thinking.
    If the OP has a scan tool he can check fuel trims and compare.
    hagrid[QUOTED] likes this.
  30. Nov 16, 2020 at 9:58 AM
    Rodion
    Rodion
    Thanks, I believe I purchased those as per spec from auto zone, and installed when I just got the truck 6 months ago.
