Spark plug gap discrepancy between manual and pre-gap.
Discussion in '2nd Gen Tundras (2007-2013)' started by TJB 2010 Tundra TRD, Dec 8, 2024.
  1. Dec 8, 2024 at 9:23 AM
    TJB 2010 Tundra TRD
    TJB 2010 Tundra TRD [OP] New Member
    2010 Tundra 4.6L SR5 TRD 4x4
    My new spark plugs, Denso Iridium SK20HR11, are pre-gapped at 0.037". My manual calls for a 0.043" gap. Should I re-gap the spark plugs or leave them since they are iridium?
  2. Dec 8, 2024 at 9:32 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Where’d you buy them from?
  3. Dec 8, 2024 at 9:35 AM
    joseph_womack
    Joe
    Louisiana
    This is from AllData
  4. Dec 8, 2024 at 9:44 AM
    TJB 2010 Tundra TRD
    Bought from an auto parts dealer on eBay. They're definitely genuine parts and from a US dealer.
  5. Dec 8, 2024 at 9:46 AM
    joseph_womack
    Joe
    Louisiana
    I don’t believe that one bit, as someone who is a mechanic I wouldn’t trust those but you do you
    seen it happen way too many times
    fixnfly and blenton like this.
  6. Dec 8, 2024 at 10:06 AM
    centex
    centex New Member
    Perfect world you want the largest gap possible without the spark blowing out to expose as much flame front as possible for maximum combustion.
    Real world, .002” aint going to make a hill of beans difference. I’d run em.
    joseph_womack likes this.
  7. Dec 8, 2024 at 10:35 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    First. This ^^^.
    Second. OP: adjust the gap closer to 1.1mm.
    I have bought 3 sets of these Denso Iridiums. Two from a Toyota dealer and one from an authorized Denso reseller, Advance Auto Parts. Not one plug out of those twenty-four needed to be regapped. Everyone was spot on.
    If it was me, and I was getting this feedback, I wouldn't dick around and would spend the $70-$80 and source them from an absolutely 100% reliable source. Such as the two I mention.
    Also, search around this forum. There's a thread somewhere from about 3/4 years ago where the physical differences in the plug box and the plug itself are shown (photos) for the counterfeits.
  8. Dec 8, 2024 at 10:46 AM
    joseph_womack
    Joe
    Louisiana
    I just did my spark plugs, I bought OEM straight from Toyota cause I wanted the quality, I could’ve bought Denso through Oreillys or advanced or where ever, but I wasn’t happy with the way the Denso non oem looked. I did get I think 2 spark plugs from Toyota where the gap looked a little funky and I just had them swap them out
  9. Dec 8, 2024 at 3:02 PM
    blenton
    blenton New Member
    I am one of those people who received counterfeit plugs and didn’t know it until I pulled them and inspected more closely. Long story short, I purchased them from Amazon - not a reseller on Amazon, but Amazon itself, hoping that it would lend legitimacy to the parts. Price was a few dollars cheaper per plug than the dealer, so no alarms went off. My dealer wants ripoff prices compared even to local parts stores. I installed them at 120k-ish and noticed no change in idle or mileage. In other words, they were no better than the worn factory plugs with 120k miles on them. I attributed it to the miles and weight of the vehicle.
    Shortly thereafter, I starting getting what felt like a slight miss at idle, but it didn't trip a CEL and it was very intermittent. So I attributed it to poor quality fuel and started using a different gas station and occasionally higher octane fuel (I was still using Regular unleaded at the time, which I don't recommend to anyone, but that's another discussion). The miss was still intermittently there and my mileage slowly decline a little bit - which I again attributed to more aggressive tires and more weight in the truck.
    After 60k miles, I wised up and purchased another set of new plugs from a dealer when they were on sale. I decided to swap them just because I was doing a slew of other maintenance. Mileage jumped 2-3 MPG, idle was smooth and silk, and the truck ran better than it had in years. So I inspected the plugs.
    Plug gaps were all over the place. Comparing printing on the plug bodies, colors were a bit off, inking wasn't consistent, layout varied a scoche - all the tell tale signs of counterfeits. Then I found this plug:
    Hint - look VERY closely at the electrode.. So I swore off Amazon and eBay car parts, even if from what appears to be a reputable source. Same goes for tools like Milwaukee: I got several very good knockoff m18 batteries that looks 99.9% legit. They almost fooled me but I could tell the difference and noted as much. I'm guessing the average homeowner would have no idea.
    joseph_womack, WILLINH and 1lowlife like this.
  10. Dec 8, 2024 at 3:16 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    And here's what the plugs should look like when they come out of the 3UR. Or close thereto.
  11. Dec 10, 2024 at 4:19 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Gap to your preference & install...
  12. Dec 10, 2024 at 5:12 AM
    smokint
    smokint New Member
    Buy the real deal, my friend
    Cruiserpilot and joseph_womack like this.
  13. Dec 14, 2024 at 7:27 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That’s the proper Toyota part number for plugs then. Curious as a friend thought 5.7 and 4.7 use same plug. Is this true?
  14. Dec 14, 2024 at 8:15 PM
    joseph_womack
    Joe
    Louisiana
    I know both are iridium’s, but I honestly can’t remember the p/n, very well could be the same
  15. Dec 14, 2024 at 8:25 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I’ve checked. Definitely different.
    AZBoatHauler likes this.
