Spark Plug Recommendations
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, Feb 8, 2023.
  1. Feb 8, 2023 at 10:46 AM
    brandostundra
    brandostundra [OP] New Member
    Looking to replace the stock spark plugs soon on my 2016 Tundra 5.7
    what is currently the best plug out there
    Moe2o4 likes this.
  2. Feb 8, 2023 at 10:48 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    OEM!!!!
  3. Feb 8, 2023 at 10:49 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    OEM Denso (or I like NGK for anything) but BUY FROM A REPUTABLE SOURCE, I got fake OEM tundra plugs on ebay once. Should have known the price was too good to be true, they eroded in 10k miles and started causing misfire faults. Replaced with OEM from RockAuto and no issues many more thousands later.
  4. Feb 8, 2023 at 11:03 AM
    AZBoatHauler
    So.Arizona
    IMO, This is the only acceptable response.
  5. Feb 8, 2023 at 11:06 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I got non OEM (NGK 94122 LFR6AHX-S Ruthenium HX Plug) from Rockauto and have had no problems in the last 4 years. The only reason I got those was because my wife's name is Ruth and I thought it was amusing. OEM are probably just as good.
  6. Feb 8, 2023 at 11:27 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
  7. Feb 8, 2023 at 11:38 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    OEM from a trusted source. If you go with Denso here's what the box looks like along with the plug# for the 5.7 liter. Denso has a list of authorized retailers on their website.
    Wallygator likes this.
  8. Feb 8, 2023 at 1:21 PM
    Rocko9999
    Rocko9999 New Member
    Oh eeeeee Mmmmmm.
    TXBrit and Wallygator like this.
  9. Apr 12, 2023 at 8:59 AM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    How often is it recommended to change the spark plugs? Is it every 30k miles?
  10. Apr 12, 2023 at 2:15 PM
    matictundra
    Franco
    AZ
    Normally 5 yrs or 60K miles, or before warranty expired. I did mine at about 60k+ miles, and found a oil leak from the #8 cly spark plug tube. Confirmed leak is not from valve cover seal to the tube. Leak was from tube seal to the cyl head. Toyota replaced the passenger side cyl head sub-assy under my extended warranty. Toyota does not sell the tube and seal that gets pressed into the cyl head sub-assy.
  11. Apr 12, 2023 at 10:25 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Toyota says 120k but personally I take what ever they say and cut it in half and will do mine at 60k. Make sure you're buying plugs from a dealer or autoparts store not Amazon or ebay as many counterfeit plugs exist now.
  12. Apr 12, 2023 at 10:35 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Every 100-120k. Did mine at 115k and they still had plenty of life left. I went OEM Denso 3421 from rock auto. Get the gear wrench magnetic spark plug socket with built in extension / swivel and thank me later
  13. Dec 18, 2023 at 7:12 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Hey all,
    Denso provides 3 different plugs as an option...
    Stock # 3421 | P/N SK20HR11
    - Gap 0.044 DENSO is O.E. Manufacturer / Iridium Long Life Plug - Patented Iridium Alloy Plug (90% Ir) with Platinum Ground Strap OE
    Stock # 4704 | P/N IKH20TT
    - Gap 0.040 Iridium TT - Ultimate Endurance and Power, 0.4mm Iridium and 0.7mm Platinum Twin-Tip Technology
    Stock # 5344 | P/N IKH20
    - Gap 0.044 Iridium Power - Performance Upgrade with World's Smallest Center Electrode (0.4 mm Dia.) & Tapered Tip Patented U-Groove Design & Patented Ir Alloy (90% Ir)
    The 3421 seems to be the popluar choice and I believe is what comes on the trucks. Do the 5344's provide more power but less life? Rock Auto has those at about $.20cent cheaper than 3421's. The 4704 I see have "twin tip" at about $.50cents more. What does this "twin tip" provide?
    https://www.densoautoparts.com/part-finder-search-results/?dpfSearch=vehicle&dpfVehicleYear=2018&dpfVehicleMake=76&dpfVehicleMakeName=Toyota&dpfVehicleBaseVehicle=145174&dpfVehicleModelName=Tundra&dpfVehicleEngine=2385&dpfVehicleEngineName=V8 5.7L 5663cc 345in³&dpfVehicleTrim=968&dpfVehicleTrimName=SR5&dpfVehicleAvailablePartTypes[A/C & Engine Cooling][]=2172&dpfVehicleAvailablePartTypes[A/C & Engine Cooling][]=6628&dpfVehicleAvailablePartTypes[A/C & Engine Cooling][]=6972&dpfVehicleAvailablePartTypes[Direct Ignition Coils & Wires][]=10214&dpfVehicleAvailablePartTypes[Filters][]=6192&dpfVehicleAvailablePartTypes[Filters][]=6832&dpfVehicleAvailablePartTypes[Rotating Electrical][]=2412&dpfVehicleAvailablePartTypes[Rotating Electrical][]=4152&dpfVehicleAvailablePartTypes[Sensors][]=5132&dpfVehicleAvailablePartTypes[Sensors][]=10328&dpfVehicleAvailablePartTypes[Spark Plugs][]=7212&dpfVehiclePartTypes[]=Spark Plugs&dpfVehiclePartNum=
  14. Dec 18, 2023 at 7:17 AM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    kparrow[QUOTED] likes this.
  15. Dec 18, 2023 at 8:00 AM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Iridium can last 100k miles. I replaced the plugs on my 2007 with 260k miles 3x all 3 times the plugs looked good. A lot will depend on how you drive your truck going for longer drives will help the plugs stay cleaner
    TacomaTRD4x402 likes this.
  16. Dec 18, 2023 at 9:13 AM
    TacomaTRD4x402
    Southern California
    Thanks for the response. Not sure if it was in general or directed to my comment. All 3 options are iridium so I'm just wondering if there is an actual beneficial difference in paying more for the slightly more expensive ones. Maybe better mpg at cost of life longevity? :confused: I'm sure someone out there will know the exact differences and benefits.
  17. Dec 18, 2023 at 9:24 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Got your answer right here. Went with Autolite iridium, lasted about 80-85k miles. Cyl 5 started to misfire, that's this bad boy here, appears to be rated at a lower heat rating, according to Champion plugs guide. I recently changed them, meaning this last week, I posted all 8 here: Possible HG failure. | Toyota Tundra Forum (tundras.com) I have a 5.7 with 287k miles. This is the 2nd set, I went with NGK previous to these and back on NGK now.
  18. Dec 18, 2023 at 9:42 AM
    Orions Dad
    2007 Tundra 4.7L
    Go with the Denso long life
  19. Dec 18, 2023 at 6:59 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I went with Denso HR11 plugs. Same as my originals.
    Local Napa had them in stock for a price as good as ordering online.
