spark plugs and coils
Discussion in '2nd Gen Tundras (2007-2013)' started by Oilfieldtundra, Mar 13, 2023.
  1. Mar 13, 2023 at 1:44 PM
    Oilfieldtundra
    Oilfieldtundra [OP] New Member
    2010 tundra crew max sr5
    Stock
    good afternoon all,
    I did my spark plugs at a 100k now I am almost to 200K and I was going to do spark plugs again. I was also thinking of doing the coils as well. is this a bad idea? also what all should I do for a 200k check up?
  2. Mar 14, 2023 at 9:31 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    It's not a horrible plan if quality parts are used. If not on par with Denso quality, you may as roll the dice and leave them be.
    If your vehicle lives its life in higher ambient temps, that would hedge my bet towards replacement.
    As for all the rest, the usual suspects:
    Clean MAF 30K
    Coolant 10yrs
    Diff's & t-case 40 to 50K
    Trans dump and fill 30K
    PS fluid 30K
    Brake fluid flush 3 years
    Filters as needed.
    Battery tested 4 years plus, or replace
    Check for oil leaks, fluid leaks (water pump)
    Verify AC pressure suction and pressure at temp. Low can kill the compressor.
    Replace drive belt every 100k
    Grease all that is greaseable
    That's all I have for now.
    EvilOne likes this.
  3. Mar 15, 2023 at 5:01 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I wouldn't change coil packs unless they fail but that's just me.
    KNABORES and 07 Tundie like this.
  4. Mar 15, 2023 at 7:35 AM
    Oilfieldtundra
    Stock
    Copy that guys thank your for the response. Do you know where the MAF censer is located?
  5. Mar 15, 2023 at 7:37 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
  6. Jun 15, 2023 at 9:58 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    why not? i'm starting to research spark plugs for my 2UZ-FE and wasn't thinking about this. how long do coil packs usually last?
  7. Jun 15, 2023 at 10:33 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've got 185k on mine. I have 2 new denso coils I keep in the truck and once I have two go bad I'll change all the rest of them. There's not always a set mileage that they'll fail at really.
  8. Jun 16, 2023 at 6:06 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Uh well....hmmm....they're electrical parts. They're either faulty or they're still good. Plenty of other things to spend money on rather than parts that are not bad.
    My OEMs with 276k miles are working beautifully.
    dondino and grave[QUOTED] like this.
  9. Jun 16, 2023 at 7:14 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Will second coils as long as they're good, let them be. I'm also at 270k+ with original coils. My 2002 Celica still has original coils.
  10. Jun 16, 2023 at 3:20 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    got it. so if my motor isn't misfiring they're probably fine? i wasn't sure if these were just a wear & tear item that had a service interval.
  11. Jun 16, 2023 at 3:22 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    you have a 4.7? what spark plugs do you use?
  12. Jun 16, 2023 at 4:31 PM
    NickB_01TRD
    Nick
    KY
    The ones the manual recommends. Though for my 01 4.7 it's different than what your 07 4.7 would use I believe. Mine are just basic copper 30k plugs.
  13. Jun 16, 2023 at 6:46 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Correct. Change the plugs and let er roll!
  14. Jun 16, 2023 at 7:26 PM
    267k and counting for me
  15. Jun 17, 2023 at 2:35 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    No need to change the coils. I'm at 226k and no problems with the coils.
  16. Jun 17, 2023 at 3:59 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    A Toyota point of perspective. My 1997 T-100 (daily driver, original owner), V6, 275,000 miles, has lived its entire life in central Alabama (HEAT) and I still run the original coil packs and they are in perfect condition. Engine purrs like a fresh kitten.
    dondino likes this.
