SPC cam bolts and AC Delco Gold LCA
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Oct 9, 2023.
  1. Oct 9, 2023 at 1:21 PM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Yes, I know your going to tell me to go OEM. I know. Ive priced it out, OEM cam bolt stuff and LCA will run me 1100$ CAD... thats absolutely insane.
    Does anyone have experience running AC Delco Gold LCA's? I know moog and mevo are garbage, AC Delco has usually good reputation though?
    For SPC cam bolts, is it really that bad? Anyone have good experience with them?
  2. Oct 9, 2023 at 1:24 PM
    Whatever you buy, DO NOT walk away from the counter if the sleeves are not steel.
  3. Oct 9, 2023 at 1:35 PM
    Aaol1
    Sam
  4. Oct 9, 2023 at 1:46 PM
    Yeah, this plastic sleeve is the problem. I can't speak to the Moog. They're not the company they used to be. They don't make all of their own parts anymore, outsource a lot, and quality has suffered.
    Jack McCarthy likes this.
  5. Oct 9, 2023 at 1:54 PM
    Aaol1
    Sam
    what makes the sleeve a problem? the plastic one
  6. Oct 9, 2023 at 1:58 PM
    It disintegrates, smashes, cracks.
    That is not an application where plastic is necessarily appropriate.
    FrenchToasty likes this.
  7. Oct 9, 2023 at 2:26 PM
    Aaol1
    Sam
    fair enough
  8. Oct 9, 2023 at 4:43 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I bought these at fleabay. They look and feel like OEM, but at 1/2 the price (and no doubt 1/2 the quality). A better bet I thought than the ones shown earlier in the thread.
    shifty` likes this.
  9. Oct 9, 2023 at 4:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    ↑ this.
    There's only about 1/8" of engagement with the cross member on each side. And that transfers whatever load is on the control arm/bushings to the chassis.
    They'll work for a temp fix if oem is on order and you have to have the vehicle back. Otherwise skip em.
  10. Oct 9, 2023 at 4:46 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Got some pics disassembled?
  11. Oct 9, 2023 at 4:58 PM
    w666
    Maryland
    Nope, but they are identical to the OEM parts.
    shifty` likes this.
  12. Oct 9, 2023 at 8:03 PM
    Aaol1
    Sam
    @w666 what did you torque those to?
  13. Oct 10, 2023 at 1:18 AM
    w666
    Maryland
    Didn't...the alignment guys (supposedly) did. Just be sure not to tighten them at all until you put it on the ground.
    BroHon likes this.
  14. Oct 10, 2023 at 3:08 AM
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    I used the ones from RockAuto last year. The bushings are not the right length. Because I don't have fistful of cash I ended up fabbing up my own with a stick of carbon steel from Grainger. If i can find the pictures i took of them I'll post them. Had to massage a couple thousandths off the bolt and it worked fine. Keep in mind I'm working on a jalopy, with no budget, and I'm not off roading etc... But what I did was at least as good or better than what they gave me. :thumbsup:
  15. Oct 10, 2023 at 6:41 AM
    Aaol1
    Sam
    Fair enough!
    @w666 do you have a big enough torque wrench where you could quickly check how tight they currently are? Reason for asking is most aftermarket ones don't torque high enough as stock ( 207ft/lbs I believe) , like the SPC only go to 150, which is not enough to hold the alignment. If these torque that high that would be great
    Also, how long have you had them on for now?
  16. Oct 10, 2023 at 9:29 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
  17. Oct 10, 2023 at 4:35 PM
    w666
    Maryland
    Not likely, at least for the next few weeks (busy season at work). Torque should be 96 ft/lbs, at lease according to tundras.com
    https://www.tundras.com/threads/torque-specs.53443/#post-1394909
  18. Oct 10, 2023 at 4:56 PM
    Aaol1
    Sam
    @w666 yea I did see 207ft lbs a few times factory ones, definitely more than 96. How long have you had these for?
  19. Oct 10, 2023 at 5:07 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Where are you getting that OEM cams are tightened to 207 ftlbs? 96ft-lbs is the torque spec per the FSM.
    Jack McCarthy and shifty` like this.
  20. Oct 10, 2023 at 6:09 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Found it. Like assassin10000 said there needs to be an 1/8" sticking out each end to fit in the slot in the frame mount. As you can see even the back/Camber mount bushing is a fat 1/16th short.
    Below is this kit:
    https://www.rockauto.com/en/moreinfo.php?pk=11955125&cc=1431003&pt=13516&jsn=9
  21. Oct 10, 2023 at 6:19 PM
  22. Oct 10, 2023 at 6:43 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    shifty`[QUOTED] likes this.
  23. Oct 10, 2023 at 6:57 PM
    Aaol1
    Sam
    Yea I only saw that from a few posts on this forum saying Toyota torque is 207ft lbs and SPC only does 150, so it's far from enough. No solid data sheet to back that up though, but it did come from multiple different posts / members
  24. Oct 10, 2023 at 7:07 PM
    des2mtn
    SW
    Tonto cover
    The factory service manual with torque specifications for much of your truck is easily accessible on this forum. I would reference that first before relying on what people say here.
    I would honestly use the 96 ft/lb on the SPCs too unless their instructions state otherwise. But I don't reccomend using the SPC cams either.
    Edit: SPC's cams indicate a 150ft-lb torque spec per their instructions https://www.spcalignment.com/instructions/25445-INS_WEB.pdf
  25. Dec 9, 2023 at 12:52 PM
    DBLTRBL
    DBLTRBL New Member
    Bill
    Iowa City
    2016 sr5 Crewmax TRD Off Road
    de-badged, hood decal, Pro Headlights, Paint Match Pro grill and hood. DVD monitors. neoprene seat covers, weathertech floorliners
    2nd Gen Factory Tq is 207 on the LCA bolts. SPC TQ for 2nd Gen part n 25450 is 198 front LCA bolts and 227 rear LCA bolts. Likely the confusion
  26. Dec 9, 2023 at 1:36 PM
    des2mtn
    SW
    Tonto cover
    No I do not provide wrong information, this is a discussion specific to 1st gens. I don't give a single crap about your 2nd gen.
  27. Dec 9, 2023 at 1:43 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No, you're the one that's wrong because you're posting in the 1st gen section.
    Jack McCarthy and assassin10000 like this.
  28. Dec 9, 2023 at 2:04 PM
    DBLTRBL
    DBLTRBL New Member
    Bill
    Iowa City
    Sorry Gents, that "you still provide wrong" was not intended for either of you, and I actually thought I had deleted that and didnt know it posted. Anyway, I was just saying that the person that thought it was 207 tq is likely confused because that is the 2nd gen tq specs. Didnt mean to imply @des2mtn was wrong.
