SPC cam bolts causing alignment to not hold
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, May 10, 2022.
  1. May 10, 2022 at 6:30 AM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    So I've read in a quick search landed in 2nd gen and there's some talk about the SPC cams not holding alignment very well.
    Has anyone in 1st gen had issues with this?
    I recently noticed a choppy sound and shimmy in the steering wheel, wheel is also slightly cocked after a friend/ mechanic drove it. Tires where rotated/ rebalanced within the last few months. Everything seemed fine.
    I have an SPC cam on one side due to that bolt being trashed when I did the LCA bushings. Not sure yet which side fell outta whack so unsure if this is the culprit but seems it could be an option.
    So I'll need a new alignment. Should I just get new OEM cams before to eliminate that and check the tabs are in place/ not folded over?
    Note: I don't go off road, haven't smacked any curbs etc. Nothing I can think of that I did to knock alignment outta whack. It's been about a year or a little less since last alignment.
  2. May 10, 2022 at 6:52 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Interesting. I thought the internal corrosion of the cam adjuster in the bushing usually keeps them from moving out of place. :p
    Subscribed. :popcorn:
    Darkness likes this.
  3. May 10, 2022 at 7:13 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've had them for a couple years, no trouble yet.
    Jack McCarthy and Mogo Gogo like this.
  4. May 10, 2022 at 7:54 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    You do some wheeling also from time to time don't ya?
    That's just something I found in search. It also said that if the tech doing the alignment doesn't tighten cams correctly then it can screw up the D sleeve on the cams. I'm chasing a ghost right now I think... hopefully I can pinpoint the cause and it can be corrected before spending on multiple alignments
  5. May 10, 2022 at 8:15 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    A few runs down fire trails, nothing serious. SOC recommends different torque value than Toyota with these, that could be an issue.
  6. May 10, 2022 at 3:22 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Most shops I've been to guarantee at least 3 months on an alignment or Firestone offers Lifetime Alignments.
  7. May 10, 2022 at 10:29 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Some of the spc bolts use a plastic/delrin/teflon liner that gets smushed. Once that happens there is no saving it.
    Get OEM and a fresh alignment.
  8. May 11, 2022 at 4:25 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    This is basically what I read on before my post I think. I checked the cams visually compared to photos taken just after alignment was done. No visual difference. Did notice some new grease from CV axles so new boots and maybe axles on the list now. FML.
  9. May 11, 2022 at 6:46 AM
    JustJake
    JustJake New Member
    2006 AC
    Mine were trash. Lost alignment after 1k miles. got to go oem.
