SPC UCA install question. DIY'ers or pro installer tips.
Discussion in 'Suspension' started by MAK, May 23, 2019.
  1. May 23, 2019 at 9:54 PM
    MAK
    MAK [OP] Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    For those DIY types out here.
    I am preparing to install my lift:
    2014 Limited 4x4 TRD package, stock suspension. Stealthest color - Silver Sky
    -Toytec Boss 3/1. 700lb springs. 1-1.5 adjustable shackles. Firestone air bags. Daystar
    cradles. SPC UCAs.
    My question is specific to the set up specs of the SPC UCAs.
    I plan to place the caster in the "D" setting.
    QUESTION: Regarding the camber setting.
    There is a slot in the camber arm, where the ball joint mounts, that goes laterally from side to side. How does one set it to be the closest approximate CAMBER position of stock? Do you put it in the middle of the slot? the inside? or the outside?
    Any other discussion about measurements/setting specific to the SPC UCAs are welcome.
  2. May 23, 2019 at 11:08 PM
    MAK
    San Diego
    Thanks for the reply, but no. The Ball joint mount to the UCA is a slot. That slot allows the ball joint to be placed either inwards towards the center of the truck or outwards towards the fenders of the truck. It is another adjustment point allowing the camber to be adjusted from the top of the tire (or spindle knuckle thingy).
    Black Wolf likes this.
  3. May 24, 2019 at 5:37 AM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    I haven't added these... Yet.
    But, when I do, if there's no clear direction, my instinct would be to place the ball joint in the center of the range of adjustment and drive to the alignment shop.
    Unless with that setting, camber is out enough to visualize, I would use an angle locator to get it closer.
    You will need an alignment after installing these.
  4. May 25, 2019 at 6:55 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I installed my SPC UCA’s yesterday. Start in the “D” position. Slide the ball joint as far to the outside as possible for a good staring point until you are able to get an alignment. It drove pretty straight at that setting.
    MAK[OP] and 15Yota like this.
  5. May 25, 2019 at 6:55 AM
    TwistedTad
    Tad
    Canyon Lake, CA
  6. May 26, 2019 at 12:56 AM
    MAK
    San Diego
    Thanks you guys. I was beginning to think that there were no more DIYer's out there.
    TwistedTad likes this.
  7. May 27, 2019 at 1:41 AM
    MAK
    San Diego
    Yeah, saving money is one thing. But the primary reason for DIY is QC, and bragging rights, of course.
    I have had some bad luck over the years with poor workmanship.
    @TwistedTad, that is my exact set up!
    15Yota likes this.
  8. May 27, 2019 at 4:25 AM
    We are out here, just haven't installed the adjustable SPC's which have moved up higher on my "get er done" list .
    MAK[QUOTED][OP] and 15Yota like this.
