Spec-D Tuning LED Sequential Signal Black Smoke Projector headlights
Discussion in 'Lighting' started by Kataloots, Jun 4, 2024.
  1. Jun 4, 2024 at 10:39 PM
    Kataloots
    Kataloots [OP] 2014 1794 Edition
    Kathy
    2014 1794 addition
    Tundra grille and Installing Spec-D Tuning LED Sequential Signal Black Smoke Projector Headlights
    I have a 2014 Toyota Tundra 1794 edition and installed the Spec-D Tuning LED Sequential Signal Black Smoke Projector Headlights. I would like to have the LED DRL strip working. Anyone know where I can get the proper wiring harness or what to do get them working?Truck 4 (2).jpg
  2. Jun 5, 2024 at 4:23 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Jun 5, 2024 at 6:01 AM
    Kataloots
    Kathy
    2014 1794 addition
    Thanks Bakershack. Newbie here.
    Bakershack likes this.
  4. Jun 5, 2024 at 6:26 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    We were ALL newbies at one time!
    Bob and Kataloots[QUOTED][OP] like this.
  5. Jun 5, 2024 at 7:19 AM
    Welcome from NY.
    Kataloots[OP] likes this.
  6. Jun 5, 2024 at 8:00 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did your 2014 1794 have the DRL white LED strip on the bottom of the OEM headlight?
    It looks like it in your pic.
    If so these aftermarket headlights aren't compatible..
    2014-2021 Toyota Tundra LED C-Bar Projector Headlights w/ Sequential Arrow Turn Signals (Matte Black Housing/Clear Lens) - Spec-D Tuning (specdtuning.com)
    The white DRL on your aftermarket headlight looks like it is fed by the OEM DRL/turn signal bulb.
    But your truck isn't wired that way since you had the white strip DRL on your OEM headlights.
    Maybe @iHacker can make you something to get that feed to your aftermarket headlight.
    But I'm not sure..
    Bob likes this.
  7. Jun 5, 2024 at 8:17 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Seems to only be 3 connectors on your aftermarket headlights.
    Top headlight bulb
    Middle turn signal and what would be your DRL if you didn't have the LED strip on your OEM headlights
    Bottom is the parking light bulb.
    The problem is your new headlight isn't getting power to the DRL.
    Not sure if you can read this, but your truck DRLs are like this.
    A separate feed for the LED DRL strip.
    Your aftermarket headlights are wired for trucks that do not have DRL LED strips and use the turn signal for DRLs.
    Side note, you've also lost your motorized beam leveler with these headlights.
  8. Jun 5, 2024 at 8:19 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The connector on your truck probably looks like this.
    The connector for the aftermarket headlight would look like this.
    These are the connectors the the bulb sockets plug into being your headlight connection simply plug into the bulb sockets.
    Perhaps @iHacker could make you something that would mimic the A12 connector from what you have.
    I could be wrong..:thumbsup:
    Bob and Kataloots[OP] like this.
  9. Jun 5, 2024 at 8:31 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  10. Jun 5, 2024 at 8:33 AM
    Kataloots
    Kathy
    2014 1794 addition
    Thanks, I have messaged ihacker. Hoping he can find a solution. I should have taken a picture of the connections before putting my grille back on. I won't be able to get at it until possibly Friday now. But what you have sent me looks about right. I taped up the unused connection for now until hopefully I can get it working.
    1lowlife likes this.
