Special break-in Oil?
Discussion in '3rd Gen Tundras (2022+)' started by nondem, Apr 25, 2023.
  1. Apr 25, 2023 at 5:55 AM
    nondem
    nondem [OP] New Member
    Randy
    Tallahassee, Fl. USA
    2023 Platinum 4x4
    Seat Jackers
    I browse the Tundra groups on the book of faces and saw someone post that the oil put in third-gens at the factory is special. Loaded with zinc to do some kinda of metal hardening during break in.
    I don't think it's true(for several reasons) but thought I ask if anyone has heard of this happening with any vehicle or ICE for that matter. I've never heard of any OEM using special oil for break in. I have seen some generator manuals say to change it early the first time to get the initial debris out but that's it.
    I follow Facebook groups for several vehicles I own including a Jeep TJ. I gotta say the folks that get their answers on the FB groups aren't usually the same grade as found in forums like this.
  2. Apr 25, 2023 at 5:57 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Someone should take a sample out of a new truck and analyze it.
    pwpblue, Mattedfred and nondem[OP] like this.
  3. Apr 25, 2023 at 6:15 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Simple logic and common sense? Completely uncalled for. This is the internet, sir.
    pwpblue likes this.
  4. Apr 25, 2023 at 6:17 AM
    nodak67
    nodak67 New Member
    JR
    follow the car care nut on YT if you want some good advice regarding toyota's across all topics.
  5. Apr 25, 2023 at 6:48 AM
    nondem
    Randy
    2023 Platinum 4x4
    Seat Jackers
    100% Agree!. but it can be entertaining :)
    I do plan on paying for an oil change at the 5000k mile initial service. 10k is too long regardless of how good the oil is. Any metal/sand debris is gonna recirculate through the engine over and over regardless if the additive package. Even if the filter catches it, how many times will it go though the bypass systems till it makes a trip through the filter media?
    ryanwgregg likes this.
  6. Apr 25, 2023 at 7:05 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I thought I was the only wierdo doing some many oil changes…. Fuk it, oil is cheap. Last time around I did my own special blend. 5 quarts 0-20 and the 2.7 quarts 0-30w.
  7. Apr 25, 2023 at 7:12 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    If I'm reading correctly, it looks like the average oil analysis shows 780-790 ppm of zinc.
    The 1000 mi. change shows 745 ppm.
    Looks like the special break-in oil with extra zinc myth is busted.
    pwpblue, ryanwgregg and Mattedfred like this.
  8. Apr 25, 2023 at 7:14 AM
    nodak67
    nodak67 New Member
    JR
    yeah dont see any oem wasting money outside of normal oil to put in a vehicle. exotic vehicles excluded.
    jhtram and ryanwgregg like this.
  9. Apr 25, 2023 at 7:18 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    I heard they sprinkle hope dust and love into the break-in oil.
    Saltyhero13, KNABORES and hagrid like this.
  10. Apr 25, 2023 at 7:19 AM
    nodak67
    nodak67 New Member
    JR
    you must be talking about ford/gmc/dodge/chevy . hopes it makes off the lot before blowing something up :)
    /s
    NORTHof54 and ryanwgregg like this.
  11. Apr 25, 2023 at 7:25 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I thought they put that in Premium fuel(?)
  12. Apr 25, 2023 at 7:29 AM
    nodak67
    nodak67 New Member
    JR
    forgot to mention the "im an engineer" YT guy (from automotive press) endorsement to boot
    /s
  13. Apr 25, 2023 at 7:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The real break-in happens in the very first few minutes of engine running. That happens at assembly plant, of course. Piston rings fully seat in within the first ~500 miles. It is advised to avoid excessive idling or prolonged full-power runs during that time. Also it is a rule of thumb to use the same oil during break-in that will be used regularly in the engine's life. This way the parts wear to each other only so much that the oil is able to create a sufficient film.
  14. Apr 25, 2023 at 9:03 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    You got two free oil changes from Toyota, just ask dealership to use your free 10k oil change at 1k miles or whoever you want to change it first time, don't pay
  15. Apr 25, 2023 at 9:11 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Thats what I did... I actually paid for 1k oil-change.
    Now I thought I'd do it differently... You never know what may happen tomorrow, you may not have this truck for whatever reason, so I think it's better not to pay until you have to, and use the included free changes :)
    I don't think it'll create confusion at the dealership. You get two free oil changes, one will show up as used, so they'll just use next available. Right?
  16. Apr 25, 2023 at 10:43 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @wedemmoez can down a quart of that and still stand erect.
  17. Apr 25, 2023 at 11:42 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I plan to do oil the first oil change at 2500 ish miles and then go 7500 after that. For full synthetic oil a 5k oil change is pointless, and it probably wouldn't do anything to go to 10k mile intervals like Toyota suggests. They engineered the motor systems in Japan, I am sure.
  18. Apr 25, 2023 at 11:45 AM
    TRDoffroadPRO
    I plan to do the first oil change at 2500 miles and then go 7500 mile after that.
  19. Apr 25, 2023 at 12:04 PM
    nondem
    Randy
    2023 Platinum 4x4
    Seat Jackers
    The OEMs compete about maintenance requirements...pretty easy for them to require just enough to get the vehicle out of warranty before problem arise.
    No additive package is going to mitigate debris in the oil recirculating for more miles.
  20. Apr 25, 2023 at 12:51 PM
    nodak67
    nodak67 New Member
    JR
    i paid for my 1300 mile oil change out of pocket. told the tech to not use the freebie until 10k.
    came out to $110 but meh, compared to the v8 $87
    will do the same at 5k oil change, pay out of pocket.
    Tibetan Nomad likes this.
  21. Apr 25, 2023 at 1:04 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    The world needed this slogan on a t-shirt years ago, truly.
    Mattedfred, hagrid and Sierradevil like this.
  22. Apr 25, 2023 at 2:58 PM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    When I was researching if the oil I was to use met the Toyota spec, I found this on oil company web site. I previously only thought of mechanical damage and wear from the A S/S
    • Start-Stop Engine Technology
      • Allows the engine to stop and start automatically to reduce fuel usage
      • These engines can present issues with sludge formation and varnish deposits
      • GF-6 and API SP oils help prevent these issues
    Mattedfred likes this.
  23. Apr 25, 2023 at 3:37 PM
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    He recommends 5k oil changes and shows why, good video.
    Hard to go wrong with the 5k or once a year if you don’t drive much.
    Sierradevil and Mattedfred like this.
