Speed accuracy
Discussion in '3rd Gen Tundras (2022+)' started by Perpendicular, Jan 4, 2023.
  1. Jan 4, 2023 at 6:25 AM
    Perpendicular
    Perpendicular [OP] New Member
    Paul
    Austin, TX
    2023 Capstone
    So, it appears my speedometer is not accurate - maybe. On my second truck as well.
    I have Waze running most of the time so I can see where others have reported speed traps, etc. It also shows you how fast you are going and what the speed limit should be. When I first start driving and my speedometer shows 80, Waze is showing 85-87 in my Tundra. I shrugged it off and presumed the GPS information was just 'off' a little. The more i drove the more I noticed it is always off when first driving but eventually begins to match up - after 15-20 miles. Every time.
    This is occurring in my Capstone I bought last week. It also occurred in my Limited I traded in on the Capstone. Both are 2023 Hybrid 4x4's.
    Saying all of that, I use Waze in my other vehicle and it does NOT show that much of a discrepancy.
    Now I am wondering if my speedometer is off or if the Tundra is making the GPS signal report inaccurate data. I would like to think it is the GPS' issue and not the truck, but I am not sure.
    Anyone else done an accuracy test on their truck or put their phone driven Speedometer next to the truck reporting one?
  2. Jan 4, 2023 at 6:29 AM
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    Have you added larger tires to your truck? My speedometer is off 5-7 mph at 60+ mph, but I have 35” tires installed. Adding larger tires throws off your speed.
  3. Jan 4, 2023 at 6:40 AM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    Should have specified. Both trucks are completely factory.
  4. Jan 4, 2023 at 6:47 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    GPS apps are more accurate then the speed indicators on any vehicle. example, to display the current speed, some cars measure the actual speed, then multiply this value by a defined speed factor and add between 2 and 4 kph (1-2 mph). This should eventually cause an industry-accepted accuracy of 10% for the displayed speed reading, which in theory means that the difference at city cruising speeds shouldn’t be higher than 8 or 9 kph (4-5 mph).
  5. Jan 4, 2023 at 7:12 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    I have this same issue happening in my truck. It happened with stock tires and now also 33" (only ~1% larger). The speed is always off by 5-7 MPH vs. waze. I don't know which number to trust. It's a little frustrating to know that the odometer and MPG calcs may also be affected. In the end, doesn't matter a ton unless I get ticketed for going 88 in a 75...
  6. Jan 4, 2023 at 7:26 AM
    JRS
    JRS New Member
    2012 DCLB
    Drive next to someone you know, on speakerphone, with a vehicle which matches GPS speed. If the problem's on the truck side, it's likely that the discrepancy gets worse the faster you go (typical for speed inferencing from a pulsed signal), so do this on the interstate to see the biggest differential.
  7. Jan 4, 2023 at 7:45 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Ive noticed on my truck, that the truck's speedo is saying im going 2-3 mph faster than gps. I just figured it was more Toyota shenanigans to say gas mileage is better than it really is
  8. Jan 4, 2023 at 4:45 PM
    xc_tc
    xc_tc New Member
    This is your GPS issue if the GPS speed and speedometer converge after driving some distance.
    Usually the car’s speedometer is higher than actual speed and the difference in speed is larger at higher speeds vs lower speeds. Pretty much all manufacturers are like this because tires don’t stay the same diameter from new. As the tire wears down it gets smaller and the actual speed will decrease vs what the speedometer shows. If you were to install a larger tire, your actual speed will be the same or higher than the speedometer.
  9. Jan 4, 2023 at 6:14 PM
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    Question to OP-Paul
    People are still having trouble finding one truck and you are on your 2nd 2023? How did you make that happen? Did you get a good trade-in value for your 1st one?
    Earl
  10. Jan 4, 2023 at 6:18 PM
    Jnhalstead
    Jnhalstead New Member
    Per law, since your speedometer can’t legally be higher than your actual speed. Almost every manufacturer has it 2mph slower than the actual speed of travel
    Krusher22plat and vtown76 like this.
  11. Jan 4, 2023 at 7:42 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    When the cops put up one of those speed sign trailers my truck is always matched right to it, FWIW.
    hairychestedfrog likes this.
  12. Jan 4, 2023 at 7:53 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    IIRC OE is allowed a 5% tolerance, usually quicker than slower
    Do a true mile for mile, not a truck to GPS test.
  13. Jan 5, 2023 at 5:16 AM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    I settled for the first one and didn't get the level I wanted. I then just got lucky on the second one even though it is a level higher than I wanted to spend. 23's are all around central Texas. You just can't be tooooo picky. I wanted a 1794 as I had one before but no 4x4's so I went with a Capstone 4x4. Trade was not bad at all, I lost very little.
  14. Jan 5, 2023 at 5:17 AM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    Thanks for all of the replies.
  15. Jan 5, 2023 at 7:01 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    My 20 actually has the correct speed now with 33” tires. I have checked and verified with a gps.
  16. Jan 5, 2023 at 11:25 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    My 22 platinum showed 2-3% too high on the Speedo when stock
  17. Jan 6, 2023 at 3:07 AM
    Jasco1
    Jasco1 New Member
    23 SR5 Crewmax TRD OR Lunar Rock
    Agree with this. I traded in an Audi for my Tundra. My A6 and wife’s Q7 were both 4 mph fast at highway speeds. The Tundra Speedo is pretty accurate. I’ve used GPS to get an idea about how far off and then keep in mind when driving. Also, it seemed to be a percentage so at 15 mph it may be dead on, while 75 may be 3-4 mph off etc.
  18. Jan 6, 2023 at 3:40 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Those seem to be the worst indicator of speed and if you blow through them fast enough they don't even light up... :devil:
  19. Jan 6, 2023 at 5:40 AM
    pursuit2550
    I find it funny that they are always higher. It’s never lower. Wonder how big of an impact this is on mileage? Because technically you reach your warranty mileage faster.
  20. Jan 6, 2023 at 6:56 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    My truck on 35’s only shows 2-3 mph difference be Speedo at 80mph (legal speed limit in Idaho)
  21. Jan 6, 2023 at 7:31 AM
    GunnyTundy
    GunnyTundy New Member
    North Dallas, Texas
    2022 Lunar Rock Tundra
    I changed out my tires to the BFG KO2 in 275/70/18 and the speedo is an exact match to GPS.
    Ruffus and dogsleds_t100_tundra like this.
  22. Jan 9, 2023 at 8:59 AM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    So, many of you are saying it is usually higher. Mine is lower, like 6-7 MPH lower than my GPS is saying. That is ticket territory, especially if I am speeding above what I think I am going by 5.
  23. Jan 9, 2023 at 10:54 AM
    JRS
    JRS New Member
    2012 DCLB
    Reread my post and determine which device has the error - phone or vehicle. If the truck is at fault, something is throwing your CAN message off. Since the speed 'magically' gets corrected after some time, I'm wondering if the hybrid controller isn't at play.
  24. May 8, 2023 at 3:54 PM
    Colonel99
    Colonel99 New Member
    ‘23 Platinum Tundra Hybrid
    Hello,
    I just bought a ‘23 Platinum Tundra Hybrid and am having the same issue with Waze (using Apple CarPlay). I took my truck in today to get a couple of things taken care of and they put me in a ‘23 Highlander. Same issue with Waze there. Sometimes it shows the same speed as the vehicle but most of the time it shows 5 to 7 mph higher on Waze. My previous vehicle did not have this issue and I believe I know why. In my previous vehicle I didn’t have “wireless” Apple CarPlay and the speed was always accurate. I believe the issue might be the “wireless” part of using Apple CarPlay. Once I get my truck back, I am going to remove my iPhone 14 Pro and reinstall via USB-C cable to see if this fixes the issue.
    Anyone else have similar issues?
  25. May 8, 2023 at 7:23 PM
    Colonel99
    Scratch that…just tried it out in the Highlander and it is still off by 5 to 7 mph. Must be on Toyota. Hopefully they will send out an update to correct. I am assuming the speedometer on the vehicle is correct and the audio system is casing the error. Seems odd that Waze…being GPS driven for the speed…could be affected by the audio system but it must be!
  26. May 8, 2023 at 7:34 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    My speedometer is closer to accurate with 33s than the 32.4s it came with. Radar still has me 1mph slower than indicated at 70 mph.
  27. May 8, 2023 at 9:05 PM
    ArticTundra
    ArticTundra New Member
    Cold
    Come out here and I’ll aim a radar at you. If you’re off by quite a bit, I’ll write you a ticket voucher to go get it fixed and then pay court fees to have it dropped. Easy.
    Eurodriver likes this.
  28. May 9, 2023 at 5:15 AM
    nodak67
    nodak67 New Member
    JR
    typically toyota speedo are 1.6 kmh off (1 mph lower) from the factory across all models.
  29. May 9, 2023 at 10:19 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    Mine matches the stand alone speed stations as well and I have 33" tires on mine.
  30. May 9, 2023 at 12:23 PM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    I had Waze show a different speed than my speedo the other day. Restarted Waze, no dice.
    Then I restarted my phone, started Waze, and the speeds matched to within 1mph.
    Mattedfred likes this.
