Speedometer and odo not working
Discussion in '1st Gen Tundras (2000-2006)' started by Brandusedtundra, Jan 24, 2020.
  1. Jan 24, 2020 at 8:41 AM
    Brandusedtundra
    Brandusedtundra [OP] New Member
    Joe
    Michigan
    2005 tundra phantom grey rclb 4.7 v8 4x4
    32's duratracs k&n air filter
    About 2 weeks ago i got stuck in an iced over mud hole and when i got pulled out by my buddy my speedometer and odo quit working ive cheaked the wires i can see abd i thought of but no ripped wires
    I have the p0500 code
    I already pulled my abs fuse as soon as i bought the truck and when i did the wheel bearings this summer i broke one of the front speed sencers but it had no affect on the speedometer
    I dont have traction control or stability control
    It is a 2005 regular cab v8 4wd
    Any ideas?
  2. Jan 26, 2020 at 8:23 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Does it still shift/drive correctly??
  3. Jan 27, 2020 at 5:14 PM
    Brandusedtundra
    Joe
    Michigan
    Yes it still runs and shift just as it always has
  4. Feb 13, 2020 at 8:43 AM
    Brandusedtundra
    Joe
    Michigan
    The code reader said vehicle speed sensor a so i replaced that and that didnt work so now i have a new gauge cluster on the way
  5. Feb 18, 2020 at 1:28 PM
    Brandusedtundra
    Joe
    Michigan
    The gauge cluster didnt work anybody got any ideas?
  6. Mar 9, 2021 at 1:52 PM
    allmotor
    allmotor New Member
    tim
    2000 Tundra Access Cab TRD Limited
    Wheels
    ever get this fixed? I have the same issue.
  7. Mar 9, 2021 at 3:03 PM
    TriniMan
    TriniMan New Member
    SEAN
    South Carolina
    2019 White Tundra CM TSS
    Installed remote start, throttle controller, transmission oil cooler, front and rear TRD sway bars and K&N air filter.
    Your speedo gets its signal from the rear speed sensor. I don't remember if it is the left or right. I do thing its the left rear speed sensor. I had a customer whose speedo stop working and i found that squirrels ate his sensor wiring harness. Once harness was replaced, speedo worked.
