Stained metal fix
Discussion in 'General Tundra Discussion' started by GianLaGatta, Feb 20, 2022.
  1. Feb 20, 2022 at 11:34 AM
    GianLaGatta
    GianLaGatta [OP] New Member
    Gian
    2019 white tundra sr5
    3in lift
    Sup guys, was bein a dummy before I left for vacation. Just got the bumper put on but it was raw metal, so it was rusting after a day or two. I went and found some cheap rust-olem to hold it off before I could clear coat it when I got home. But I let it sit for too long and it’s stained! Any products or methods you guys recommend to get the polished look back?
  2. Feb 20, 2022 at 11:40 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    joonbug likes this.
  3. Feb 20, 2022 at 11:41 AM
    GianLaGatta
    Gian
    3in lift
    Not a bad deal, would that reach the plates too?
  4. Feb 20, 2022 at 12:52 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :notsure: dunno, I haven't played with one yet but it'll polish the tubing with the right grit paper. There'll definitely be some hand work to accomplish what you want.
  5. Feb 20, 2022 at 12:54 PM
    GianLaGatta
    Gian
    3in lift
    Awesome, thanks for the help. Nice truck btw:headbang:
    831Tun[QUOTED] likes this.
  6. Feb 20, 2022 at 12:57 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Our bumpers are VERY similar. Can't remember the fab guy's name, he's in SoCal, where I first saw the design. Good luck with your project.
    joonbug likes this.
  7. Feb 23, 2022 at 9:26 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    0000 steel wool should do the trick.
    831Tun likes this.
  8. Feb 23, 2022 at 9:30 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    A light polishing compound. Or ROCKS....like it is meant to be against. ;)
    GianLaGatta[OP] likes this.
  9. Feb 23, 2022 at 9:32 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thing about steel wool is little fragments get left behind and can make a rust situation worse. I gave up on steel wool a long time ago and only use synthetic now.
    I made an entry door for a client at the beach. I applied the desired finish with steel wool. A couple weeks later I got a callback, black dots were popping up primarily in the corners. So, I had the pleasure of refinishing a door I'd just built. That was the last time I used steel wool.
    Sumo91[QUOTED] and joonbug like this.
  10. Feb 23, 2022 at 10:14 AM
    Sumo91
    TN
    That makes sense. I haven't had it happen to me yet, but I'll be more cautious of that in the future. I use it alot for cleaning up glass, machined surfaces, and chrome, etc. Maybe a magnet could get any wool pieces leftover. They also make a 0000 and 000 bronze wool that works great too. But it's harder to get your hands on. Most bronze wool labeled "Fine" is 000
