Stainless steel braided brake lines
Discussion in '1st Gen Tundras (2000-2006)' started by kentuckyMarksman, Oct 3, 2023.
  1. Oct 3, 2023 at 5:23 PM
    kentuckyMarksman
    kentuckyMarksman [OP] New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    I've had braided stainless steel brake lines on tricks in the past. Would like them on my Tundra. Does anyone here have any on their truck? What lines do you have?
    I ordered a set from Power Stop in July but am still waiting on backorder. I've seen some others by Goodridge, but the picture only shows 2 lines (front), but the description says 4 lines included. My truck only has 3 soft lines, not 4.
    Anyone know of a set of braided brake lines in stock that would work with a 2006 Double Cab 4x4 Tundra?
  2. Oct 3, 2023 at 6:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have these on the silver truck at least. 70k+ trouble free Miles
    HBTundra likes this.
  3. Oct 3, 2023 at 7:02 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I ditched the hard lines for braided as I felt more comfortable with the slack being lifted 5"+. I had kinked one of the short hard lines doing front end work and the brackets didn't work on the new spindle for the hard lines anyways. I got them from a guy on the tundra Facebook groups
  4. Oct 4, 2023 at 3:32 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Do you have a link to the lines you used?
  5. Oct 4, 2023 at 4:55 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I got them from this dude from Facebook group. I don't know.if he's on the forum or not.
    https://www.evanyipdesigns.com/
    tvpierce[QUOTED] likes this.
  6. Oct 4, 2023 at 6:52 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    I got the Goodridge braided stainless lines because they included a stainless line for the rear as well. Got nothing bad to say about them.
  7. Oct 4, 2023 at 7:52 AM
    kentuckyMarksman
    Given that my truck has 1 soft line in the rear, it's a non VSC truck, correct?
    Edit: I've confirmed my truck is non-VSC.
  8. Oct 4, 2023 at 7:59 AM
    I’ve got braided SS on my 2000 for many years now. Can’t say they added anything other than piece of mind, but the brakes on it are great, so guess they are working.
  9. Oct 4, 2023 at 8:13 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I had called goodridge quite some time ago but wasn't sure what I needed with the lift etc. They are super helpful on the phone, iirc there's 1 or 2 guys that deal with this type of thing at their company seems to know his shit. I haven't done that rear yet the fronts were a problem at the time so I concentrated there but wish I'd have done all now due to having to bleed brakes again I always need to find a helper.
  10. Oct 5, 2023 at 8:20 AM
    kentuckyMarksman
    Thanks. I've found the Goodridge lines I need. Turns out the company I ordered the Powerstops from have them in stock. I've asked if I can change my order from the PowerStops to the Goodridge but haven't heard back.
  11. Oct 6, 2023 at 6:40 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Let us know the part number of the goodridge if/when you get them for reference to this thread.
  12. Oct 6, 2023 at 6:52 AM
  13. Oct 6, 2023 at 7:38 AM
    kentuckyMarksman
    I'm planning on getting the Goodridge # 21192 lines.
  14. Nov 28, 2024 at 10:05 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Well now, another VSC thing I hadn’t thought about yet. How are my VSC rear lines different than normal, and what do I need to order to make sure that when I lift 1.5” all my lines are safe?
  15. Nov 28, 2024 at 10:10 AM
    kentuckyMarksman
    VSC trucks have 2 soft lines in the back, non VSC just have 1.
    Bed Tundy[QUOTED] likes this.
  16. Nov 28, 2024 at 10:12 AM
    To boot, and only for reference, I highly, highly doubt you need to extend your lines for 1.5" lift. I have roughly 2.5" lift and my lines are fine at full droop and full compression.
  17. Nov 28, 2024 at 10:15 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Ok good, that’s not too bad, I thought it would be worse. I’ll just give it a shot without any
    I’ve been looking at how most people install their rear leaf spring and it seems disconnecting the brake lines makes it easier for installation and less risk of damage. Bleeding the brakes with VSC is super easy, it’s my own pump. How did you end up with 2.5” in the rear shifty?
  18. Nov 28, 2024 at 10:40 AM
    2.5” front. I settled out around 1.4” in back using the ATS HD springs I think? I measured recently, initial lift was like 2” and it settled to 1.75 after a month or so. Apparently settled more in the last year.
  19. Nov 28, 2024 at 10:56 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I have my topper over my bed but no spare tire adding weight in the back, so it might take a while to settle. was part of your initial gain just from sagging springs or is that 2” over stock height? Just watching it squat when I loaded it with firewood helped me decide the 90-221HDs were the way to go.
  20. Nov 28, 2024 at 11:10 AM
    My truck has 80k miles. Springs were fine. @w66 has my old springs now. They were fairly mint. That 2" gain was with no topper, and unsettled. It settled to 175" I believe after the initial ride (memory fuzzy). Then I added the topper, and had about 1,000lb of UPS battery packs in the back for a couple months. And after I pulled the batteries out, drove it for a while with a couple hundo pounds of tires and stuff for a few more months, that's when I measured again around 1.4-1.5"
