Started Engine After Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ranger198P, Nov 29, 2023.
  1. Nov 29, 2023 at 5:32 PM
    Ranger198P
    Ranger198P [OP] New Member
    2018 Cement Tundra 4x4 XSP
    None
    Good evening! I have a novice question and truth be told I know it’s my paranoia kicking in. I’ve changed the oil myself in all my vehicles over the years. Watched a video on clear flood mode and looked up to see if my 2018 Tundra had it. Thought it would be good to do to “prime the filter” before start. Found a forum post on facebook stating it did with instructions. Shouldn’t have trusted it given it was from a forum and not the owners manual. Changed the oil and tried it. Engine fired off with my pedal pressed to the floor. I killed it immediately and doubt the RPMs got over 2K if that with the pedal pressed down. Bet it was less than a second. I’d been running the engine just prior to changing to pull it into the shop so I’m sure the engine had oil coating it. That couldn’t have caused any harm could it?
  2. Nov 29, 2023 at 5:43 PM
    AZBoatHauler
    So.Arizona
    Definitely over thinking. It’s fine.
    If you want it to crank and not fire pulling the IGN fuse will do it. Not necessary.
  3. Nov 29, 2023 at 6:09 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    You can prefill the filter with oil before screwing it back on to minimize the delay of filling it if you’re concerned about that in the future.
  4. Nov 29, 2023 at 6:14 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Just a FYI. I've had 7 new from the dealer Toyotas since 1985. Lots of miles on all of them. Done every single engine oil change myself (some 200 of them). I've never prefilled an oil filter. Never had an inkling of an issue.
  5. Nov 29, 2023 at 6:18 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I love to prime...
    Xcumminsguy and MadMaxCanon like this.
  6. Nov 29, 2023 at 6:18 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Ha, I tried the same thing and was surprised as you were when the truck fired right up .
    Don’t worry about it, just gets the oil pressure going a bit quicker!
  7. Nov 29, 2023 at 6:19 PM
    Ranger198P
    None
    For sure gents. I was more concerned about the fact that it started to rev up with the gas pressed before giving it a chance to get oil up into the engine. As I stated it didn’t rev higher than 2K and was only for a second.
    Thank you gents for all the responses. It’s much appreciated. I’ve done my own oil changes for 15 years on multiple trucks and this was the first time I felt like I made an oops.
  8. Nov 29, 2023 at 6:22 PM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    I don’t think it’s necessary either. I do it because it’s easy…figure why not.
    Johnsonman likes this.
  9. Nov 29, 2023 at 7:48 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    I've done my own oil changes for over 30 years and have never prefilled a filter.
    RustyShackle323 likes this.
  10. Nov 29, 2023 at 7:55 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    You'd be surprised how long your bearings go without oil if you don't pre-fill the filter first which only takes a minute. Will it kill your engine, no, is it great for it, also no.
  11. Nov 30, 2023 at 3:43 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    hagrid likes this.
  12. Nov 30, 2023 at 3:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You don't oil up your gen2 bearings and someone's else gen3 spins them.
    hagrid and windblown101 like this.
  13. Nov 30, 2023 at 4:07 AM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    You didn't hurt anything and now you know (if you didn't before) that the internet has some bits of good advice, and really dumb advice.
    Henry1jg and Ranger198P[OP] like this.
  14. Nov 30, 2023 at 5:42 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Don't look at me. I'm still flabbergasted that people insist on draining out perfectly good TGMO from the factory and refilling with what I am sure is an inferior product.
    Except Kirksoil. Kirksoil is the only lubricant that is equivalent to TGMO in laboratory testing.
    Kirksoil is guaranteed to protect bearings during periodic dry running conditions. Except for 3rd gen bearings. Even Jebus can't save those.
    @Eurodriver
  15. Nov 30, 2023 at 6:14 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
  16. Nov 30, 2023 at 6:25 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    You CLEARLY don't "roberttheoildude.com"
    I'm flabbergasted you continue to rep Kirksol, when Amland is the undisputed king of lube.
    I would like to see one shred of evidence to support the swill oozing from your keyboard..... Sir
    Henry1jg, hagrid[QUOTED] and vtl like this.
  17. Nov 30, 2023 at 6:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  18. Nov 30, 2023 at 6:29 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Our usernames both pertain to Ranger boats
  19. Nov 30, 2023 at 6:49 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Ok, so there is a difference. If prefilling the filter makes such a difference, why doesn't the manual recommend doing so? And most techs I know don't prefill the filter. And I'd bet that the million mile Tundras did not have prefilled filters in their oil changes. Is prefilling a BAD idea? No. But how much good is it REALLY doing?
  20. Nov 30, 2023 at 8:24 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Just keep topping it off until the main bearings fail, which is imminent with gen 3, don't ya know?
    Eurodriver[QUOTED] and hagrid like this.
  21. Nov 30, 2023 at 8:26 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Also a superior lubricant.
    For wimmenz.
  22. Nov 30, 2023 at 8:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I've heard rumors Toyota uses Boibutter at gen3 assembly lines. So it is silk smooth and rock solid.
    Johnmatrix and Sierradevil like this.
  23. Nov 30, 2023 at 10:07 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Do they sell it in 55 gal drums? I've heard this is how much is needed with gen3.
  24. Nov 30, 2023 at 12:10 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It's a gift.
  25. Dec 1, 2023 at 3:44 AM
    Bammer
    Monroe, CT
    that keeps giving !
    Sierradevil and hagrid[QUOTED] like this.
