Starter switch wiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by TheJoergers, Jun 13, 2023.
  1. Jun 13, 2023 at 11:38 AM
    TheJoergers
    TheJoergers [OP] New Member
    Sam
    2015 tundra
    Just for informations sake, what had happened was, the steering column got kicked so hard that the ignition switch (and the piece that plugs into it) both shattered. I can find the replacement ignition switch but can't figure out what the thing that plugs into it is called.
    It would be the white clip part that the wires fit into and then plugs into the ignition switch. But no matter what search terms I use I can't find it. Is it even something replaceable?
    I would also need to know which wires go where (if I can ever find the lil clip part)
    Image is of the part of the ignition switch that I'm needing the connecting piece to go into.
