Steering rack fail on my 19...53k miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by dkrou, Apr 18, 2023.
  1. Apr 18, 2023 at 2:39 PM
    dkrou
    dkrou [OP] New Member
    dan
    2019 tundra
    Just got the call I need a new steering rack on my 19...can't drive the truck in its current state. Toyota says they are seeing this a lot in lifted trucks. I have a 3 inch lift and did it right. Fortunately I got it covered under warranty which is typically not the case if it is lifted. Such a common issue they have 400 of these racks backordered. Who knows how long it will be to get it repaired. Anyone else have this happen?
  2. Apr 18, 2023 at 3:01 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    what wheels and tires do you have?
  3. Apr 18, 2023 at 3:10 PM
    dkrou
    dan
    2019 tundra
    18 inch toyota rims on bora spacers....295/70/18. I got the coachbuilder steering kit when I put the toytec coilovers on. Also dif drop kit...
  4. Apr 18, 2023 at 3:21 PM
    MadMaxCanon
    I was wondering if mods had something to do with the dealer claim of lifted trucks having this issue alot. I dont really recall seeing alot of these failures on the forum.
    Silver17 likes this.
  5. Apr 18, 2023 at 3:25 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Toyota does have a TSB on the rack, not sure how far it goes to year was. When I was issued a letter, if I remember correctly it did mention it ran up to 2021. I'm sure if you search around you may find your answer.
    MadMaxCanon likes this.
  6. Apr 18, 2023 at 3:35 PM
    blackdemon_tt
    Here are 2 TSBs on the NHTSA site, you can search via your vin and get better information. This is a general search with year, make and model.
    December 23, 2021 NHTSA CAMPAIGN NUMBER: 21E103000
    Power Steering Gear Assembly May Leak Oil
    An oil leak may cause a sudden loss of power steering assist, increasing the risk of a crash.
    NHTSA Campaign Number: 21E103000
    Manufacturer Toyota Motor Engineering & Manufacturing
    Components STEERING
    Potential Number of Units Affected 151
    Summary
    Toyota Motor Engineering & Manufacturing (Toyota) is recalling certain JTEKT power steering gear assembly service parts for 2007-2021 Tundra and 2008-2022 Sequoia, part numbers 44250-0C160, 44250-0C131, 44250-0C170, and 11250-0C121. The power steering gear assembly may have been manufactured incorrectly, which can result in an oil leak.
    Remedy
    Dealers will inspect and replace the power steering gear assembly, free of charge. Owner notification letters were mailed on February 17, 2022. Owners may contact Toyota customer service at 1-800-331-4331. Toyota's number for this recall is 21TH01.
    Notes
    Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.nhtsa.gov.
    31 Affected Products
    8 Associated Documents
    Request Research (Services fees apply)
    November 23, 2021 NHTSA CAMPAIGN NUMBER: 21V920000
    Oil Leak May Cause a Loss of Power Steering Assist
    NHTSA Campaign Number: 21V920000
    Components STEERING
    Potential Number of Units Affected 22,462
    Summary
    Toyota Motor Engineering & Manufacturing (Toyota) is recalling certain 2008-2022 Sequoia and 2007-2021 Tundra vehicles. The power steering gear assembly may have been manufactured incorrectly, which can result in an oil leak.
    Remedy
    Dealers will inspect and replace the power steering gear assembly as necessary, free of charge. Owner notification letters were mailed on January 21, 2022. Owners may contact Toyota customer service at 1-800-331-4331. Toyota's numbers for this recall are 21TB10 and 21TA10.
    Notes
    29 Affected Products
    15 Associated Documents
  7. Apr 18, 2023 at 3:53 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    By steering rack failing does this mean the power steering has failed? Or is the truck actually inoperable and cannot turn at all?
  8. Apr 18, 2023 at 4:39 PM
    dkrou
    dan
    2019 tundra
    Power steering pump is fine...rack went out and barely turns. You can't drive it.
    300BLK[QUOTED] likes this.
  9. Apr 18, 2023 at 4:41 PM
    dkrou
    dan
    2019 tundra
    I think this only applies to defective parts that were installed after the truck was delivered. I will check again regardless...thanks
  10. Apr 18, 2023 at 5:55 PM
    blackdemon_tt
    Doesn't hurt to try. Not sure I follow regarding defective parts after delivery. My 07 falls under this TSB and I haven't touched the rack at all.
  11. Apr 18, 2023 at 6:01 PM
    dkrou
    dan
    2019 tundra
    I thought they checked my VIN under that already but I will check again...thanks UPDATE...My VIN says no unrepaired recalls.
  12. Apr 18, 2023 at 6:14 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Interesting, sorry to hear about your issue. I’ve not previously noticed this mentioned as a common issue on lifted tundras, or stock for that matter on the many social platforms I frequent that are tundra related in years of paying attention to them.
    TheBeast likes this.
  13. Apr 18, 2023 at 6:24 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Been lifted most of the miles I've got on my 2016. I've got 7.5" and I've run spacers most of that time. Currently at around 79k miles.
    I've got no issues with steering.
  14. Apr 18, 2023 at 7:28 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I got a notification a while back that mine had a recall for the potential defective power steering gear service replacement assemblies. NHTSA Recall No.21E-103
    Hadn't done it yet. I got a 2019 SR5 TRD Sport.
  15. Apr 19, 2023 at 10:35 AM
    DeanoBambino64
    DeanoBambino64 New Member
    Dean
    Saskatoon Area
    2008 Tundra Crewmax Limited 4X4 5.7L V8, 20"aluminium oem wheels.
    Why R&P warranty is a nightmare for mechanics.
  16. Apr 19, 2023 at 10:45 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Is it the same issue like in late 2021 where 1 rack assembly line had a worn equipment and was making racks out of tolerance? 3 other assembly lines were ok.
