Steering Wheel Controls
Discussion in 'Audio & Video' started by contenderv07, Jun 18, 2022.
  1. Jun 18, 2022 at 12:03 PM
    contenderv07
    contenderv07 [OP] New Member
    Will
    Hey everyone, I just got a Pioneer DMH-2660 stereo. Everything works great except for one thing.... when I go to Carplay mode the steering wheel control to move to the next track doesn't work, but volume works. It also works when I go to the radio, just not within carplay. Am I missing a component or something?
  2. Jul 3, 2022 at 7:01 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I’m having this same issue. Were you ever able to get it fixed?
    I don’t get why it’ll work for the radio but not in car play mode.
    Also on yours if you do something on your phone like open photos app does yours change from say the radio screen to the black CarPlay screen?
    contenderv07[OP] likes this.
  3. Jul 3, 2022 at 10:27 AM
    contenderv07
    Will
    I got in touch with idata and they told me to get the maestro RR and that would work. I haven't gotten it installed yet, but I think that will do the trick. Too bad its like another $270 for the RR and another harness you have to get. I think I'm gonna get it installed next week so I'll report back
  4. Jul 3, 2022 at 10:35 AM
    Musicmasterd12
    Southern Louisiana
    Damn! Yea I’ll just have to live with not being able to track forward and back on CarPlay. That’s steep! I don’t have the maestro though, I used the axxess steering wheel control
  5. Jul 3, 2022 at 10:42 AM
    contenderv07
    Will
    cool thing with the maestro you can see other things like tire pressure, obd2 codes, etc.. Having to reach over to turn it to the next song stinks haha
  6. Jul 4, 2022 at 4:11 AM
    contenderv07
    Will
    on a side note these are the models that idata said I needed
    bulldog93 likes this.
  7. Jul 4, 2022 at 5:18 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I think you’ll be much happier with the idatalink. I have it on our truck and everything works perfectly. Zero issue with carplay track up/down using swc. Suck its a little pricey. But it’s worth it in the end. Hit eBay, sometime you can find a deal.
  8. Jul 4, 2022 at 10:57 AM
    Musicmasterd12
    Southern Louisiana
    Also with the radio if youre listening to the radio and then open an app on your actual phone does it change your screen to the iPod screen? Just curious if anyone else has that issue
  9. Jul 4, 2022 at 12:22 PM
    BrandonL812
    Brandon
    Mine doesn’t change when i open my phone to browse something else or open another app. carplay still function normal on the radio and i can still check email and messages on the phone or browse the web.
  10. Jul 4, 2022 at 12:25 PM
    Musicmasterd12
    Southern Louisiana
    thanks. It must have something to do with the wireless adapter I added then. I’ve honestly never tried it without the wireless adapter so may have to just plug it in directly and see if I have the same issue
    thanks for your help
    BrandonL812[QUOTED] likes this.
  11. Jul 7, 2022 at 8:41 PM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    Same parts I used to put a DMH-2600NEX in last week. Also used there USB adapter to retain the factory USB location. My only issue with the harness is that it is intended to use a premade harness so you don't have to splice it to you stereo harness. Only the adapter harnesses can't be bought yet. I emailed them and was told no one will have them listed yet even though their website shows them. So step one is literally cut of big connector and splice in wires.
    That said the ssytem works great and getitng the TPMS screen and gauges (especially trans temp) is great. Didn't change anything from default while programming the RR and everything works fine.
  12. Jul 8, 2022 at 5:14 AM
    BrandonL812
    Brandon
    can you elaborate on this? I’m not sure I understand it correctly?
  13. Jul 8, 2022 at 5:46 AM
    FredB32
    FredB32 New Member
    2011 TRD RW
    Same...I have the USB adapter I installed on my 2011 a few weeks back and it works fine. Note there are two USB adapters. The factory one (at least on my 2011) had to be connect up to the data point behind the glove box. Not difficult but a little work, as I had to kind of feel my way around. I'm going off memory a bit, but I believe there are two adapters as some trucks have a data/entertainment center type setup, and others don't. One routes the USB via the factory wires, and one I believe hooks it up directly to the deck. Again...memory here, but the having or lack of originally-installed Bluetooth/steering wheel controls may be the deciding factor.
  14. Jul 8, 2022 at 6:00 AM
    belairbrian
    What I found was that the original harness was the rTO2, it had unterminated wires which were ready to splice to the harness that comes with the head unit. Now there is the hrTO2 (notice teh h ). It has all of the loose wires connected to a black connector. In theory you can buy a short adapter cable. In the case of a pioneer unit it would be part number PI01. Thus no splicing. But no one seemed to have them. I emailed maestro, and they told me it was a new product and none of the resellers would have them listed for sale yet. They did suggest calling crutchfield and asking if they had one, but the guy there didn't know what it was. I suspect these adapter cables will start to show up and this will literally be a plug and play solution.
    I was also told the older rTO2 cable was discontinued. I guess since it takes 30 seconds with wire cutters to turn an hrTO2 into an rTO2.
    This is from the install guide:
  15. Jul 8, 2022 at 6:04 AM
    belairbrian
    Something that just popped into my head. Maestro sells an "antenna adapter". It is for the gps and satellite antennas, not the AM/FM radio antenna. I didn't use the gps or sat radio connections. Maestro does NOT make a AM/FM radion adapter but you need one, so source that seperately. I went with the red wolf https://www.amazon.com/dp/B07VFTPJMM?ref=ppx_yo2ov_dt_b_product_details. Works fine, you don't need to connect the blue wire.
  16. Jul 8, 2022 at 6:11 AM
    BrandonL812
    Brandon
    I see what you’re saying now. That must be new because i used the RTO2 harness. Hrto2 must be their new update version.
  17. Jul 8, 2022 at 6:16 AM
    belairbrian
    That's what i undertood. I guess they got the hrTO2 into production but don't have the adapter cables yet. Which kind of makes sense. The big harness fits pretty much every Toyota in the newer year group. But they will need different adapters for each head unit manufacturer.
  18. Jul 8, 2022 at 6:23 AM
    BrandonL812
    Brandon
    I supposed it’s only a matter of time before they will have the adapters. It will definitely make installation so much easier. No soldering involve.
  19. Jul 8, 2022 at 7:28 AM
    contenderv07
    Will
    Ahh perfect!! thats what I wanted to hear! I was debating going ahead and setting it up at home, then taking it to best buy, but if you say the defaults worked, then that sounds good to me. Thanks again!
  20. Jul 8, 2022 at 3:41 PM
    BrandonL812
    Brandon
    it’s really simple to program. You can watch YouTube video by 5starcarstereo (five star car stereo). They have vid on how to program it.
