Steering Wheel crooked
Discussion in '2.5 Gen Tundras (2014-2021)' started by Abdul98, Nov 25, 2020.
  1. Nov 25, 2020 at 2:15 PM
    Abdul98
    Abdul98 [OP] New Member
    Abdul
    2020 Toyota Tundra limited double cab
    Hey everyone, Since I've bought my truck, the steering wheel has been at an angle. I've had the truck aligned, tires rebalanced with no luck. No matter what I do, when I put the wheel perfectly straight, the truck goes slightly left. Has anyone else had this issue or are tundra's naturally like that? It drives me nuts and I'm looking for a solution.
    Thanks everyone! Happy Holidays!
  2. Nov 25, 2020 at 2:24 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    That can be adjusted. Have the dealership take a look at it.
  3. Nov 25, 2020 at 5:29 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    What does it do when you let go of the wheel? Does it pull either way?
  4. Nov 25, 2020 at 7:30 PM
    Rubberdown
    Take it back and tell them to straighten the wheels. It’s just an adjustment.
    15whtrd and Boerseun like this.
  5. Nov 25, 2020 at 7:39 PM
    SKB
    SKB New Member
    Shane
    CA
    2015 S/C Tundra CM 4X4
    when the steering wheel is offset to the right with no input does it straighten out and pull left or stay to the right and drive straight?.
  6. Nov 26, 2020 at 3:20 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    1/4 turn in on L/H and a 1/4 turn out on R/H tie rods will fix that. They didn't center and lock the wheel down when doing the alignment.
    -Jason
  7. Nov 26, 2020 at 3:56 AM
    slongo
    slongo New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    You need a better alignment shop ! They need to center the steering wheel before they do the alignment .
  8. Nov 26, 2020 at 6:34 AM
    Mustache 1
    Mustache 1 New Member
    2015 Tundra ,Limited , MGM
    If the steering angle sensor was not reset with the Code Link device or a scan tool the steering wheel adjustment can be affected.
  9. Nov 26, 2020 at 7:12 AM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    My 2020 is doing the same except my wheel is to the left and not the right like OP’s. I’ve removed the steering wheel in an attempt to straighten it out up top, but one tooth to the right only makes me off center in the opposite direction
  10. Nov 26, 2020 at 7:58 AM
    TriniMan
    TriniMan New Member
    SEAN
    South Carolina
    2019 White Tundra CM TSS
    Installed remote start, throttle controller, transmission oil cooler, front and rear TRD sway bars and K&N air filter.
    Hi guys, see if helps you. First, thomasbus337, you should never have to pull the steering wheel off to center it. Your turn signal cancel points will be off and it will not fix you problem.
    A little on my back ground; I worked as a service rep. for Hunter Engineering Co. for 20 years. I left four years ago and now I have my own repair shop that also do alignment.
    The alignment printout that you are showing tells me a few things. The shop is using a Hunter aligner and on paper your alignment looks great. Now for the possible bad, the tech did not drive you truck the verify that he did a good alignment to see that the truck drives straight and your steering wheel was straight; the alignment machine could be out of calibration and need a service rep. to come in and calibrate it, also the turnplates that the front wheels sit on while being aligned may also need some service. One of the signs that the aligner needs calibration is a crocked steering wheel after the alignment was done.
    Still, your problem is an easy fix. If the truck drives straight, but the steering wheel is off to the left or right, you can take a crayon and mark the inner and outer tie rod end at the jam nut and put another reference mark on the outer tie rod end 180 degrees for the first mark. Now, what ever direction and quantity you turn the inner tie rod end on the left side, you do the same on the right side, same direction and quantity. So half a turn down on left, and half a turn down on right. Then test drive. If the steering wheel got straighter, you turned the inner tie rod ends in the right direction. If it got worst, turn the inner tie rod ends back to the original position and continue another half a turn. Then test drive.
    Sorry for be so winded, but at my shop, every vehicle get test driven before giving back to my customer.
  11. Nov 26, 2020 at 8:16 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  12. Dec 1, 2020 at 3:10 PM
    KDSA
    KDSA New Member
    Cory
    17’ DC White
    Having the same issue. Got my alignment from Les Schwab for free from the place I bought my truck, never going back. Firestone has always done well with all vehicles that myself and family have owned.
  13. Dec 1, 2020 at 3:14 PM
    thomasbus337
    2020 TRD Sport DC
    I should have mentioned, I had the wheel off to leather wrap it anyway. I did find a tech document on TIS that outlined this same fix with the adjustment of the tie rod ends. I added it to the list for the dealer to look at when it goes in for service
  14. Dec 2, 2020 at 1:48 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    If it’s bothering you the tie rod adjustment method is really quick and you can do it in your driveway with wheels on ground. Takes about 5 min. Here’s a direct link to a good video:
    https://youtu.be/YVdgWLD41Wc
  15. Dec 2, 2020 at 4:18 AM
    BigT27
    BigT27 New Member
    My new 2021 with 5 miles had the same issue. Went back to toyota and after 2 different trips they got it right. Maybe they don't test drive them in Texas before shipping?‍♂️
  16. Dec 2, 2020 at 6:55 AM
    coTony
    Tony
    Montrose, CO
    That is the number one return complaint from everywhere, the dealers, tire/alignment shops, etc. after an alignment. I used to work at Hunter Engineering and when we found out that was the number one reason dealers had returns after an alignment we invented a device that mounts to the steering wheel and while under the vehicle they can get the steering wheel level by themselves without needing help.
    Take it back tot he last place that aligned the vehicle... unless it has been a long time
  17. Dec 3, 2020 at 5:03 PM
    thomasbus337
    2020 TRD Sport DC
    So I had mine looked at today. The paperwork states that my toe was out of spec. The wheel is now straight going down the highway but it will drift slightly to the right if I let the wheel go, it didn’t do this before. Again, it’s been like this since new. Would uneven wear from bad toe cause the pull now that it’s properly adjusted?
  18. Dec 3, 2020 at 6:09 PM
    TriniMan
    TriniMan New Member
    SEAN
    South Carolina
    Its possible. Try swapping the front wheel left to right and see if the drift goes away.
