Steering Wheel Locked, truck won’t start
Discussion in '2.5 Gen Tundras (2014-2021)' started by CNE0207, Jan 12, 2020.
  1. Jan 12, 2020 at 10:11 AM
    CNE0207
    CNE0207 [OP] New Member
    Arvada, CO
    2020 Cement CM Limited
    So.... Here’s the back story.. I’m in the CostCo parking lot just loaded a new TV in the bed... go to start the truck and the dash reads steering wheel locked. Truck won’t start and wheel won’t unlock no matter what i do. After trying to jump it, locking and unlocking with the key fob 20 times or so, I give up and start dialing roadside assistance... I push to start one last time and BOOM magic the wheel unlocks rotates 45 degrees and the truck starts.... anyone else had this issue?
  2. Jan 12, 2020 at 10:12 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You turned the truck off with the wheel turned. You need to turn it slightly to unlock the wheel as you press the button. This will unlock the wheel.
  3. Jan 12, 2020 at 10:20 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    It's a Toyota thing - had it happen in my 07 Camry. Just wiggle the wheel back and forth, it does take some force, and it'll eventually unlock. Usually within 1 or 2 wiggles it does it for me.
    I'm curious if the display is the only indication in the new Tundras? In the older ones the indication is the key can't turn from off, so while wiggling the wheel I put a little pressure on the key and it eventually can turn. Does the display notification go away like the ignition key is allowed to turn?
  4. Jan 12, 2020 at 11:29 AM
    CNE0207
    Arvada, CO
    I was pretty much standing on the brake pedal and moving the wheel back and forth for a good 5-10 minutes, it was really stiff, wouldn’t budge. When it finally did unlock I didn’t even have my hands on it... it was strange but I’m thinking it must have been the angle and how I was parked.
  5. Jan 12, 2020 at 11:33 AM
    Ericsopa
    Ericsopa Old man and the sea
    For years now ALL makes and models, not just Toyota, have had locking steering wheels when the ignition is off. But the steering wheel is not actually locked until a pawl slips into the locking notch. The wheel can still be turned a few degrees in either direction. If, after turning the key off, you happen to pull on the steering wheel a little as you exit, and you hear and/or feel a click, you just locked the steering wheel. When you get back in you'll find that if you try and turn the steering wheel, it will not move at all in one direction . But in the other direction it WILL move a few degrees, but will have tension on it. So merely turn the wheel slightly in the direction that it will move, against the tension, then you can turn the key easily, or in the newer models, the push button will start the vehicle. You must remove the tension that is on the pawl inside the locking notch in order to turn the key or have the push button start activate. Jiggling the wheel serves little purpose. Just pull the wheel in the direction that it will move, even if only slightly, and you will relieve that tension on the locking pawl.
  6. Jan 12, 2020 at 11:46 AM
    CNE0207
    Arvada, CO
    I’ve had plenty of vehicles over the years, and had several lock up the steering wheel. But this time I guess was different. I’ll keep an eye on it, fingers crossed it was a combination of several things and just more difficult to get the wheel unlocked.
  7. Jan 12, 2020 at 12:49 PM
    15whtrd
    15whtrd Mr. Blonde
    One thing to keep in mind. Never shut your truck off and take the key out with the wheel completely cranked in one direction. When the steering wheel locks, it locks up against the steering stops. Giving you zero wiggle room to unlock the steering wheel with the key. Always back off the steering stops a little. A half a turn can do.
    NewImprovedRon likes this.
  8. Jan 12, 2020 at 12:51 PM
    CNE0207
    Arvada, CO
    I’m in the 2020 so its a push button... that adds a new feel to it. I’m definitely used to juggling the key while turning the wheel in previous vehicles... but the push button... new feel for sure
    15whtrd likes this.
  9. Jan 12, 2020 at 12:55 PM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    I’ve had the steering wheel lock up before in most recent vehicles but never had it to the point it wouldn’t easily disengage.
    It would royally tick me off if it couldn’t be undone in 5 seconds or less!!
    CNE0207[OP] likes this.
  10. Jan 12, 2020 at 2:18 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Yes this happened to me in my 2004 Toyota. Thought my ignition was going out (worn). Turns out my key was worn down from the thousands of insertions. Grabbed my spare
    And it worked perfect. So even with the worn key I’d get the chime and initial lights but wasn’t able to unlock the wheel or start the truck. Take a look at your key. If it’s not sharp anymore use the spare,
    if you have one , and see if that make a difference.
  11. Jan 12, 2020 at 10:04 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    He pulls in with the steering wheel turned and the front tires come up against the concrete parking stop. Truck is in park and the tires are against the stop making it hard to turn the wheel.
  12. Jan 12, 2020 at 10:18 PM
    G10dra
    G10dra Not a New Member
    Toyota has had this steering wheel lock feature since the 1990's or maybe older,
    This vid explains it
  13. Jan 12, 2020 at 10:33 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    This is more noticeable in our trucks because Toyota decided to remove the damn grab bar so we pull on our steering wheel to get in and out
  14. Jan 12, 2020 at 11:09 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Toyota has had this feature forever, my first car was an '85 Corolla, and pretty much every time I started it I had to put a little tension on the steering wheel to get it to unlock. I can imagine in the push start Tundras it's a little less second nature to get it to unlock, because I'm use to always putting tension on the wheel, and the key simultaneously to "feel it" - can't really do that with the push button.
    15whtrd likes this.
  15. Jan 13, 2020 at 5:12 AM
    NoRcptn
    NorCal
    2017 Platinum
    LOL , I read it so fast didn't see it was a push button :facepalm:
  16. Jan 14, 2020 at 9:54 AM
    Glockmeister
    Where did this info come from? :notsure:
    The OP didn’t mention any of that.
  17. Jan 14, 2020 at 11:12 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Speculation. I've been a tech for a very long time and towed for AAA/CAA for 10 years. We had so many people call in to say they couldn't turn the key in the ignition and their steering wheel won't budge. When we got there most of the time the front tire was up against something.
    The OP was very vague in his description so I took a stab at it.
  18. Jan 14, 2020 at 1:20 PM
    Glockmeister
    Gotcha. :thumbsup:
    The whole thing is just weird, pressure didn’t solve it and pushing the button again w/o pressure worked.
  19. Jan 14, 2020 at 1:23 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I think maybe that when the push button start is pressed the locking mechanism struggle to release because it's under tension. The OP mention on the second try it worked and the wheel spun 45°.
