Step guide for coil over install
Discussion in '2.5 Gen Tundras (2014-2021)' started by Youth is overrated, Oct 23, 2019.
  1. Oct 23, 2019 at 8:51 PM
    Youth is overrated
    Youth is overrated [OP] New Member
    2017 Silver Tundra CM TRD
    6112/5160 2.5 +2 driver 1 pass CB shims, CB+3 shackles,
    I’ve looked but have not seen anything, looking for a step by step guide to replace coil overs . Will be installing 6112/5160 setup this coming weekend. Just curious if anyone has put together a tips and tricks document to aid the process.
    Rica25 likes this.
  2. Oct 23, 2019 at 10:08 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  3. Oct 23, 2019 at 10:47 PM
    AYANG
    AYANG New Member
    Ontario, CA
    2016 Black Tundra Crewmax
  4. Oct 24, 2019 at 1:11 AM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    It’s not really a guide... but I did mine two days ago.heres my best attempt to help. You’ll need to unbolt the components in green and red. On the green portion there’s a bolt on top of your UCA that holds your bracket for your break line unbolt this and bungee your spindle to the back as to relieve tension on the lines. Unbolt your tie rod (red). If you have your sway bar still also (yellow line) this Will need to be unbolted. Keep in mind these parts are also pretty well bonded together and a hammer alone won’t separate them. I recommend the OEM tools ball joint separator as its cheap, works well, and has a warranty worked like a charm for me. Once all done Remove the bottom of the shock and slide it out. Pop your new ones in, rebolt everything back in, torque everything and off to get an alignment and your done. F99922A7-37FC-4F9E-AB39-D170F52050F2.jpg
  5. Oct 24, 2019 at 4:48 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    If your doing it yourself, make sure you eat your Wheaties !
  6. Oct 24, 2019 at 4:50 AM
    Youth is overrated
    Lol. Difficult is it?
  7. Oct 24, 2019 at 4:53 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    No, it's not difficult, And don't disconnect the spindle from the upper control arm..Watch a couple of youtube videos and you'll understand why.
    Edit : There are some writeups somewhere on this Forum..
    Omohundro likes this.
  8. Oct 24, 2019 at 4:57 AM
    Youth is overrated
    Alrighty thx
  9. Oct 24, 2019 at 4:59 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    I just did it this last weekend on my 2010 2WD. I unbolted the 2 under the spindle holding it to the LCA, and unbolted the one to the sway bar. Lastly I unbolted the bottom shock bolt and the 4 on top, Pried the LCA down with a long pry bar and removed the shock assembly. Reverse for re-install. Not sure if the same for a 4WD with the drive axle in the way.
    jeremyd likes this.
  10. Oct 24, 2019 at 5:00 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    This^^^^, don’t disconnect the spindle and upper control arm. It’s actually quite easy to do.
    jeremyd[QUOTED] likes this.
  11. Oct 24, 2019 at 5:00 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    yep, same on 4WD.
  12. Oct 24, 2019 at 5:14 AM
    They are correct...do NOT disconnect at the upper ball joint. Pull the 2 bolts on the lower end to swing the spindle out of the way. Also, since you will need an alignment anyway, loosen the lower control arm bolt and lower the arm instead of prying it. Trust us, it will be a lot easier that way.....that coil will slide right in. :thumbsup:
    chugs likes this.
  13. Oct 24, 2019 at 5:22 AM
    Youth is overrated
    Thanks for the pointers everyone! Hopefully I don’t SX crew anything up! Lol.
  14. Oct 24, 2019 at 5:24 AM
    Here is the install for Toyecs coils, but as mentioned, loosen the lower control arm bolt. You will be glad that you did.
  15. Oct 24, 2019 at 5:32 AM
    Youth is overrated
    Awesome! Thanks
