Sticky Leather
Discussion in 'Detailing' started by batclam, Apr 16, 2021.
  1. Apr 16, 2021 at 11:31 AM
    batclam
    batclam [OP] New Member
    2015 Silver Platinum
    I bought a used Toyota Tundra Platinum. I noticed that the dashboard leather was sticky to the touch. I thought it may be dirty so I tried to cleaned it with a mild soap and water solution. Cleaning did not help. I then applied a leather product I got from the Toyota dealer. This also did not help. The leather appears to be degrading or melting somehow? It has slowly started to progress to both doors. Any help would be appreciated.IMG_6558 - Copy.jpg IMG_6562 - Copy.jpg IMG_6561 - Copy.jpg
  2. Apr 16, 2021 at 11:36 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Never saw that in any leather equipped vehicles I ever had.
    My 2020 is not going that at all.
  3. Apr 16, 2021 at 11:42 AM
    biebs96
    PA
    Have you had the vehicle serviced recently?
    If so, was it at a place where they wipe down the interior as part of a sanitizing routine?
    cctxquicksand likes this.
  4. Apr 16, 2021 at 11:49 AM
    abomb
    abomb New Member
    2015 Platinum 4x4
    Watching to see if anyone else chimes in. I have a 2015 Silver Platinum as well with the exact same issue. Brought it to the dealership and they claimed it's not a "known" issue.
    batclam[OP] likes this.
  5. Apr 16, 2021 at 11:51 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Idk if it’ll help but I use chemical guys leather conditioner and mcquires leather cleaner.
    1/68AR Ventre A Terra likes this.
  6. Apr 16, 2021 at 12:16 PM
    batclam
    I have not had anyone touch the truck interior or cleaning since I bought it. I thought about emailing the chemical guys to see if they have heard or run across this.
    abomb, I am glad I am not the only one who has had this issue. I was told by dealer the same thing when I went to get an unrelated part and asked if they would look at it.
  7. Apr 16, 2021 at 4:39 PM
    Rocko9999
    Rocko9999 New Member
    When PU coatings-the coating that is on almost all leather in modern cars, starts to degrade it becomes sticky. I would post this in a detailing forum to see what can be done.
    Hi06silver likes this.
  8. Apr 16, 2021 at 5:29 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My 2014 w/215k miles isn't doing this. I use chemical guys quick leather detailer followed up with their conditioner
    War Machine likes this.
  9. May 14, 2021 at 12:33 PM
    wtjenk
    wtjenk New Member
    bill
    Tundra Platnum 2015
    I have a 2015 with 70K milage that has the same problem, have tried leather treatment soap and water nothing works. Gets worse every summer as soon as temperature reaches 70+. It is a know problem Toyota dealers only response it to replace the door panels and the leather stitching on the dash.
  10. May 21, 2021 at 8:50 AM
    abomb
    abomb New Member
    2015 Platinum 4x4
    I just came back from the dealer and for the dash pad and front passenger door panel (which are the melting ones on my truck) -- they wanted $1,300 parts/labor to do it. Confirmed that they will not cover this...
    I'll end up tracking down the parts and putting them in myself.
  11. May 21, 2021 at 9:19 AM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    My wife had a Camry that did this. The dealer replaced the dash under warranty, so it is definitely a known issue. My 2015 Tundra stays in the sun, I’m sure I will have the same issue as you at some point.
  12. May 21, 2021 at 9:35 AM
    jhuey8947
    jhuey8947 Affordable Auto Leather
    Tucson
    2019 TRD Pro Voodoo Blue
    C823A706-3B38-4578-ACDD-4B2B9ECE911F.jpg These parts just pop of with just a few clips. The vinyl then because of the heat will peel off the plastic with some ease and lil residue. The just wrap with choice of color.
    AZBoatHauler likes this.
  13. May 21, 2021 at 9:47 AM
    IndianaGeologist
    IndianaGeologist New Member
    This is something that happens in hot and sunny areas. In NM and AZ you'll see people put carpet on top of the dash to prevent the sun from breaking down their dashes (mostly plastic). My guess is the leather Toyota used has a treatment on it that doesn't do well in constant sun. Good sun screens for your windshield can protect this from happening, unfortunately I have know idea what can be done once the damage is there.
  14. Jul 23, 2021 at 8:33 PM
    Ealh
    Ealh New Member
    I have a 2014 platinum Tundra and all 4 doors are doing the same thing. It is very frustrating to spend this much for a vehicle to have this happen. I have written the CEO. Toyota should cover this! It’s ridiculous. Going to depreciate my truck.
  15. Jul 27, 2021 at 11:29 AM
    Etuck77
    Etuck77 New Member
    Ralpj
    15 Tundra Patinum 4x4
    Same here. 15 Tundra. Purchased with 40,000 on it. Did not notice til one hot Texas day detailing it and wiped the dash leather once and it almost peeled off leaving a few wrinkles in it kinda looks like blisters. The colder the weather it is fine. When it gets hot the stickiness just poor out and now the driverside ac section has started doing it. You can see my fingerprints embedded from simply touching it!
    IndianaGeologist likes this.
  16. Jul 27, 2021 at 11:47 AM
    IndianaGeologist
    That's unfortunate to hear as a fellow Texan with a new truck. Hoping my sunscreen protects the dash.
  17. Jul 29, 2021 at 9:24 AM
    15plttundra
    15plttundra New Member
    Same issue here: 2015 Tundra Platinum, Black Leather, Houston TX area
    Driver's Door and Front dash are degrading.
    The fake leather is defective/ failing under heat/ sun
    I have wiped my sticky areas with alcohol/ microfiber cloth. It takes the sticky residue and some of the color off. I was able to get it smooth again, treated it with leather cleaning/ conditioning products but with this week's 95+ temps, the sticky returned in the same two spots I previously cleaned, lasted about two months before returning. I notice it will cool and kind of re-seal overnight when it first turns sticky, but over time in the heat it gets worse.
    Looks like all other others with same problem so far have been black leather. Also looks like the door panels/ dash are the problem areas. no issues with the seats.
    Sounds like replacement is the only real solution. But how do we know we aren't buying defective replacement products?
    If I could re-seal the leather somehow, I would give that a try. It appears no cleaning/ conditioning products will solve the problem. No success stories on youtube I can find.
    Bottom line, Toyota sourced/ manufactured defective leather on these panel areas that cannot withstand heat.
  18. Jul 29, 2021 at 11:42 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    This isn't just Tundras that do this. My Civic EX-L did the same exact thing on the drivers side door panel. I put some silicone trim restorer on it and it helped a lot, at least for a while, but when it got really hot, it was sticky again. My door skins were vinyl, not sure if Toyota uses a nice faux leather or vinyl for those areas. If it is indeed leather, there must be a chemical reaction with the dye or tanning solution and heat. No help, I know, just stating that I've seen this in another vehicle.
  19. Aug 11, 2021 at 5:09 PM
    CoCotton
    CoCotton New Member
    2015 Platinum
    I'm having the same issue on a 2015 Platinum with 130k miles.
  20. Sep 5, 2021 at 9:22 AM
    Ealh
    Ealh New Member
    So I heard back from the Executive Secretary of Toyota (I emailed the CEO and CFO) and they had me take it to a Toyota dealership to have it looked at, and then the service manager would respond to her with his findings. Well, I heard back from her and she cannot find anything about recalls or such. Service manager told her it must have been from outside influences (duh) and since I am out of warranty, it would not be covered. She said the service manager told her $3900 and some change to replace them. I told her that was outrageous! Those panels can be found new for less. I would buy them and do it myself, but scared to mess it up. Wish that one part would come off and I could recover it. Oh well...
  21. Sep 5, 2021 at 11:39 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Back a few years ago they had a recall on the dashes of some Camrys because the leathers was sticky and falling apart. Had to take it into the dealer and the service manager had to write a ticket on it. They then ordered a dash and when it came in they called and set up appointment to replace it. Sounds like the same problem to me.
  22. Sep 5, 2021 at 11:39 AM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I have it on both front doors. 2014 Platinum 75k
  23. Sep 5, 2021 at 11:44 AM
    Black@Blue19
    Ken
    SE Texas
    Nothing y’all do is going to fix the problem. I thought my wife had did something and wouldn’t tell me so I tried a bunch of stuff??? It’s the materials they used it is sticky and acts like it is degrading/ rotting away!!! Toyota did not have a problem back then replacing the dash but it was a few years after we had purchased the vehicle before it started to happen. They replaced the whole dash to fix the problem!!!
    Want to say it was in 2014 or 2015 somewhere around there??
  24. Sep 13, 2021 at 12:37 PM
    MTP
    MTP New Member
    Matthew
    2016 Tundra Limited
    6 Inch Lift
    I have a 2016 Tundra Limited with same problem. The vinyl around the drivers side AC left vent adjacent to the door gets sticky and shiny when parked in the sun. When it cools off it leaves a white film. To me looks like bad adhesive used and it is bleeding through the vinyl. Problem started after a year. Does anyone know of recall or extended warranty to fix this problem?
  25. Sep 13, 2021 at 1:25 PM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Sunscreen and Bug spray can cause this. It breaks down the petroleum products in synthetic leather. Looks like most the photos are from heavily touched areas.
    eick and Kratos like this.
  26. Sep 13, 2021 at 7:20 PM
    MTP
    MTP New Member
    Matthew
    2016 Tundra Limited
    6 Inch Lift
    I removed the left front vent and looked at the backside. It is definitely a bad adhesive problem by Toyota. I placed it in the sun for 5 minutes and the adhesive glue became moist and sticky. Adhesive never cured properly. It obviously a defect that Toyota should fix at their cost.
  27. Mar 2, 2022 at 1:13 PM
    LaBaN_27
    LaBaN_27 New Member
    Iconwheelsand Toyo open countries, window visors, Bushwacker Xtend a Flare
    Did anybody ever get a fix for this? 2015 platinum
  28. Mar 16, 2022 at 10:10 PM
    Level7Tundra
    Level7Tundra New Member
    Ron
    2015 platinum here.. same problem. Very frustrating
  29. May 7, 2022 at 1:28 PM
    Crowbar310
    Crowbar310 New Member
    I have a 2014 Sequoia. Same issue on the driver door panel, color red/brown. Any solutions are welcome!
  30. May 8, 2022 at 5:24 PM
    MULLI63
    MULLI63 New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    Bought a 2015 Tundra Platinum in mint shape with 70K miles in March 2022. Was looking for a newer used, but this was decked out and had low mileage and a SnugTop on it. The bed looked like no one ever put something in it! I’ll post more in the new member intro section.
    Point of the above, is that even with the mint condition and the way the previous owner took care of the truck, the passenger side dash panel with the air register was a sticky mess. I thought it was just the detailer over saturating with armor all when they cleaned it up for me to take home, so I tried cleaning. Did not work, so I was on this forum and went through a variety of failed fixes. Warm soapy water, leather cleaner, leather conditioner, alcohol, WD-40 and nothing worked. Didn’t get worse, just started looking crappy as I was assaulting the leather. I decided to tear off the leather to see if I could just clean it up and put paint or plasti-dip on the plastic and make it look good. What I found out is that this is not leather, it is vinyl! I was trying to be so cautious since it was “leather”.
    I didn’t tear it off, I gave it a warm sudsy bath to clean off as much of the chemicals I had use on it and then after it dried I wiped it down with alcohol. Took off all the lint and other crap that was stuck to the pleather.
    Six coats of plasti-dip later and the leather looks amazing! I am looking forward to seeing how it holds up in the sun/heat and will update the thread after we experience some sun this summer. I live by the beach in SoCal where May and June are notorious for overcast, gloomy days (May Gray, June Gloom). Should heat up in July - October for a real test.
    To apply the Plasti-Dip, I removed the air vent (three easy screws) and then did two light coats, then two a bit heavier coats and then two fairly heavy coats. The sitching got a bit covered up in some areas and you can see that, so I would not do the heavier coats if doing it again. Would keep up the medium coats for the last two.
    The zoomed in picture is where the sticky area was. It looked really bad after I used all the chemicals and now it looks great.
    I know it’s not a solution, but it is an experiment in process!
    E36C8424-48AE-427A-B59A-97BE24CACD6C.jpg 51E79B89-8B6C-4C71-93B6-75D28456825E.jpg 3BD3ED9F-F66D-4525-A82F-83848F5031D9.jpg
