Stoptech rotor kit opinion
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra234, Jan 6, 2020.
  1. Jan 6, 2020 at 11:28 AM
    Tundra234 [OP] New Member
    Mgmtundra likes this.
  2. Jan 6, 2020 at 11:53 AM
    TheBeast The Beach
    yep no issues for the past 2 years. skip the drilled one, just get slotted.
    I run:
    StopTech slotted sport rotors (F and R)
    Posi Quiet ceramic brake pads (F and R)
    Flyinryank and Rex Kramer like this.
  3. Jan 6, 2020 at 12:21 PM
    Thanks. I'll see if their kits will let me select different pads on AutoAnything. I may have to purchase pads and rotors individually which might cost a little more.
  4. Jan 6, 2020 at 12:22 PM
    TheBeast The Beach
    that's what I did at the time. I don't see the slotted option only.
  5. Jan 6, 2020 at 12:39 PM
    They have non-Cryo for $109 per rotor and Cryo-treated for $130 per rotor treated. Rears are $98 for non or $120 for the treated. Front pads are $53.00
    https://www.autoanything.com/brakes/61A2722A0A0.aspx
    https://www.autoanything.com/brakes/61A4364A0A0.aspx
    These fit the rear... https://www.autoanything.com/brakes/61A4366A0A0.aspx
    https://www.autoanything.com/brakes/posi-quiet-pq-pro-brake-pads
    TheBeast[QUOTED] likes this.
  6. Jan 6, 2020 at 1:12 PM
    TheBeast The Beach
    if you do a lot of towing, Cryo might be better.
    GNTundra likes this.
  7. Jan 6, 2020 at 2:12 PM
    Just a 2200 lb popup camper is about the limit. Which of those pads would be the best? I am going to do all 4 corners.
  8. Jan 6, 2020 at 3:11 PM
    TheBeast The Beach
    I have the extended wear ones. so far so good.
  9. Mar 20, 2020 at 12:59 AM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Been researching this here. I'm am also looking for new brake rotors since my OEM warped, and its appears based on what I'm reading here in the Forum, no one has had any issues with Stop Techs. I have done some research and for trucks and for towing slotted rotors are the best option. Different results with Power Stops. Why would Cryo be better.
  10. Mar 23, 2020 at 7:14 PM
    Tundra-XP
    Will
    Great thanks for the info.
