Substantial shaking under downhill braking
Discussion in '2.5 Gen Tundras (2014-2021)' started by smslavin, Jul 9, 2018.
  1. Jul 9, 2018 at 6:04 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    so, this started yesterday and i need a little input.
    downhill sections of freeway, 6-8% grades and 50-70mph, truck was shaking substantially under braking. shaking increased with brake pressure. mainly came up through the steering wheel but there was some vibration in other areas of the truck.
    my first thought was warped rotors however, it does not occur on flatter sections of road either on the freeway or off. nor does it occur going uphill. also, the shaking from warped rotors tends to subside with more brake pressure. mine increased until speed dropped below 40ish.
    it did not appear to occur while we were in the dirt yesterday.
    truck is just shy of 24k. lift and 35s have been on for roughly 10k miles. it's been aligned once.
    looking for ideas on possible causes and what to check. i have not yet crawled under it as everything was a little too hot yesterday afternoon. might try to get under it this morning before things heat up.
  2. Jul 9, 2018 at 6:15 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Empty bed?
    Have the tires been rotated every 5k?
  3. Jul 9, 2018 at 6:19 AM
    smslavin
    Hudson Valley
    Some stuff
    bed is not empty. there's a topper and drawer system with full drawers plus an aftermarket bumper with a full size spare.
    yes, tires have been rotated every oil change. i do a 5 wheel pattern to rotate in the spare.
  4. Jul 9, 2018 at 6:56 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Still sounds like warped rotors. Maybe only start to warp when really heated up, like sustained downhill, not enough time to cool.
    Only reason I’m thinking this is I have a diamond blade in a chop saw,(wet/dry) was doing great no issues. Cutting pavers for backyard. When I made a few cuts back to back the blade warped bad. I thought I’d have to go get a new blade for two more cuts to be done. Well me being a cheap ass figured I could go slow and get two more cuts.
    By the time I got to them the blade had cooled and was nice and straight again.
    So, might still be warped rotors. For what it’s worth.
  5. Jul 9, 2018 at 7:04 AM
    smslavin
    Hudson Valley
    Some stuff
    thanks
  6. Jul 9, 2018 at 7:19 AM
    Remove rotors, scratch surface with Emory cloth, clean with brake cleaner.
    Remove pads, do the same with the brake pad surface.
    Lube pad pins with brake grease.
    I would have to do this to my factory Tundra brakes until I swapped them out at 60k miles.
    Maybe @landphil has some insite of the problem.
  7. Jul 9, 2018 at 7:21 AM
    smslavin
    Hudson Valley
    Some stuff
    i'll give that a shot one evening this week. thanks.
    ColoradoTJ[QUOTED] and 831Tun like this.
  8. Jul 9, 2018 at 8:04 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for posting this Sean. I had this happen on my '07 and never figured it out. It wasn't a frequent issue so I never fixed it. Thanks @ColoradoTJ, now I'll know what to try should the issue arise again on the '16.
  9. Jul 9, 2018 at 8:16 AM
    Grumpy Uncle
    Pat
    CO
    Maybe a slightly loose caliper? More weight shifted to the front because you're going down hill at speed.
    smslavin[OP] and NewImprovedRon like this.
  10. Jul 9, 2018 at 8:36 AM
    Macks
    Macks New Member
    Kevin
    Also check your front wheel bearings
    smslavin[OP] likes this.
  11. Jul 9, 2018 at 8:43 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
  12. Jul 9, 2018 at 9:12 AM
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    I had this happen on my Tacoma...Toyota replaced the rotors under warranty. Big difference between the two brake systems but symptoms are the same: hard to replicate on flat ground by shook like crazy when going downhill in the mountains.
  13. Aug 13, 2018 at 2:34 PM
    smslavin
    Hudson Valley
    Some stuff
    ok, so, i went through the steps that @ColoradoTJ outlined. last week we drove to telluride and back. traffic on 285 and over monarch wasn't heavy and moved steadily. as soon as the brakes got hot, everything started shaking. spent a lot of time cruising downhill in second and third.
    i'll be replacing pads and rotors. considering the following: powerstop z36 front/rear kit and ebc's stage 3 truck kit w/ greenstuff pads for front and rear.
    there is a significant price difference but, whatever, i want the truck to stop. especially when the girls are with me.
    i put powerstop on wifey's Q7 and they are holding up well with a significant improvement over stock. no noise. no dust. i had ebc on my FJ and was happy. Amazon reviews on the z36 kit are mix of positive and negative with a few mentioning warped rotors before 10k miles. reviews on summit are all positive. kinda sorta leaning towards the ebc setup but thought i'd pose yet another brake question to the tundra geeks and fanatics.
    so, what say you?
    Fuumanstu likes this.
  14. Aug 13, 2018 at 2:43 PM
  15. Aug 13, 2018 at 2:48 PM
  16. Aug 13, 2018 at 2:54 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Yup, just replaced mines. No more shakes.
  17. Jul 21, 2020 at 8:04 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
  18. Jul 21, 2020 at 8:10 PM
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    Mine are doing the same thing on my 19 CM. Will be changing out to the powerstop z36 system as soon as I have time and money
  19. Jul 21, 2020 at 8:30 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    I’ve had the best luck with new oem rotors. Turning them or replacing with after market or performance rotors have always led to one thing...warped again and way too soon.
  20. Jul 21, 2020 at 9:12 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Warp rotors. 110%. Get new ones problem solved 120%
    Charvonia Design and Tundyfundy like this.
  21. Jul 22, 2020 at 8:33 AM
    alpinepro4
    Pat
    Stick with new OEM sounds like the better route then?
  22. Jul 22, 2020 at 8:52 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    + 1 warped rotors
    +1 stick with OEM
  23. Jul 22, 2020 at 9:10 AM
    alpinepro4
    Pat
    Can you the the rotors. Or just get new ones?
  24. Jul 22, 2020 at 9:19 AM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    yeah sounds like a braking issue not tires. rotors could have hot spots so uneven spots where maybe you came to a complete stop when the brakes were super hot. or they're warped.
  25. Jul 22, 2020 at 9:21 AM
    sensei
    best recommendation is when you change rotors change the pads too. then look into doing some light bedding of the brakes and try to prevent coming to a complete stop when they're super hot (ie. a long downhill that requires plenty of braking).
  26. Jul 22, 2020 at 1:04 PM
    phabej
    phabej New Member
    This.. I always change them together. Pads are cheap!
    I've had good experience with "powerstop" slotted brands, does better than OEM for my Subaru. But that's just me.
    Above..
  27. Jul 22, 2020 at 1:34 PM
    alpinepro4
    Pat
    Ok, I will change out rotors with OEM again and new pads. Descending Teton pass often eats breaks even when gearing down. Shake getting bad.
  28. Jul 22, 2020 at 2:08 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I had a 2015 SR5, and currently a 2019 TRD Pro. I also live near the mountains. When coming down the passes I get the same thing if I overheat them. I avoid it by not letting the rotors overheat by using trans braking, though sometimes I still experience it to a smaller degree.
    While not 100% sure of the cause, rotors don't usually warp in the sense we think they do.
    What we sense as a warp is usually uneven transfer of material to the rotor from the pad. The "warp" is actually a sticky spot in the rotor that the pad grabs onto. I've saved a few rotors in my day by sanding the pad transfer material off, replacing the pads and re-bedding the pads correctly.
    If your rotors were truly warped or worn uneven, it would happen all the time. It sounds to me like they're getting really hot and you got one area of uneven pad transfer that is being exaggerated by the heat and becomes extra "sticky".
    If you have the money to throw around then by all means, replace them and re-bed.
    If not, you can sand off the pad transfer material with a DA sander and re-bed.
    This guy walks you thru it.
    https://youtu.be/5qB-jnANdTw
  29. Jul 22, 2020 at 8:37 PM
    phabej
    phabej New Member
    That 10% grade downhill by Jackson hole it's notorious for killing brakes.. if you mean that route
  30. Jul 23, 2020 at 7:35 AM
    alpinepro4
    Pat
    Yes I drive it 4 days a week. 5 in the winter. A lot of gearing down. Tourist don’t know how to drive the pass and ride there breaks all the way down. Seen a few run aways with big trucks. Now that scary. Generally the pass is safer in the Winter.
    phabej[QUOTED] likes this.
