Sudden Loss of Gas Mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by ppd1510, Mar 27, 2022.
  1. Mar 27, 2022 at 2:24 PM
    ppd1510
    ppd1510 [OP] New Member
    I've searched the forums and can't find a thread that fits this scenario.
    I've driven my 2015 Tundra 1794 for about 21 months before a rare snowstorm hit the area and knocked a bunch of trees down. I used the 4WD for the first time in 4H only.
    Prior to this snowstorm, I consistently averaged 15 MPG commuting to work and 17+ MPG on a long trip. This is all on factory tires/rims.
    After coming out of the snowstorm and disengaging the 4WD to drive normally again. My commuting gas mileage is consistently 13 MPG and my long trips are barely 15 MPG.
    I took the truck to the local Toyota dealership and they suggested cleaning the induction system, intake valves, and throttle plate and adding a solution to clean the fuel injectors...
    After all of this, no change in MPG! And no feedback from the service writer on the use of 4WD as a possible reason. I sense a very slight tension in the truck that I did not before, but I may be wrong since I'm trying to think of a reason for MPG loss without a tire/rim/lift change.
    Is it possible that the 4WD has not fully disengaged? Any other thoughts?
  2. Mar 27, 2022 at 2:29 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You'd know if the 4wd didnt disengage.
  3. Mar 27, 2022 at 2:50 PM
    ppd1510
    Agreed. And I've engaged and disengaged it again to make sure.
    14burrito[QUOTED] likes this.
  4. Mar 27, 2022 at 2:53 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    The rest of it just doesnt make sense, hence you reaching out.
    How many tanks have you been hit with the loss at?
  5. Mar 27, 2022 at 3:02 PM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Are you calculating your MPG's by hand or relying on the trucks computer?
    GODZILLA likes this.
  6. Mar 27, 2022 at 3:25 PM
    ppd1510
    Calculating by hand at each fill-up. The snowstorm was Jan 7th. More tanks than I can count and at least two 4-5 hour one-way drives and back, and a couple 1.5 hour drives. I've been monitoring this for awhile and figure this board would be a last resort.
  7. Mar 27, 2022 at 3:26 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Maybe a weird blend make it to your stations causing the drop in fuel economy.
  8. Mar 27, 2022 at 3:32 PM
    ppd1510
    I can't imagine that... I have a couple friends with trucks and they have not noticed anything. The first thing I checked was the tire pressure after having a discussion with them.
  9. Mar 27, 2022 at 5:20 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    I live in New Jersey and October 1st to April 1st they have winter blend gas here
    My mileage drops down to what your talking about 13---15 mpg after April it goes back up to around 18------21 Mpg Highway That's with my 2018 5.7 but I did notice after towing my mileage would not automatically go go the mileage before the towing maybe it's because it take the average of the gas in the tank , maybe your getting bad gas, go to a differant station, I only use Exxon or amoco not bp even its supposed to be the same. I found one Amoco station by my sons house and always get better mileage , you might have gotten bad gas Go to another name brand station
    Zoso and 14burrito like this.
  10. Mar 28, 2022 at 3:41 AM
    ppd1510
    I will try that. I do gas up at Sheetz locally, but on long trips, I have gassed up at the most convenient station.
    Thanks for the advice!
    Steplift20 likes this.
  11. Mar 28, 2022 at 4:02 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Might wanna check that all your brake calipers are functioning properly, since you felt a slight tension.
    Jaypown likes this.
  12. Mar 28, 2022 at 4:13 AM
    ppd1510
    Will do. Thanks.
    Casper3[QUOTED] likes this.
  13. Mar 28, 2022 at 4:22 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Hit your rotors with an infrared thermometer after driving. I thought I had a caliber hanging up on my boat trailer so I did this and compared to the truck. Both were right around 125 degrees.
  14. Mar 28, 2022 at 5:51 AM
    Steplift20
    2018 Tundra
    They are telling you to check the rotors to see if one of them is hanging up? Great advise ,this is what you can do very easy way to check
    After your driving awhile stop the truck get out and put your hand on the rim they should feel the same if one is hot that's the problem Check front and rear too.
    ppd1510[OP] likes this.
  15. Mar 28, 2022 at 5:53 AM
    Steplift20
    2018 Tundra
    After driving get out Nd feel the rims if one is hotter than the rest that's the one that's hanging up but I would suspect it's bad gas
  16. Feb 1, 2023 at 4:03 PM
    Crayzerbeam
    Crayzerbeam New Member
    '19 Quicksand 4x4
    I just had a similar problem as the OP. I used 4WD on Sat and my gas mileage after that was cut in half.
    I put the truck in 4lo, drove down my street a bit, then went to 4hi and then 2wd...it took a long time to get out of 4hi, but the problem went away and my mileage returned to normal.
  17. Feb 1, 2023 at 5:13 PM
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    Drive your truck and engage and disengage. Allow it to cycle fully each time. Repeat. Repeat.
  18. Feb 2, 2023 at 3:23 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    If you believe one or both front wheels are still engaged. Raise the front end of the truck and rotate each wheel by hand. The front drive shaft should not rotate.
  19. Feb 4, 2023 at 12:41 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    If they are still engaged you would notice as soon as you turned a corner.
