Sumo Springs or Timbren
Discussion in 'Suspension' started by NorcalHntr, Sep 12, 2021.
  1. Sep 12, 2021 at 8:47 PM
    NorcalHntr
    NorcalHntr [OP] New Member
    Nor cal
    2018 Sr5 Tundra Trd Crewmax Mgm
    Im getting a new lake boat that is about 4k and sag drives me crazy.
    Not sure how much there will be till I get it.
    Just found out about these products.
    Do they mess up offroad performance?
    Does upward travel change when unloaded?
    Can anyone enlighten me about these product
    Thanks in advance
  2. Sep 18, 2021 at 6:22 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I have the black Sumos and I really like them. My boat is about 4500lbs and with it and the box and back seat area full of vacation stuff have less than 1.5" squat. I really can't answer your other questions, although I fail to see how they could mess up off road performance, unless having less compression is a problem.
    I can't compare the Sumo with Timbren as I've no experience with Timbren. I'm very happy with the Sumos and there also 15% off this month when bought thru SuperSprings International.
  3. Sep 18, 2021 at 6:45 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I was considering them and asked a similar question earlier this year and my take is that the way to prevent disproportionate rear end sag and still utilize the full mechanical design of the suspension is to use airbags. Sure others will say otherwise YMMVJMHO
  4. Sep 19, 2021 at 6:18 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I will agree that air bags offer the ability to tailor the amount of resistance to suspension, but I wanted something simple and reliable, without compressors, lines and multiple ways for failure. SumoSprings offer that, cheaper to purchase and easier to install, should last as long as the truck with no moving parts or failures to be concerned about.
    But I agree YMMV, good luck!
    doggiecareman[QUOTED] likes this.
  5. Sep 23, 2021 at 11:12 PM
    Dansly56
    Dansly56 New Member
    daniel
    I run Timbrens and pull a 6000lb travel trailer and they’re awesome. When not towing you will feel them going over speed bumps
  6. Sep 24, 2021 at 7:42 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I have the blue SumoSprings and tow a 5k boat. No more sag. The ride is a little more harsh in the rear while towing but definitely feels more controlled. There is no noticeable difference well not loaded. If I do any kind of major off-roading I remove them. About 10 minutes each side. Other than that I leave them on. Hope this helps!!!
    Jhon, NorcalHntr[OP] and des2mtn like this.
  7. Sep 24, 2021 at 8:26 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Just thoughts, I've had the air bags on heavy trucks pulling 5th trailers that work well but when MTY you gotta drop air pressure and not allow air bad to have a vacuum. So to think of off roading could be a problem adjusting and a pain to get them right. The Sumo's or good for heavy loads and have them on motorhome but not good when light loaded. I have had travel trailers with equalizer hitches on them that levels out the load and keeps truck level. When done towing you take all off and you're back to normal on your truck. I've never done this on a boat but seems it would work, just thinking. Maybe you know someone who has this setup that you can borrow to test determining if this is an option.
    NorcalHntr[OP] likes this.
  8. Sep 26, 2021 at 3:19 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Looks like you’re leveled too?
  9. Sep 26, 2021 at 3:27 PM
    BIGUGLY
    Paul
    2018 Limited
    Equalizer hitches won't work for a boat. Especially going down a ramp in reverse
  10. Sep 26, 2021 at 3:28 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Im have. 3/1.5 lift. SumoSprings were able to make me a custom set to accommodate the lift. When towing I am just about level.
    Jhon[QUOTED] likes this.
