Supercharger install time and rate
Discussion in 'Performance and Tuning' started by cjscinta, Jun 14, 2022.
  1. Jun 14, 2022 at 2:41 AM
    cjscinta
    cjscinta [OP] New Member
    Nashville TN
    Could someone tell me how much time it takes to install a supercharger and what the average rate is? I thought I read somewhere it takes 8-10 hours. I was given a quote if 20 hours at $120/hour. Is that fair or does that seem excessive? Thanks
  2. Jun 14, 2022 at 2:59 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    counting the SC 8k(no tax) I was 10k out the door with tune, Figs intercooler bottle and dual catch can installed
    Platinum714 likes this.
  3. Jun 14, 2022 at 3:05 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I was was right @ $2k for the install.
    Peitz performance took about 14 hours. I had an issue with the goofy fuel pump wrench.
    I installed way back when running stage 1 Harrop untuned was cool.
    moving to stage 2 was ~$1800 - includes tune & parts.
    so...going straight to a "base" stage 2 Harrop should run you ~14k ish. all in.
    then, factor in the Diderot effect and you're looking at another $5k of shit you'll add - because you asked this forum questions. trust me - it happens.
    AZTundra and Platinum714 like this.
  4. Jun 14, 2022 at 3:22 AM
    cjscinta
    Nashville TN
    I already have the supercharger so it sounds like 2k might be the install price from what you are saying.
  5. Jun 14, 2022 at 3:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes. maybe add $1k for tuning & ancillary issues.
    ...because my initial install only had a before and after dyno run....no tuning. find a good tuning wizard.
  6. Jun 14, 2022 at 3:32 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ...AND
    if your shop does not normally install on Tundras.....make sure they have the goofy fuel pump wrench. I am not FFV, so needed to change the larger fuel pump.
  7. Jun 14, 2022 at 3:46 AM
    cjscinta
    Nashville TN
    So if I am FFV no fuel pump change?
    Chris996 likes this.
  8. Jun 14, 2022 at 4:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I think so...you FFV guys have larger fuel pumps already.
    be sure to tell the folks you have an FFV...y'all have special shit (in a good way).
    there many are folks on here that did FFV.....I'm not one of them.
  9. Jun 14, 2022 at 6:15 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    20 hours is in the ball park if they include other services in that figure and not just bolting on the blower. It seems a bit on the high side otherwise.
    The shop I used broke out 14 hours for the Harrop and 2 for the fuel pump (they have to drop the tank). It could be the Magnuson requires more or less time.
    Labor rates will change by region.
    nobodyintexas and snivilous like this.
  10. Jun 14, 2022 at 6:46 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    14 to 16K for everything including fuel
    (improvements). That was from ProSpeed for the Harrop stage 2
  11. Jun 14, 2022 at 7:24 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sounds like I got mine installed pretty cheap. Bought the Harrop for 7200 on sale, 7400 with shipping. Install including stage 2 parts was 870 bucks. Remote Tune with a MPVI2, injectors and smaller pulley were another 2000. Boost and AFR gauges were installed with the blower and cost $330, plus the flex pod mount was maybe 150 bucks. I know the install labor was low for me, I’m a long time customer of my mechanic’s who just works in his home garage when he’s not at his day job as a mechanic. Most could expect to pay double that for labor.
  12. Jun 16, 2022 at 3:05 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Here was my breakdown:
    Saltyhero13 and reywcms like this.
  13. Jun 17, 2022 at 6:17 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    SC was about 8k delivered, plus 450 for boost gauge and wideband, plus 800 for stage 2 pulley and injectors. Tune was about 500. So all in was about 9750. I also did plugs and coolant flush so definitely under 10k. I installed it myself, easy. It gave me a project to focus on.
    I didn't need the fuel pump swap as my truck is FFV.
  14. Jun 17, 2022 at 6:23 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Longo Toyota?
  15. Jun 17, 2022 at 6:27 AM
    ZPhilip
    Philip
    West Chester, PA
    Nah my name is Longo. Install done at RT Tuning in Montgomeryville, PA.
    FISHN43[QUOTED] likes this.
  16. Jun 17, 2022 at 6:28 AM
    FISHN43
    FISHN43 New Member
    Ohio
    What are the odds!?!? Lol
    Thanks!
  17. Jun 17, 2022 at 6:29 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Took around 20hrs, I think a competent mechanic and experienced can do it in 10hrs or less.
    Jcmf52 likes this.
