Sway bar end link bolts/nut
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaxfljustin, Aug 30, 2024.
  1. Aug 30, 2024 at 11:23 PM
    jaxfljustin
    jaxfljustin [OP] New Member
    Making this post just for historical purposes in hopes it may help someone save alot of time and headache if they search.
    Long Story short, upgraded sway bar in the front on my 2.5gen tundra. There is a loosely captured nut on the lower control arm and a bolt runs through the link into that nut.
    Mine was rusted and became a free-range nut. The dealerships parts lookup will tell you the nut is not sold separately and you have to buy the whole control arm and replace.
    After spending too much time looking around I have found the 2 part numbers needed and have installed them back and working great. There is enough room to get the open end of a wrench on the nut to torque it down. These should be the same for 2007-2021.
    90178-A0085
    Suspension Stabilizer Bar Link Nut (The one thats captured inside the lower control arm)
    90119-A0278
    Suspension Stabilizer Bar Link Bolt
    equin, ejes and ChesterTundra like this.
