Sway bar install question
Discussion in 'Suspension' started by BHarry, Nov 10, 2017.
What is the best install location for the TRD sway bar?
  1. Bottom of axle
    7 vote(s)
    58.3%
  2. Top of axle
    0 vote(s)
    0.0%
  3. Rear of axle
    5 vote(s)
    41.7%
  1. Nov 10, 2017 at 10:36 AM
    BHarry
    BHarry [OP] New Member
    Northern Nevada
    2014 BRM CM TRD
    I just purchased a TRD sway bar and was thinking about doing the install pretty soon. I have seen several posts talking about the installation and was looking for some opinions. I know the recommended installation is with the brackets on the bottom of the axle, but I have seen some that were installed on the top of the axle as well. I have also been told that you can mount it to the back of the axle 90° from the typical position.
    It seems like the factory installation would be the most effective set up, but it does hang lower and limit your clearance. I know the sway bar is not great for off-road anyways so that may be a moot point. Any input is greatly appreciated.
    OBXTundra likes this.
  2. Nov 10, 2017 at 10:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This has been discussed in other relative threads, dig around some. :thumbsup:
    Law323 likes this.
  3. Nov 10, 2017 at 10:47 AM
    ToyotaTundraMike
    2015 Tundra
    Think some members have found an easy way to remove it when going offroad. Seems like that would be your best option.
  4. Nov 10, 2017 at 11:24 AM
    BHarry
    Northern Nevada
    2014 BRM CM TRD
    Looks good! I had read they function the same regardless of mounting location, but I have also heard that changing the location changes the angles and reduces the effectiveness. Thanks for the input and pics!
    NewImprovedRon likes this.
  5. Nov 10, 2017 at 1:31 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    The angle of the dangle depends on how much you've lifted the rear of your truck. Here's mine with OME/Dakars and CB+1:
    [​IMG][​IMG]
    CJ21, BHarry[QUOTED][OP] and Sunnier like this.
  6. Nov 10, 2017 at 1:54 PM
    BHarry
    Northern Nevada
    2014 BRM CM TRD
    Mine is stock in the rear, it is leveled in the front.
  7. Nov 10, 2017 at 2:05 PM
    TheBeast The Beach
    I like jberry setup. Mine installed the way Toyota has it but it does hang a bit lower than jberry setup
  8. Nov 11, 2017 at 7:24 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Heard my name three times.
    Spolar, Law323, BHarry[OP] and 3 others like this.
  9. Nov 11, 2017 at 9:42 AM
    mphatrik
    mphatrik New Member
    IMG_20171111_104024780_HDR.jpg From the factory.
    CJ21, BHarry[OP] and NewImprovedRon like this.
  10. Nov 15, 2017 at 4:43 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    With an SOS lowering kit.
    CJ21 and BHarry[OP] like this.
  11. Nov 15, 2017 at 5:50 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    makes no difference in function. Simple physics. You'll be good to go either way.
    T500 likes this.
  12. Nov 15, 2017 at 6:03 AM
    Rex Kramer
    Georgia
    Correct!
    You want to have the end links positioned as close to vertical as possible.
    Wynnded likes this.
  13. Nov 15, 2017 at 9:01 AM
    TheBeast The Beach
    isn't your spare supposed to be the other way to gain a bit more clearance ? just wondering. Mine is positioned the same way the poster above you.
  14. Nov 15, 2017 at 9:21 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Is the consensus that you can mount the sway bar up 90 degrees, on the rear of the axle, as to not lose ground clearance?
    Law323 and NewImprovedRon like this.
  15. Nov 15, 2017 at 10:47 AM
    Rex Kramer
    Georgia
    It's above the scrub line, so it's good to go.
    BHarry[OP] and Wynnded like this.
  16. Nov 15, 2017 at 3:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've never seen that info before, good find.
  17. Nov 19, 2017 at 12:32 PM
    BHarry
    Northern Nevada
    2014 BRM CM TRD
    Well after putting way too much thought into this, I decided to do the install today. I began the process thinking I would mount it to the rear of the axle, but I did have a change of heart halfway through. My thinking was the engineers at Toyota know a lot more about this stuff than I do... Though I did lose a very small amount of clearance, I do like the idea of having the end links close to vertical. At the very least, it can’t hurt! I could see it being beneficial to mount it to the back of the axle if you have a lift.
    Thank you everyone for your input and I hope this thread will help others in the future.
  18. Nov 19, 2017 at 12:49 PM
    Rex Kramer
    Georgia
    That looks like a text book installation - enjoy!
    BHarry[OP] likes this.
  19. Nov 19, 2017 at 1:20 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks great, mine is arriving this Tuesday, and couldn’t decide in which way i wanted to install it, after reading your post im going to install it per instructions.
    BHarry[QUOTED][OP] likes this.
  20. Nov 19, 2017 at 1:24 PM
    Rex Kramer
    Georgia
    1. Bottom of axle = standard installation location.
    2. Top of axle = when would you do this, and why?
    3. Rear of axle = installation location when the rear is lowered.
  21. Nov 19, 2017 at 1:40 PM
    Ely010606
    SPARKS, NV
    Mine is stock, so your saying #3 is ok to install. Thanks
  22. Nov 19, 2017 at 1:52 PM
    Rex Kramer
    Georgia
    I believe #1 is best for stock.
  23. Nov 19, 2017 at 2:19 PM
    Ely010606
    SPARKS, NV
    Kool thanks.
  24. Nov 19, 2017 at 2:54 PM
    BHarry
    Northern Nevada
    2014 BRM CM TRD
    This was one I’ve seen on here. It has a 7in lift.
    https://www.tundras.com/posts/364876/
  25. Nov 19, 2017 at 3:50 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Rex don't care about clearance...Rex truck is lowered.
    Rex Kramer likes this.
  26. Nov 19, 2017 at 4:26 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Anyone know if @Roman is doing free shipping on TRD rear sway bars for BLACK FRIDAY or CYBER MONDAY from Cool Springs Toyota?? I need to get one.
  27. Nov 19, 2017 at 4:42 PM
    Ely010606
    SPARKS, NV
  28. Nov 19, 2017 at 6:59 PM
    BHarry
    Northern Nevada
    2014 BRM CM TRD
    Will do, thank you!
  29. Nov 19, 2017 at 7:36 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    one of the best mods I did. I had a flat on a loaded dump trailer and this literally helped me stay on the road in time to pull over and change the flat....so glad I added this to my tundra
