Switch Pros SP-9100 Install
Discussion in 'General Tundra Discussion' started by Bailey, Feb 6, 2018.
  1. Feb 6, 2018 at 11:55 AM
    Bailey
    Bailey [OP] Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Hey Everyone!
    I wanted to share a few photos of my Switch Pros SP-9100 Install on my 2010 Tundra.
    I plan on adding a small variety of accessories down the road and this makes it very easy to do so. This also makes it easy to run the fog lights anytime (I'll get there :cool:). For those that aren't aware, the Switch Pros SP9100 is a very high tech solid-state power module that features 8 circuits for lighting and electrical accessories (4-35A, 4-18A). These circuits have a nice amount of programmable features like momentary, flash, dim, strobe :goingcrazy:, and more). All you have to do is install the power module under the hood, run the very thin switch cable inside, and mount the switch panel... It's that easy! But I wanted to make it a little bit easier.
    What's all included (color coded wires on SP-9100, was red on SP-8100):
    I went ahead and mounted the Power Module to the underwood fuse box cover. I also picked up a distribution block from Frys and ran the individual wires to that. This allows me to simply unscrew the block hardware and attach the accessory wire. No crimping, soldering, or splicing.
    The wires are color coded as follows:
    Switch 1 - Brown (18A)
    Switch 2 - Red (18A)
    Switch 3 - Orange (18A)
    Switch 4 - Yellow (18A)
    T1* (Trigger) - Pink
    Ground - Black
    LT** (Interior Lights) - White
    Ignition*** - Blue
    Switch 5 - Green (35A) 2 Wires
    Switch 6 - Blue (35A) 2 Wires
    Switch 7 - Purple (35A) 2 Wires
    Switch 8 - Grey (35A) 2 Wires
    *Trigger. Allows a trigger to control up to 4 circuits. I am going to run the Baja Designs fog lights to switch 1 and the OEM fog wire to T1 (Pink). When I activate switch 1 I will be able to turn on the fogs anytime. I will also have control over the fogs using the factory stock on the steering column.
    **Interior Lights. This allows the backlighting to be dimmed when your headlights come on. You can pre-set the color and brightness in the switch pros app.
    ***Ignition. Gives power to panel when vehicle is started. Prevents lights or accessories from being left on without the car on or keys inside. Run directly to battery if you want to bypass.
    Here is how everything looks mounted underneath the hood:
    For the Switch Panel I decided to mount it somewhere that could easily be reversed or changed. I chose the cubby directly in front of the shifter. Here is how it looks mounted:
    Vehicle OFF
    Vehicle Running (backlight on full brightness)
    Vehicle Running and Headlight ON (backlight dimmed to match interior)
    And a zoomed out pic showing how it sits compared to the other interior lights. I'll be fine tuning the color and brightness when it gets dark tonight.
    Hopefully this helps give some people ideas of how or where they'd mount their SP-9100. So far I'm very happy with the product and plan on messing around with it more once I get more lights!
    Can't wait to see what the strobe, flash, and dim do.... dance party? :taco::kona::jellydance::dancingbacon::broccoli:
  2. Feb 6, 2018 at 12:20 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I’m jelly. I want
    Erichudgins and Notachickmagnet like this.
  3. Feb 6, 2018 at 12:37 PM
    Bailey
    CO
    Let's see a REAL write-up :boink: ...something like this here.
  4. Feb 6, 2018 at 12:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    one of these days... need to pay for my new wheels.. then sliders .. then I can get the 9100 but i'll need to get more lights from @Baja Designs ... its never ending..... arrghhhh :annoyed:
  5. Feb 6, 2018 at 12:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Curious is there a reason you mounted the 9100 to the fuse cover? I was planning on using SDHQ engine compartment mount.
    831Tun and dcsleeper408 like this.
  6. Feb 6, 2018 at 1:23 PM
    Bailey
    CO
    dcsleeper408 likes this.
  7. Feb 6, 2018 at 1:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  8. Feb 6, 2018 at 1:34 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Very clean setup Bailey!
  9. Feb 6, 2018 at 1:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, nice and clean!
  10. Feb 6, 2018 at 1:44 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    nicely done bailey. it's nice that they color coded the wires on this version and the distribution block was a great idea.
  11. Feb 6, 2018 at 1:54 PM
    Great write up.
  12. Feb 6, 2018 at 2:00 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Can you program certain lights to automatically turn on when trigger is active?
    Does trigger take a +12 signal?
    My plan is to run certain lights to go on with my high beam :D
  13. Feb 6, 2018 at 2:42 PM
    Bailey
    CO
    Thank You! :cheers:
    Thanks! I wasn't about to have wires sitting around under the hood. Trying to keep it as clean as possible :cool:
    Yes you can!
    All you need to do is run the High Beam + to the Pink Wire. With the app you can program up to 4 circuits to activate when the trigger is active... That would allow a lot of light! :eek:
  14. Feb 6, 2018 at 2:55 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Sounds like a plan :rolleyes::D
  15. Feb 6, 2018 at 3:00 PM
    geno0506
    geno0506 New Member
    Michael
    Awesome write-up and looks great!
  16. Feb 6, 2018 at 6:49 PM
    Bailey
    CO
    Thank You! :D
  17. Feb 6, 2018 at 6:51 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @BaileyJ when are we going to get to meet the man at Baja design?!
    @BlueBottle is putting together a meet soon.
    Or you can roll with us on a run sometime soon?
    BlueBottle likes this.
  18. Feb 6, 2018 at 6:52 PM
    Bailey
    CO
    It's looking like the CO crew is going to meet me before the NorCal crew. Heading out the 11th and don't plan on turning back :mudding:
  19. Feb 6, 2018 at 6:53 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks nice and clean!
  20. Feb 6, 2018 at 7:08 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I can’t say it doesn’t look better than my craftsmanship! Very nicely done @BaileyJ
    Do you find the buttons to be sensitive enough? On my 8100 the smartphone app is my preferred button system, but then again I didn’t mount it right next to the shifter. I’m holding out for SDHQ’s sunglasses pocket mount if it happens anytime in the near future
    geno0506 likes this.
  21. Feb 6, 2018 at 7:21 PM
    Bailey
    CO
    :hattip:
    I haven't had enough time to mess with the app although it worked fine when I set the color. I don't plan on using the phone app too much since they always seem to be finicky (maybe it's the user)
  22. Feb 6, 2018 at 7:23 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I’ve had a few issues but it’s more suitable for me........for now
  23. Feb 7, 2018 at 8:30 AM
    wasabi4
    wasabi4 New Member
    Lee
    2017 Limited CM 4x4
    This thread just made me pull the trigger on getting the 9100.
    @BaileyJ how do you locate the wire for the fogs?
  24. Feb 7, 2018 at 8:40 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Very nice! Clean install!! After seeing the features of the switch pros this makes me want to pull the trigger and upgrade my "ghetto pros" lol
  25. Feb 7, 2018 at 8:53 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    :thumbsup:
  26. Feb 7, 2018 at 9:55 AM
    Bailey
    CO
    I'll be posting up how I ran the fog wiring soon. Hopefully today or tomorrow! I'm going to be using the OEM connectors to avoid any splicing or cutting of the OEM electrical.
  27. Feb 7, 2018 at 9:55 AM
    Bailey
    CO
    Lol! :rofl:
  28. Feb 10, 2018 at 3:52 PM
    Bailey
    CO
    https://www.youtube.com/watch?v=2XlP5lUz9PQ
    Noob to youtube and videos so I apologize about sound or shakiness. Quick demonstration of the flash function found on the Switch Pros SP9100. I want to utilize the flash when conditions are very poor and during emergency situations. The Front Baja Designs Squadron Sport Fogs and the Rear Baja Designs s2 Sport have the ability to be ran as ON/OFF or Flash. When the switch is pressed once the lights will come on. When the switch is double pressed (like double click) the lights will flash. All of these switches can be programmed using the Switch Pros app.
    Baja Mike and BlueBottle like this.
  29. Feb 10, 2018 at 4:45 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Cant wait to get mine installed, i made the rookie mistake of pre stickering the switches and then realized my baja designs bars need to be on the bottom 4 switches!
  30. Feb 16, 2018 at 3:21 PM
    Sahara200
    Sahara200 New Member
    Charles
    Land Cruiser 200 Series Sahara
    None at this point, just got it...
    G'day guys, just landed here from Sydney after searching for info on the Switch Pros system. Thanks BaileyJ for your post which bought me here.
    Just got an LC 200 Series and I'm wanting to fit one of these babies to it. I probably should ask this question of the manufacturer but hey, I figured I might draw on your guys experience and get a quicker response.
    The manufacturer says the power module is solid state but it has no high current 0V (negative) connected and no heatsink so is it really solid state or a bunch of low profile relays under the potting?
    BTW, I'm an auto sparky but no electronics guru...
    Cheers, Charles
    NewImprovedRon and Bob like this.
