Switch Pros Trigger wire, What to use them for?
Discussion in 'Electrical' started by NoMoreGreen, Aug 27, 2023.
  1. Aug 27, 2023 at 3:18 PM
    NoMoreGreen
    NoMoreGreen [OP] New Member
    Robert
    2020 Tundra
    I just finished (Well is it ever finished?) Installing and RCR force 12 on my truck. (2020 Tundra) But I am left with the 2 triggers wires I am unsure what to do with.
    I had the thought of hooking up to the Reverse lights but I couldnt find a fuse to that.
    Give me some other ideas to hook these triggers up to? Toss out all of the ideas.
  2. Aug 27, 2023 at 3:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :notsure:
    I've never found a use for the triggers.
    reywcms and NoMoreGreen[OP] like this.
  3. Aug 27, 2023 at 3:34 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I use one for the backlight trigger when the headlights are on, and the other for the factory fog light circuit. @BiggHertz did some fancy shit with his.
    BiggHertz likes this.
  4. Aug 27, 2023 at 3:38 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    831Tun and TRDFerguson[QUOTED] like this.
  5. Aug 27, 2023 at 4:07 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  6. Aug 27, 2023 at 4:09 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    He can have the title of unicorn. Haha
  7. Aug 27, 2023 at 4:57 PM
    NoMoreGreen
    Robert
    2020 Tundra
  8. Aug 27, 2023 at 5:07 PM
    sandboxjoe
    sandboxjoe New Member
    Joe
    Chandler, AZ
    2018 Cement Crewmax
    A little bit of this... A little bit of that.....
    On my truck I have trigger 1 tied to high beam (fuse box under hood) to activate (2) LP6. Trigger 2 is tied to reverse (behind passenger side kick panel) to activate (2) S1. The high beam fuse is easy to find and it wasn't hard to wire in the reverse trigger.
  9. Aug 27, 2023 at 6:10 PM
    NoMoreGreen
    Robert
    2020 Tundra
    The fuse for the reverse lights is passenger side kick panel huh? I’ll have to look there.
  10. Dec 29, 2023 at 8:08 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    any more info on where it is under the kick panel? Seqouia build here and replacing the rear reflectors with Kc cyclones tapped into the factory back up lights, but want to tap the switch pros so I can turn them on at anytime
