Synthetic oil change how often?
Discussion in '2nd Gen Tundras (2007-2013)' started by srwiles, Sep 9, 2019.
  1. Sep 9, 2019 at 8:17 AM
    srwiles
    srwiles [OP] New Member
    Stephen
    TN.
    white 2012 Tundra SR5 4 door
    by fold cover
    talked to an engineer about synthetic oil changes, according to him 10,000 miles easy between changes. feed back thanks
  2. Sep 9, 2019 at 8:27 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    My 2015 manual says if you are using the 0W-20 that 10000 miles is fine. Excerpt
    Your vehicle is certified withGenuine Toyota 0W20 motor oil. ForVEHICLES CERTIFIED FOR 0W20 motoroil, the oil change interval is 10,000 milesor 12 months IF 0W20 MOTOR OIL ISBEING USED. If 0W20 is not available,5W20 mineral oil may be used. However,it must be replaced at A 5,000 miles or6 month INTERVAL with 0W20 motor oil.
    Les7311 and srwiles[OP] like this.
  3. Sep 9, 2019 at 8:32 AM
    Blueknights75
    Ron
    Clayton, NC
    There are several topics in this forum regarding this question.... if your engine is FFV Toyota recommends 5k mile oil change intervals. If your engine is not FFV then the recommended oil change interval is 10K miles. There have been several members who have had their oil analyzed after 10k miles and it still had plenty of life.
    GODZILLA and omgboost like this.
  4. Sep 9, 2019 at 8:37 AM
    srwiles
    Stephen
    TN.
    by fold cover
    Thank you from Tn.
  5. Sep 9, 2019 at 8:53 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Thanks for asking this. I was thinking about doing it every 5k, but I may do one at 10k and send it in for analysis. On my BMW, they suggest 15k but I will change at 7.5k or 10k.
  6. Sep 9, 2019 at 9:11 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    I'm changing mine every 5k miles.
    MJoeP, Parrothead_DFW and Y0TA PR0 like this.
  7. Sep 9, 2019 at 9:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    FFV here and I change at 10. According to a service advisor I talked to there is no difference in the oiled parts. Just pulled dipstick at 6k and oil is golden.
  8. Sep 11, 2019 at 2:49 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Does a change oil light come on or a service indicator light somewhere on the dash?
  9. Sep 11, 2019 at 3:27 PM
    On the 07-13, a maintenance required light will come on at the 5,000 mile mark. I think the 14 and up has digital display.
    Yodder J[QUOTED] likes this.
  10. Sep 14, 2019 at 6:01 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    On my 2008 5.7 it has had 10,000 change intervals since about 5000 miles on the ODO. I use Mobil 1 5/20 or 0/20. I fit in normal service for the most part. If you do lots of hauling, towing, city driving or dusty roads you will want to shorten the interval or get a used oil analysis.
  11. Sep 15, 2019 at 7:52 PM
    Black4X2
    Black4X2 New Member
    Bill
    2007 Black Tundra Limited 4X2
    5000. It's pretty black by then.
  12. Sep 15, 2019 at 9:13 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    My cap says 5/30 but my manual says 0/20 or 5/20.
    I use 0/20 and change every 5K. Sometimes I will disregard the 5K and go 6-7K.
  13. Sep 15, 2019 at 9:31 PM
    DEAD HORSE.....
  14. Sep 15, 2019 at 9:32 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    X2
    Black Wolf likes this.
  15. Sep 15, 2019 at 9:34 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    So how you like your 14 compared to your 07?
  16. Sep 15, 2019 at 9:38 PM
    Much better interior with the Limited. The 07 was fun building it with the best bang for the $, but this go round will even be more fun, and doing the same thing...best bang for the $ and will not only look kuul but will also take me wherever I want to go.
    Y0TA PR0[QUOTED] likes this.
  17. Sep 15, 2019 at 9:42 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Your 07 was bad a$$ looking!! Im sure this one will look just as good!
  18. Jan 1, 2020 at 2:29 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  19. Jan 1, 2020 at 4:37 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  20. Jan 1, 2020 at 10:04 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    +1 at 5,000
  21. Jan 2, 2020 at 3:39 AM
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    I'm guessing Toyota is playing it safe and recommends changing out 5W20 sooner since they don't test that oil as thoroughly as 0W20 which they can guarantee works properly in the truck.
  22. Jan 2, 2020 at 3:42 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    If "playing it safe" means managing their factory warranty risk then you are correct.
  23. Jan 2, 2020 at 4:20 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I change mine every 5K miles as well.
  24. Jan 2, 2020 at 9:44 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Both are completely capable of 10k oil changes. At operating temp, they’re essentially the same oil. Toyota aint splittin hairs there.
    The difference between 5k and 10k oil changes recommendations from ‘Yota is based on usage(heavy/lots of towing, dirt environment etc)or fuel.
    Flex fuel(e85) can be brutal on oil. It takes 30% more e85 to operate over gasoline, so over 10k miles, you’re using a lot more fuel, increasing the possibility of diluting oil. Fuel diluted oil doesn't lubricate.
    In short, unless your really truckin’ or using e85, changing your full synthetic at 5000 miles is a waste of resources.
  25. Jan 2, 2020 at 10:04 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Understanding oil is 1st step in answering the question.
    Conventional oil has additives to allow it to be pumped easily during those frigid conditions during cold starts. These additives break down over time and begin to clump inside of the engine, around 2500 miles. So called synthetic oil is usually group 4 oil which is conventional oil that has gone through a different refining process to remove sulfur. This so called synthetic oil is allowed to be called synthetic only in the US of A, no other country calls it synthetic. The additives in this oil break down around the 5000 mile mark. True group 5 oil is man made and therefore is recognized as synthetic around the world. This oil can go alot longer, Amsoil says up to 15k miles between change intervals and in ideal conditions even longer.
    Science is getting better, presently the additives in conventional oil and so called synthetic oil are getting better and can hold together longer which is making some oil have longer change intervals. I haven't kept up with the brands but if you do some research I am sure you can get info on who makes actual group 5 synthetic oil, it is not much more $$ than group 4 synthetic but it is a superior product.
  26. Jan 2, 2020 at 10:13 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Is this the 2nd or 3rd gen forum? I got lost.
  27. Jan 3, 2020 at 9:41 AM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    Even good oil and filters are cheap, I change mine with Mobil 1 every 5k.
  28. Jan 3, 2020 at 9:59 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I do 5k for warranty reasons but wouldn't hesitate to go 10 after it expires
  29. Jan 3, 2020 at 10:31 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I go 5k, always have. I'm sure synthetic can go much longer it's the filters I question.
  30. Jan 3, 2020 at 10:45 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    10k all day with M1 FS and TRD filter. 180k and still runs like new and 190 psi across all 8 cylinders at ~175k
    Larly5000 likes this.
