Tail Lights with Amber Turn Signal
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlexJet, Nov 3, 2020.
  1. Nov 3, 2020 at 4:27 PM
    AlexJet
    AlexJet [OP] New Member
    2021 TRD Offroad CrewMax
    Does anyone knows is there an option of getting Tail Light for 2018+ Tundra with Amber Turn Signal?
    I have been browsing this forum and Internet, but so far can't find such Tail Light.
    All previous generations of Tundra's had Amber Turn Signals, but the last one lacks them out.
  2. Nov 3, 2020 at 4:53 PM
    None that I have seen.
  3. Nov 3, 2020 at 4:59 PM
    Nobody makes them. I would prefer a amber turn signal also.
    Durania likes this.
  4. Nov 3, 2020 at 5:07 PM
    Yeah the only option for an Amber signal is the Muth mirrors at $200 for a set.
  5. Nov 3, 2020 at 5:08 PM
    Or a Dremel, orange plastic and super glue.:D
  6. Nov 3, 2020 at 5:40 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Mountun Goat and ElNopal like this.
  7. Nov 3, 2020 at 5:42 PM
    biebs96
    PA
    I’ve been thinking about making the reverse light an amber turn signal.
    The abandoned red turn signal would be an additional brake light.
    Then I would have to figure out a legal reverse light. It seems in my state, one lamp is acceptable and it can be anywhere on the vehicle (ie. an led license plate bracket lamp)
    ElNopal likes this.
  8. Nov 3, 2020 at 5:44 PM
    BlueRibbon4x4
    Geno
    That’s the simplest route to go. You can put reverse lights in the bumper with led pods, and tap into the trailer plug reverse circuit.
    ElNopal and biebs96[QUOTED] like this.
  9. Nov 3, 2020 at 5:52 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    @Headlight Revolution license plate light! Easy set up and mounting.
    biebs96[QUOTED] likes this.
  10. Nov 3, 2020 at 5:57 PM
    biebs96
    PA
    It’s on my Christmas list for the wife.
    Tundyfundy[QUOTED] likes this.
  11. Nov 3, 2020 at 7:06 PM
    KC.Tundra
    KC.Tundra New Member
    Kevin.
    Kamloops, BC
    2019 SuperWhite Platinum Tundra CrewMax SB
    20’ KMC Grenade OR. TRD Skid Plate. TRD Rear SwayBar. Toyota Door Sill Protectors. Toyota Hardflip Tonneau cover.
    We need a Meso Customs Tacoma Stage 1 light set up but for tundras. He makes a setup for Tacomas with vleds. Where the top turn signal is now a brake light and the reverse light is a switch back with the turn signal. Worked really well! Has a clean look, safer(larger brake light), and was way brighter.
