Tailgate delete - PVM and backup camera options
Discussion in '3rd Gen Tundras (2022+)' started by Scruffy_Nerf, Apr 28, 2022.
  1. Apr 28, 2022 at 4:35 PM
    Scruffy_Nerf
    Scruffy_Nerf [OP] New Member
    2022 Toyota Tundra SR5
    I need to remove my tailgate to fit a slide-in camper. I would like to find a backup camera that can be mounted on the rear of the camper and will plug and play with the Tundra's integrated camera system. Compatibility with the Tundra's PVM system would be a bonus but not necessary. Has anyone found something that works on their 2022 yet?
    As a note, I contacted camerasource.com and they haven't started developing a camera that is compatible with the 2022 Tundra. However, they did ask for picture of the connectors to see if they previous gen camera would work. I'll try to send them photos soon.
  2. May 8, 2022 at 10:04 PM
    LuisLAN
    LuisLAN New Member
    You could try to use the camera that is already in your tailgate.
    Get it off of it and find a way to mount it to the camper.
    If you mount it roughly in the same position/height I would think that the PVM would still work.
    Scruffy_Nerf[OP] likes this.
  3. May 9, 2022 at 4:06 AM
    Chrlsone
    Chrlsone New Member
    Charles
    2022 MGM Platinum Tundra
    If you remove your tailgate. Will it not set the sensor off showing it is ot close. I remember reading in here somewhere that someone was complaining about just leaving the tailgate down was doing that.
  4. May 9, 2022 at 4:19 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    License plate backup camera maybe?
  5. May 9, 2022 at 8:42 AM
    Scruffy_Nerf
    I’ll look into all these suggestions. Thanks! I wonder if there is a way to bypass the tailgate closed problem.
  6. May 9, 2022 at 8:46 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    I'll be in the same boat when I get around to mounting our camper. Checking compatibility with my camper camera and harness from the 2020 Tundra is on my to do list. I'll try to check that this week if I get around to it. The camera and harness are both from Camera Source.
  7. May 9, 2022 at 8:57 AM
    LuisLAN
    LuisLAN New Member
    It would be a matter of trying the PVM with the gate open.
    And figuring out what type of sensor and how it gets triggered.
  8. May 9, 2022 at 9:01 AM
    LuisLAN
    LuisLAN New Member
    Adding to this, I think it would be a great idea to figure this out using the OEM camera because that would open the possibility to use the upgraded digital rear view mirror even while driving.
  9. May 10, 2022 at 8:19 PM
    P3ngu1n4l1f3
    P3ngu1n4l1f3 New Member
    2022 white Tundra TRD
    Has anyone found an extended backup camera wire for the 2022 yet?
    I cut and remove the camera from the tailgate with the plug. I did the same to the plug under the bed and added a 5 wire extension in between. However, the camera will still not turn on once when put into reverse.
    I've tried 3 type of wires, but still no luck.
    I thought the camera was damaged so I removed the extension and plug the camera directly to the plug under the bed, the camera works again.
    My guess is that this camera cannot use any sort of wires to extend the length to be relocated.
    Please let me know your thoughts.
    Kap1 likes this.
  10. May 10, 2022 at 8:26 PM
    Iwantone22
    Iwantone22 New Member
    22 Tundra Limited 4X4 ICE
    Just guessing here but possibly the extension too long. The system is not getting fast enough response maybe?
  11. May 10, 2022 at 8:32 PM
    P3ngu1n4l1f3
    Possibly... One of the 3 wires I tried was a 1 foot cable.
  12. May 11, 2022 at 11:10 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    following
  13. Aug 19, 2022 at 9:43 PM
    Keeferton
    Keeferton New Member
    Keith
    Bend, OR
    22 Tundra TRD Off-road DC
    Anyone find a kit that works yet?
  14. Sep 4, 2022 at 3:44 PM
    Scruffy_Nerf
    Did you end up trying your 2020 camera or did you go a different route?
  15. Sep 5, 2022 at 7:03 AM
    DexterL
    DexterL New Member
    Emailed a few companies about this since my PVM doesn’t work anymore with the topper installed, waiting to hear back but doesn’t sound good so far
  16. Sep 5, 2022 at 8:39 AM
    Scruffy_Nerf
    Look forward to an update but I had feeling it would be a long wait for someone to come up with a solution (if one exists).
  17. Sep 5, 2022 at 11:59 AM
    DexterL
    DexterL New Member
    if anyone feels sporty drop the headliner and see what the camera connectors look like- take some pics. We might get lucky and it could be universal and we can use ford or Chevy harness extensions… or we might get super lucky and toyota left 3-10ft or extra wiring in there we can snake through and grommet!
  18. Sep 6, 2022 at 6:07 AM
    Scruffy_Nerf
    Camera Source confirmed that they don’t have anything currently that will work. They say the wiring is completely different in the 2022 and sourcing the parts is difficult.
  19. Sep 6, 2022 at 2:15 PM
    DexterL
    DexterL New Member
    Got this from rosta, let them have it
  20. Oct 3, 2022 at 10:23 AM
    Dakota5556
    Dakota5556 New Member
    Sunny
    2022 Wind Chill Pearl Tundra Platinum
    GFC Camper, Baja Design Ditch Lights, Switch Pro, SDHQ Ditch Brackets
  21. Oct 3, 2022 at 10:26 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I would just order a tailgate harness and use it. I think it would be long enough to get the camera somewhere decent
    not the cheapest. But also, it would likely work
  22. Oct 12, 2022 at 10:11 PM
    Scruffy_Nerf
    I am looking into the possibility of buying an OEM backup camera and mounting it to the back of the camper.
    I think I’ve identified the group of parts that I would need but I’m having a difficult time deciphering the toyota parts catalogue.
    28BF9A2A-C44D-45B8-84A2-A95A969D5E2E.jpg E7D95982-4EE2-4CE6-93AF-C4979B005950.jpg
    I can’t tell the difference between 867B0-0C070 and 86790-0C290. Do I need both? I was thinking that I just need 86790-0C290 since I have the PVM system but it really changes things if I have to get both to make this plan work.
    I know @Roman is out of the parts game but I figured it’s worth a shot mentioning him to see if he has thoughts on this.
  23. Oct 19, 2022 at 5:42 AM
    TTCsparky
    TTCsparky New Member
    Scott
    2020 White Tundra Plt
    0C070 is the non-PVM camera. 0C290 is the PVM camera.
    The wiring/connectors are going to prove to be a larger hurdle, I imagine.
  24. Oct 19, 2022 at 6:03 AM
    Scruffy_Nerf
    I think you're right about the wiring/connectors being the most difficult part based on what I heard back from camerasource a few months ago. They said they currently can't source the connectors and have no idea when that will change.
  25. Oct 19, 2022 at 8:47 AM
    AverageAZN
    AverageAZN New Member
    Austin
    2004 Toyota Sequoia
    OME/Dobinson long travel lift, 34s
    Did you figure this out? Looks to me like the camera cable has a ground shield. youll need to carry that through the entire cable as-well. Try connecting that and see if it works
  26. Oct 23, 2022 at 9:05 PM
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    I believe that is the case too. I worked with cable assembly frequently in my previous work, and RF & Video cables use bare copper to shield from interference + ground.
    P3ngu1n4l1f3, do you have a better picture of the cables?
  27. Nov 6, 2022 at 4:43 PM
    hammertime59
    hammertime59 New Member
    kelly
    2022 Tundra Limited extra cab 4x4
    What about leaving the camera and wires intact when removing the tailgate? Then mount the camera on the camper shell roughly just off the camper door?
    Sorry, finally found the place to type, I'm new, be gentle.
  28. Nov 6, 2022 at 4:49 PM
    Scruffy_Nerf
    Definitely something I’m looking into. I was hoping someone else would do it first since my spray on bed liner is sprayed over the bolts converting the tailgate wiring. I’ll update if go down that road.
  29. Mar 16, 2023 at 11:30 AM
    Jasontylers
    Jasontylers New Member
    JT
    22 Tundra TRD aka The Wizard
    TRD 3” Lift KMC Wheels Nitto Recon Grappler 35’s TRD side steps
    Has anyone figured this out? Camera Source doesn't have them yet and neither does Tailgatecamera.com (where I got mine for my old Tacoma). I'm going to attempt removing the camera from the tailgate and mount it to the camper. Will keep everyone posted.
  30. Mar 16, 2023 at 7:11 PM
    Jasontylers
    JT
    This is as far as I’ve gotten to removing the camera from the tailgate for relocating on the camper. Lots of wires so I stopped! That’s the end of the wire for the camera. Definitely different than the Tacoma. There’s also another camera looking thing in the tailgate handle. Anyone know what that is?
