Tailgate Gap Cover / Rock Shield
Discussion in 'General Tundra Discussion' started by csuviper, Apr 22, 2020.
  1. Apr 22, 2020 at 10:33 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Absolutely hate having dirt and rock fall between the gap of the bed and the tailgate. I know there are solutions out there but which is the best one? Are they permanently applied or only installed when needed? Which option is best?
  2. Apr 22, 2020 at 10:37 AM
    csuviper
    Broomfield, CO
    Tundyfundy and Jim LE 1301 like this.
  3. Apr 22, 2020 at 10:55 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I can't answer your question, but this looks like it might be worth something if you have a cap or cover. At least it would look better than my homemade weather strip and sheet rubber.
    https://tailgateseal.com/
  4. Apr 23, 2020 at 4:04 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I just saw this on Facebook or online ad somewhere and assumed it was like a cheap wish ad or something. I’m interested let me know if you grab one
  5. Apr 23, 2020 at 7:50 PM
    csuviper
    Broomfield, CO
    That is a seal and not a cover for the gap. Not what I was looking for but thanks for looking.
    I want that gap cover so I don’t get dirt and rock falling to the ground as I shovel it out of the truck.
    15whtrd likes this.
  6. Apr 24, 2020 at 5:22 AM
    Slayer
    Slayer Member
    Slayer
    I just simply just remove the tail gate.
    1 quick electric disconnect.. & pull off the gate. takes less than a minute.
    also gives better access to the bed.
    ..Slayer
  7. Apr 24, 2020 at 6:13 AM
    Interesting
  8. Apr 24, 2020 at 8:05 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    What about using a 2' x width of bed piece of rubber sheeting. Place it over the gap with 1/2 on the bed, and 1/2 on the tailgate. Dump some stone in the bed, on top of the rubber sheet to hold it in place and then close tailgate and fill the rest of the load. The sheet will fold 90 degrees to keep the gap covered and the stone will keep it in place. Once ready to unload, lower tailgate and start removing stone. Once bed is empty, roll up rubber sheet and store for next use.
  9. Apr 24, 2020 at 8:18 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    whenever I haul loose rock or gravel, I throw down a tarp before the rock is dumped into the bed. Then I shovel out of the bed until it is lite enough i can roll the remaining material out by lifting on the tarp. Don't get much in the gap doing it this way, and it gives a little more protection to the bed itself. The only downside is you need to secure the tarp after the material has been loaded before you drive to your destination. Its also not the permanent solution you are looking for.
    RitcheyRch and 300BLK like this.
  10. May 8, 2020 at 2:53 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    BUMP. Interested in this as well. I had a rock fall between and put a little knick in the bottom of the tailgate. Would have been worse if i didn’t softly start to close it. If I slammed the gate closed I’m sure I would have bent metal.
  11. May 8, 2020 at 6:37 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Tarp is the way to go IMO. Makes cleanup easy and helps protect the liner from excessive wear.
    RitcheyRch likes this.
