Tailgate latch won't lock
Discussion in '1st Gen Tundras (2000-2006)' started by Outbound, May 10, 2019.
  1. May 10, 2019 at 5:37 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Of course this happens while I'm loading up for a trip.
    My tailgate latch will unlock but won't lock. I can only lock it by flipping the mechanism with my finger. It won't lock with the key at all. It will unlock with the key no problem.
    It was working fine last week, the last time I used the lock...
    Here's a vid to show what I mean. Any ideas?
    Black Wolf likes this.
  2. May 10, 2019 at 5:50 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine got sticky a year ago, I was afraid the key would bend from how hard it got to turn. I sprayed some graphite in the key hole and on the moving parts, it got smoother.
    Outbound[OP] and Black Wolf like this.
  3. May 10, 2019 at 5:52 PM
    Yep. I've had to use graphite a time or two.
    Outbound[OP] likes this.
  4. May 10, 2019 at 5:53 PM
    Outbound
    Aaron
    Northern Alberta
    I'll give graphite a try. It's not just stiff. It won't move to unlock at all. It feels fine when unlocking.
  5. May 10, 2019 at 6:00 PM
    Mine was the same way. I just had to use it in my driver side door lock. Wouldn't budge at all.
    Outbound[QUOTED][OP] likes this.
  6. May 10, 2019 at 6:08 PM
    Outbound
    Aaron
    Northern Alberta
    Heading out to snag some graphite lube right now. :thumbsup:
  7. May 10, 2019 at 6:10 PM
    :fistbump:
  8. May 10, 2019 at 7:02 PM
    Outbound
    Aaron
    Northern Alberta
    Didn't work. Still jammed. It will rotate counter-clockwise no problem. Won't rotate clockwise at all.
  9. May 10, 2019 at 7:03 PM
    Use Tannerite...
    Patch999 and VTYOTA like this.
  10. May 10, 2019 at 7:10 PM
    Outbound
    Aaron
    Northern Alberta
    Don't have that. How about thermite?
    Black Wolf[QUOTED] and VTYOTA like this.
  11. May 10, 2019 at 7:31 PM
    @Grumpy Uncle "might" have access to something better.................:spy:
  12. May 10, 2019 at 7:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Did you try another key? Had the same thing on my Tacoma door lock, turned out the key was getting worn. A new key cut from the same master worked great.
  13. May 10, 2019 at 7:47 PM
    I seem to recall you mentioning that! Definitely a possibility.
  14. May 10, 2019 at 7:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Actually now that I think about it, my chip key for the Tundra is the same in the door, the odd time I do use the key instead of the fob. Yet the plain copy I keep in my wallet locks and unlocks it perfectly. It was copied from the worn key as well. Must be something to do with the rounding edges.
  15. May 10, 2019 at 8:09 PM
    Outbound
    Aaron
    Northern Alberta
    Yep, that worked!! I have no idea why I didn't think about trying another key. Thank you!
  16. May 10, 2019 at 8:10 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    :bananadance:
  17. May 11, 2019 at 6:27 AM
    Professional Hand Model
    Hand Protectors
    Yeah our ignition keys and the ignition cylinders wear at the same rates from talking to each other daily. That rear latch cylinder doesn’t get used much and your worn key (rounded) wouldn’t activate the cams.
    Landphil for the win!
  18. May 11, 2019 at 6:48 AM
    Outbound
    Aaron
    Northern Alberta
    That makes sense. My back up key works in the ignition too. Might just swap it for the other one and keep only one on the keychain
  19. May 11, 2019 at 6:59 AM
    Hand Protectors
    Make new keys from the (newer) good key just so you’ll have those match up for the future, as well.
    Make sure you test all of them everywhere before leaving the key makers shop. They may have to fine tune like when I had new ones made for the 02’.
